C63 AMG (W204) 2008 - 2015
You ever heard a chirping noise coming from the rear, even when not braking?
Old Jun 21, 2011 | 09:32 PM
Pertplus's Avatar
Hyperion's Candy-Coated 4 x 4
Really weird and cant seem to figure it out.
Old Jun 21, 2011 | 09:35 PM
DuaneC63's Avatar
AMG GLC63. Audi R8
With all the HP you've got, it's prolly chirping the tires between up shifts. The new wrap looks stellar btw.
Old Jun 21, 2011 | 10:32 PM
_AMG_'s Avatar
C63
I don't hear a chirp but occasionally I do hear a clink sound. Kinda like metal tapping each other when switching gears or when coming to a stand still.
The sound is very faint but I have noticed it a few times.
Old Jun 22, 2011 | 12:29 AM
Pertplus's Avatar
Well, I got the new performance rotors and I am wondering if it could be the brake pad rubbing up on the rotor (that was what one of my friends hypothesized). Does that sound reasonable? The sound seems to begin when I accelerate from a stop and basically sounds like super loud crickets. Obviously it's hard to explain, but needless to say I am not happy with this.
Old Jun 22, 2011 | 12:39 AM
BerBer63's Avatar
2009 C63
same thing happened to me but more of a tick not a chirp...try bedding your pads on the new rotors. if not see how the pad is seated might be rubbing while not engaging the brakes
Old Jun 22, 2011 | 12:46 AM
Pertplus's Avatar
Yeah, I think you might be right, it's like a chirp and tick. Kinda of like a high pitch sound that is as repetitive as a baseball card in bicycle spokes. Regardless, I kinda wish this was done prior to me getting my car back with the newly installed rotors.
Old Jun 22, 2011 | 11:52 AM
BerBer63's Avatar
2009 C63
Also check your lugs might be cross threaded or untorqued....?
Old Jun 22, 2011 | 02:07 PM
_AMG_'s Avatar
C63
Does the sound come from the rear only? If so, then there is a possibility that
your lug bolts are rubbing against the emergency brake shoe causing a repetitive clicking sound.
Is there any way you can provide us with a video so we can hear what the problem is?
Old Jul 19, 2011 | 01:54 AM
Pertplus's Avatar
Damn this noise back! I think it was diagnosed like you said, "rubbing against the e-brake"....although i thought it was cured. Could it be that the emergency brake doesnt get fully released (just noticed it again a day after I used the emergency brake) when I pull he lever? It's weird that the chirping occurs when moving, is that consistent with a rubbing against the emergency brake?
Old Jul 19, 2011 | 02:03 AM
_AMG_'s Avatar
C63
I had a similar problem, only mine was due to the lugs.
If the E-brake doesn't get fully released it will constantly make a ticking sound, it'll get progressively louder the more you drive.
Did this occur after you changed the rotors?
nrgy's Avatar
AMG GT-R
Yea I experienced this problem shortly when I had my car hooked up to a Dynapak Dyno. The lugs they used were too long, and it hit the e-brake and would make a clicking noise as the wheels turned. Luckily they stopped it right away and put in the proper length lugs.
When you installed your new wheels, if they used the same lugs then this shouldn't be the problem I wouldn't think.
