C63 AMG (W204) 2008 - 2015
X PIPE VS STRAIGHT PIPE
Old Jul 6, 2010 | 03:12 AM
_AMG_'s Avatar
C63
Ive been speaking with a close friend of mine who is a master certified tech at Mercedes. I wanted to remove my resonators and I asked him if i should go with the x pipe or straight pipe. I was expecting him to say the X pipe but instead suggested getting a straight pipe due to a more free flowing exhaust path. He claimed that straight pipes are the only way to go on the C63. I trust him since he is a close friend and has worked on every single AMG, and knows these cars inside and out.
Can some one shed some light on this subject and give a couple of suggestions?
Old Jul 6, 2010 | 03:17 AM
C63newdude's Avatar
C63 AMG
Straight pipe with a "H" in the middle for sound balance and pulses.
Old Jul 6, 2010 | 03:40 AM
arctichaze's Avatar
C63
Speaking of which who sells these kits?
And are you talking about the resonators right before the mufflers?
Old Jul 6, 2010 | 04:22 AM
cls55's Avatar
i have xpipe on my ml63 from the factory.
Old Jul 6, 2010 | 05:02 AM
HIRO63's Avatar
c63
I have double X and I like it
Old Jul 6, 2010 | 09:20 AM
Dads C63's Avatar
2014 Audi RS7
I am very surprised an MB mechanic told you that since the crossover pipe in built into the resonator. Removing the resonator and replacing them with straight pipes is fine but then the two exhaust banks have no way to balance themselves. I would recommend removing the secondary cats and leaving the resonator in place. You may get some drone in the cabin without the resonators. I still have my stock exhaust in place from the resonator back because the gains are minimal and the sound increases exponentially.
Old Jul 6, 2010 | 12:33 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
If you trust him then follow his advice and don't second guess. In reality the seat of the pants feel is negligable.
Old Jul 6, 2010 | 12:35 PM
ejsheltra's Avatar
The resonators are built as a straight path and removing them will increase sound but not torque or power
Old Jul 6, 2010 | 03:31 PM
_AMG_'s Avatar
C63
I want a sound improvement that's why im only messing with the resonators.
Old Jul 6, 2010 | 05:11 PM
Even Money's Avatar
'15 VW GTI
You want it louder? Or you really don't like the stock exhaust note? I think you might be better off just deleting the cats, the resonator does a pretty good job as is.
Old Jul 6, 2010 | 05:29 PM
TTMotorsports's Avatar
Former Vendor of MBWorld
Whatever we're tuning!
Get rid of the secondary cats and leave the resonator.
Without the resonator there will be considerable droning/resonance while cruising.........unless you are stomping the ***** out of it all of the time.
Without adequate exhaust gas volume(just cruising/not stomping) the exhaust pulses will start to collide and cause droning.
Old Jul 6, 2010 | 06:15 PM
arctichaze's Avatar
C63
So where can I get the secondary cat deletes? And I'm assuming this is in the form of an X Pipe as well?
Old Jul 6, 2010 | 06:19 PM
emericr's Avatar
2021 Porsche TTS
You can do straight pipes for removing the secondary cats since you leave the resonators that acts as an X pipe. Any worthy exhaust shop in FL can do this for a few hundred dollars but it may not be that easy in So Cal with your strict laws. Other forum members should be able to chime in.
Old Jul 6, 2010 | 06:30 PM
arctichaze's Avatar
C63
Exactly... California rules prevent muffler shops from touching the catalytic converters of any car. Unless you know the owner
Old Jul 6, 2010 | 06:31 PM
Here is what a 63 cat delete looks like when it is done properly.
http://cid-8b4f5128fba1290b.photos.l...Catdelete2.jpg
Old Jul 6, 2010 | 06:35 PM
alqamzi's Avatar
2009 c63, 2011 GT500
^^ the link shows nothing
Old Jul 6, 2010 | 06:42 PM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
Nice work!
Old Jul 6, 2010 | 06:43 PM
It works every time I try it. It is hosted at Windows.Live
Old Jul 6, 2010 | 06:49 PM
alqamzi's Avatar
How much a job like this costs?
Old Jul 6, 2010 | 07:04 PM
Sorry the picture was so HUGE!
We charge $995 for the cat delete and mating to the factory resonator.
If we can duplicate the ends that go into the resonator(we use the ends off of the original pipes) then we can duplicate this section for much less than that!
Old Jul 6, 2010 | 07:05 PM
Originally Posted by obsidian05e55
Nice work!
Much appreciated!
Old Jul 6, 2010 | 07:10 PM
Here is OEM vs TTM set up.
http://cid-8b4f5128fba1290b.photos.l...te%20pipes.JPG
Old Jul 6, 2010 | 07:20 PM
TopEndS62's Avatar
2005 BLK/BLK E-Double Nickel.
^^^Beautiful work as usual bruce...... Whats your take on straight pipes replacing cats, and x-pipe replacing resonator??? if so where would you place the x-pipe? and with what size? 2.5???
55 setup...
thanks
Old Jul 6, 2010 | 07:39 PM
55 setup...
thanks
This is the same set up we fabricate for the secondary cat delete for the M113k and m156.
This is on an E55!
http://cid-8b4f5128fba1290b.photos.l...2CatDelete.JPG
The x-pipe's original functionality was introduced when engines had carburetors to "equalize" the banks. Now, I use an the x-pipe for sound purposes only. If you use an X-pipe it should be as far forward as possible.
The torque that you supposedly "lose" would only be at the initial stab of the throttle and will never come into play again as you go through the gears!
You want to excavate the exhaust pulses and heat out of the engine as fast as possible for peak efficiency and that is with as little back pressure as possible. Stepping the exhaust is another way to increase efficiency and that is why we use 3" after the OEM ~2.75".
Hope this helps!
Old Jul 6, 2010 | 08:00 PM
TopEndS62's Avatar
THANKS BRUCE.......clears up alot
