C63 AMG (W204) 2008 - 2015
ACG Build: C63 Weistec Stage 2
Old Jul 5, 2011 | 10:26 PM
Girard@ACGautomotive's Avatar
a car
Lightbulb ACG Build: C63 Weistec Stage 2
Mercedes Benz AMG has always been known as: "an iron fist in a velvet glove". They are luxurious cars with the ability to eat up most vehicles on the road in a straight-line race. The phrase has regained its meaning with the introduction of the c63 AMG, a smaller sedan with a monstrous 6.2 liter motor. Since its introduction, a number of aftermarket companies has offered ECU tunes, headers, nitros setups and other smaller performance enhancers. We all know what the gains were and what had been accomplished so far. With this project, we take a leap forward in enhancing the performance of the C63 AMG platform. Below you will find a short summary of the work to be done. While more will be added to the list, we will post the new updates as we go. The car will be built in-house at Automotive Connoisseur Group, San Diego facility by two of our Mercedes-certified mechanics.
The updates will first be posted to our Facebook page and then they will be posted here. "Like" us to be the first to see the updated images, the videos and the latest info:
Facebook Page
Weistec M156 Stage 1 Supercharger System:
- 2.3L Twin-Screw Compressor Module
- 1000hp Liquid to Air Intercooler Core
- High Flow Cast Aluminum T6 Hardened Lower Manifold
- High Flow Cast Aluminum T6 Hardened Throttle Body Inlet Y
- 45mm Boost Bypass Assembly
- Constant Mu, Delta Pressure (CMDP) Cog Drive System
- Billet Aluminum Cog Drive Cradle Assembly
- Poly Chain GT Carbon Fiber Cog Belt
- Supercharger Serpentine Drive Belt
- Johnson CM30 30 Liter/Min Intercooler Water Pump
- Big Cap Intercooler Water Reservoir with drain
- Dual Pass Heat Exchanger
- High Flow Fuel Rail System
- Molded Silicone Couplers
- Power-Steering Reservoir Relocation Assembly
- Weistec Engineering M156 Stage 1 Reflash (CARB E.O. Pending)
Weistec M156 SC Stage 2 Package
- Fuel System Upgrade
- Cog Pulley Upgrade
- Stage 2 Spark Plugs
- Calibration
Weistec M156 CNC Race Port Head
* 5-axis CNC machined
* 397.88 CFM Intake flow
* 257.81 CFM Exhaust flow
* Fully assembled, Read to run heads
* Custom ground factory 40mm intake valves
* Custom ground factory 33mm exhaust valves
C63 Tri-Y Long Tube Headers, Stainless Steel, w/V-band adapter flange
C63 (Optional) 3" Connecting Mid Pipes **For use with Long Tube Headers**
C63 300 Cell High Flow Cats w/ Test Pipe
Quaife limited Slip Differential + Install Kit
MB C 63 AMG (6.3 V8)
SLIP ON - HOMOLOGATED (TÜV approved/Street legal) - Akrapovic
Titanium exhaust system, mufflers (e24*03 1283) L&R, set of titanium quad rectangular tailpipes 118 × 83 mm
ACG W204 C63 Rear Resonator Delete (Install Pipe for Akra Slip On)
ACG 2-Piece Rotor Upgrade (Slotted)
Custom Caliper Repaint + AMG Logos
MA Carbon - 9-piece Interior Kit
MA Carbon - Steering Wheel
MA Carbon - Instrument Cluster
MA Carbon - Upper Center Console
Full Satin Protection Wrap
Old Jul 5, 2011 | 11:22 PM
BK63amg's Avatar
'16 GTS Solar
boss
Old Jul 5, 2011 | 11:27 PM
_AMG_'s Avatar
C63
Subscribed!!
Old Jul 6, 2011 | 12:32 AM
vdubpower's Avatar
i drive them all, fast and hard
me 2
is that a widebody c63 above me....
Old Jul 6, 2011 | 12:48 AM
jsc1234's Avatar
2010 C63, 2014 E63
very nice!!
Old Jul 6, 2011 | 12:51 AM
_AMG_'s Avatar
C63
Originally Posted by vdubpower
me 2
I wish!!!
Old Jul 6, 2011 | 01:07 AM
jspAMG's Avatar
C63, C300, 911TT x 3, 911 C2 x 2, 911SC, SL65, SL500, 280SL Plus some trucks
It will be interesting to see what happens with an unlimited budget.
Old Jul 6, 2011 | 05:48 AM
alrasheed1991's Avatar
2011 C63AMG P31
interested very nice
Old Jul 6, 2011 | 11:35 AM
Sincity's Avatar
Nice. Whose car does this belong to?
Old Jul 6, 2011 | 05:22 PM
HuangYiChao's Avatar
BMW M3 2010
nice!
Old Jul 6, 2011 | 05:31 PM
a car
The owner wants to stay anonymous; however, some of you will see him at some track events around SoCal.
Old Jul 6, 2011 | 05:37 PM
2011 C63AMG P31
price stage 1,2 pm me ?
Old Jul 6, 2011 | 05:58 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Unlimited budget, eh? Baller.
Thanks for linking to this thread from 6SO... will be interesting to see the results you/Weistec/ACGSD achieve.
Old Jul 6, 2011 | 06:14 PM
Dads C63's Avatar
2014 Audi RS7
Subscribed!
I hope you have better luck than JRCart.
Did you find the solution to the torque limiters that kick in beyond stage 1 numbers? I understand that stage 1 will be fine but when you get to stage 2 the power levels go beyond what the stock or modified ECU will allow and thats when the trouble starts. Have they been able to beat those limiters or are you going to face the same challenges?? If so, you should call JRCart and let him in on your secret. If not, an unlimited budget won't do you any good. Good luck!!
Old Jul 6, 2011 | 06:21 PM
a car
We will cross that bridge when we get there We are still at the starting stages of this build.
Old Jul 6, 2011 | 06:28 PM
dodger63's Avatar
2013 f250 6.7 diesel
Originally Posted by Dads C63
Subscribed!
At least someone speeks the truth around here, I hate the talk crap, then duck and hide that most do around here! Thanks dads
Old Jul 6, 2011 | 06:53 PM
James@ACG's Avatar
07 RS4 sold, R53 Cooper S, 2008 Cayman S, 2012 GTR
Right now we plan to do the build in stages...
first upgraded cylinder heads with stage 1
the we'll do teh stage 2 update with the LTH, and akra exhaust.
Next will be the stage 3 with SLS cams...
Go big or Go home
James@ACG's Avatar
PM sent.
Old Jul 6, 2011 | 07:57 PM
SonnyakaPig's Avatar
MB
Go big or Go home
I respect the project that you're undertaking. Should be a beast-and-a-half in every stage.
Quick question: A build of this level is obviously about maxing out performance at every stage (which is a good thing), but are SLS cams an efficient match for F/I?
Old Jul 6, 2011 | 08:26 PM
James@ACG's Avatar
The SLS cams will actually help us lower the compression to run more boost.
Old Jul 6, 2011 | 08:54 PM
MB
I hear that. But if you want to lower compression, and clearly this is a big budget build, why not just get lower compression pistons. Why rely on the cams that already don't seem to work very well in the M156?
How much boost do you guys intend to run?
If you think about pushing this blower (assume trans limitations can be overcome) to like 12-14 psi (kind of the high limit for a 2.3L twin screw) would the SLS cams lower compression enough to not blow an 11.3:1 CR motor?
Old Jul 6, 2011 | 09:22 PM
MB
It is premature for me to even suggest a catastrophic engine failure. My bad for speaking negatively. We should only hope for postive things for this build.
I have to admit though, when I hear "SLS cams" for this build I tend to think that maybe the thought of using them is because they are pretty much the only available aftermarket cams. And if that's the case, then is it really the best match: M156 motor, twin screw, and SLS cams?
Edit: I also want to say that your guys' shop has an amazing reputation and I really respect the work that you guys produce.
Old Jul 6, 2011 | 09:52 PM
jspAMG's Avatar
If there are better cams, then they will be made. Everything was once not available. After this tests some limits, expect the motor to be static until the end of the year, then it will be removed from the car and non bolt-on modifications will be started.
Don't everyone be so worried. I really don't care if we make some mistakes along the way and have to backtrack. And if we have an engine failure, they make more of them. Relax, lets see where it goes.
Jim
Old Jul 6, 2011 | 10:25 PM
MB
Jim
That's a really great attitude. It's unique for the M156 market.
I was asking about the cams because in the Domestic F/I aftermarket, there are cams made for blower application. And they differ from the performance oriented N/A cams.
Sounds like you have some really fun ideas planned for an engine build. I guess you'll be looking into the rear fender mod so that you can fit some wider rear wheels/tires.
I'm really excited to see your build, especially because it sounds like you may delve deeper than anyone's been.
Old Jul 6, 2011 | 10:37 PM
jspAMG's Avatar
My first engine build was when I was 13 years old and my dad pulled home a 5th wheel car transport FILLED with Volkswagon Beetles. He told me I could build a flat track behind our house and race them if I could make any of them run. Before I was 14 I had 3 of them running and had taught myself to weld so I could make mild steel rollcages.
At 16 my dad bought me a brand new 1969 Z28 and told me to have at it.
It should be noted my dad had a reputation with Ford Model A hotrods.... He also lost his license on the same day I did when he bet me his new Honda 450 could outrun my Z28 in a quarter mile and we got popped at 130mph drag racing the wrong way on a one way street. Fun times.
By 17 I had built two 500HP small block Chevy drag cars and I had broken through the 11 second barrier in a Nova II.
I have the itch and the resources. Money is useless if you aren't doing good or having fun with it. The P-Car people over on 6SpeedOnline know about my Merc build, its doubtful that many people here know that simultaneously to this Merc build, I have a 996TT with the motor out heading to 700HP also.
Everyday is an adventure. Live it.
Jim
You have already rated this thread Rating: Thread Rating: 10 votes, 3.90 average.
