C63 AMG (W204) 2008 - 2015
CHEAP WEIGHT SAVINGS!!!!
Old Feb 9, 2011 | 10:33 PM
  #51
SonnyakaPig's Avatar
MB
Originally Posted by dodger63
Me to... Sorry my car before diet at all other then spare removal with me in it was 4150 and I weight 225 at that time so about 3925
No worries. Thanks for the info.
Old Feb 9, 2011 | 10:59 PM
  #52
GHAZAN's Avatar
MBUSA
rear seat cushion, as in the part your *** is on or your back?
Old Feb 9, 2011 | 11:15 PM
  #53
I am Jeff's Avatar
Steel Grey Metallic C63!!
All *** baby! lol Find something to pull out the rear seat cushion where the *** cushion meets the back.
Old Feb 9, 2011 | 11:30 PM
  #54
C63fan's Avatar
C63 w/p30; MHP ECU tune+header+mids+CF air intake duct+Akrapovic+wide body kit+ Vorsteiner VS110
Originally Posted by propain
I thought I read somewhere the Titanium ones saved 1lb per tire. That might have been for the whole setup though... they are cool though.
I just mean using a smaller rim like a 17 or 16.
63 nice...
Battery 45lb saved.
Spare Tire about 40lb saved.
Headrests 4.5lb saved.
CF hood and trunk: 75lb's saved
Passenger Seat: 63lbs
Rotors: 40lb's saved.
Rear seat cushions: 10lb's probably at most. Still good.
Smaller Rim size: (Please fill in if you know)
202lb's with the rotors...
Let Jon drive:
270lb's of weight savings...
Really learn a lot about our car! TKS!
Old Feb 10, 2011 | 12:22 AM
  #55
dodger63's Avatar
2013 f250 6.7 diesel
This is very educational!
Old Feb 10, 2011 | 01:42 AM
  #56
NS_C63's Avatar
2008 C63 AMG
+1
Old Feb 10, 2011 | 05:39 AM
  #57
NellyRod's Avatar
2012 C63 AMG BS, 2010 DUCATI 1198S
Really interesting thread. These weight savings are amazing, but unless you track your car, is it really worth the $$$. Considering the price of some of these mods, probably not IMO.
How much do you guys think this would affect gas mileage?
Is there a light-weight battery available that would be good for a daily driver?
Old Feb 10, 2011 | 09:47 AM
  #58
propain's Avatar
See Sig
If you break it down a lot of them are free weight savings...
Passenger Seat
Spare
Headrest
Cushions
124lb's without spending a dime.
Beyond that the Battery is a cheap solution to drop 45lb's so without hurting your wallet on the track day you can save 169lb's. You can drop .15 off your time for the price of this battery. Thats a good deal indeed.
Light weight for a DD? Why bother? You will probably only save about 10-20lb's at most. For a DD you wont feel the difference at all.
Great thread though... Thanks in whole to Dodger and Mthis and others who have discovered these tricks for us.
Fine, Jon cant drive... isn't Hagi Jon's weight or a little above? Let him drive! lol
Old Feb 10, 2011 | 10:46 AM
  #59
superlubricity's Avatar
Super Moderator Alumni
2011 GLK 350, 2013 GT-R, & 2013 RAM 1500
Here are additional weights from some of my previous posts. I'll work on creating a sticky for all of this info so it is easy to find/reference.
Forgestar F14 Wheel (1200-lb rating, 18x8.5 ET46) = 18.08 lbs w/ Hardware*
Forgestar F14 Wheel (1200-lb rating, 18x9.5 ET55) = 20.51 lbs w/ Hardware*
*Hardware (TPMS, hub-centering ring and center cap) = 0.175 lbs
Nitto NT05 Tire 245/40-18 = 25.09 lbs
Nitto NT05 Tire 275/35-18 = 27.38 lbs
Front OEM Wheel (18x8 ET45) & Front OEM Tire (Pirelli PZero 235/40-18) w/ TPMS and 5,000 miles of use = 49.75 lbs
Rear OEM Wheel (18x9 ET54) & Rear Tire (Nitto NT555R 285/35-18) w/ TPMS and 400 miles of use = 51.77 lbs
Rear OEM Wheel (18x9 ET54) w/ TPMS = 26.00 lbs
Front Forgestar F14 Wheel (1200-lb rating, 18x8.5 ET46) & Front Tire (Nitto NT05 245/40-18) w/ TPMS and 25 miles of use = 41.52 lbs
Rear Forgestar F14 Wheel (1200-lb rating, 18x9.5 ET55) & Rear Tire (Nitto NT05 275/35-18) w/ TPMS and 25 miles of use = 48.27 lbs
Rear Forgestar F14 Wheel (1520-lb rating, 18x9.5 ET54) & Rear Tire (Michelin PS2 275/35-18) w/ TPMS and 0 miles of use = 48.04 lbs
Spare tire, Jack, Styrofoam Pad and First Aid Kit = 39.50 lbs
Rear Headrests (All 3 Combined) = 4.51 lbs
Front OEM Brake Rotor (1-pc, Non PP) = 35.56 lbs
Front OEM Brake Rotor (2-pc, P30) = 29.58 lbs
Front evosport Brake Rotor (2-pc) = 23.33 lbs
OEM Crank Pulley = 6.3 lbs
evosport Crank Pulley = 4.3 lbs
Old Feb 10, 2011 | 11:01 AM
  #60
mthis's Avatar
Anything W/4Wheels
Passenger Seat
Spare
Headrest
Cushions
if i were jon's weight i would have hit 10's at atco lmao, im not that light fellas, if 180 is light then you fat a$$ need to get on diets
Old Feb 10, 2011 | 11:03 AM
  #61
blackbenzz's Avatar
haters crazy
Problem with letting jon drive is he will save thee average guy, some weight but he can't drive so....
Old Feb 10, 2011 | 11:08 AM
  #62
I am Jeff's Avatar
Maybe you need to take that huge **** and shyt before you get on the strip. You might save 2-4 pounds easy. lol
Old Feb 10, 2011 | 12:12 PM
  #63
MB
I, for one, will be very appreciative of this topic becoming a sticky. Thanks for being willing to organize everything into a nice thread.
Old Feb 10, 2011 | 12:24 PM
  #64
dodger63's Avatar
Hey hey.. You weight 180 soaking wet with boots on! I no I'm fat now but next year I'll be skinny
Old Feb 10, 2011 | 12:27 PM
  #65
dodger63's Avatar
It should but not this one it could be cleaned up allot
Old Feb 10, 2011 | 12:28 PM
  #66
GHAZAN's Avatar
MBUSA
use laxatives everyone's doing it
Old Feb 10, 2011 | 01:31 PM
  #67
Badblackfolife's Avatar
BENZ 550
i did all the weight savings and then gained 50lbs myself
Old Feb 10, 2011 | 01:40 PM
  #68
MB
For sure. Agreed.
Old Feb 10, 2011 | 02:10 PM
  #69
propain's Avatar
See Sig
I did... Im down to about 200 now. Dropping a much need 10lb's of holiday weight.
Jon says hes 140. If you met Jon than you know hes more like 120. Either way, I haven't met you yet, I thought I heard you were a light driver.
Old Feb 10, 2011 | 02:11 PM
  #70
chief63's Avatar
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
Rear Forgestar F14 Wheel (1500-lb rating, 18x9.5 ET54) & Rear Tire (Michelin PS2 275/35-18) w/ TPMS and 0 miles of use = 48.04 lbs
Just a quick correction that the F14 18s were also tested at 1500 lbs, I see you mention 1200 twice and then 1500, maybe just an error. thanks!
Old Feb 10, 2011 | 02:48 PM
  #71
Actually, I have sets of both and there is a difference. The original F14s were stamped 1200 lbs. They are about .7-lbs lighter per wheel than the newer 1520 lbs stamped ones. The design is slightly different too but only noticeable in the thickness of the spokes near the center of the wheel.
Old Feb 10, 2011 | 05:21 PM
  #72
dodger63's Avatar
So as I thought a lite weight set of wheels save u about 24 total pounds.
Do you have the rear evo rotors, how much do they save
Old Feb 10, 2011 | 10:27 PM
  #73
C63newdude's Avatar
C63 AMG
I used a few (4 I believe) Oddisey PC680 batteries. These batteries are the number one choice and weight only 11-13lbs.
Although the weight savings are proven the number one complaint is the rapid discharge. Go to other car forums and see. These batteries wouldn't start your car if you leave it park for 3 weeks or more. Another comun brand is the braille batteries.
Old Feb 11, 2011 | 04:30 PM
  #74
MB
I have some questions. I was telling my buddy who drives a BMW 135 about this battery weight savings idea.
He found some discussion online that said the weight savings from the lighter battery is very good but it should be factored against the amount of additional parasitic loss that the engine may see from the alternator having to charge the lighter battery more often?
My initial response was that even if you lose 6-10 bhp from the alternator contributing to greater parasitic loss, when you have a car that comes stock with 450 bhp, and then you get it tuned and maybe even add LT's, any affect on hp from additional parasitic loss is more than made up for with the weight savings from the lighter battery and more importantly, how that weight savings adds together with additional weight savings mods. (sorry for such a long sentence).
Plus, I don't imagine the lightweight battery constantly needs to be charged when the car is driving. Is that true? When the car is driving, does the alternator need to constantly charge the battery?
What do you guys think?
Also, another weight reduction mod that my buddy told me about: draining the windshield washer fluid. I haven't checked under my hood, but does anyone know how much fluid is in that canister?
Old Feb 11, 2011 | 04:35 PM
  #75
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
Guys, I've been running carbon fiber Braille batterys for years, they are great batteries. I put one in my Black Series about two years ago, saved me close to 50 pounds but I had issues when I sprayed nitrous, battery is too small for the draw of the nirtous system.
WARNING DO NOT ATTEMPT TO RUN ONE OF THESE BATTERIES IF YOU ARE RUNNING NITROUS!
