C63 AMG (W204) 2008 - 2015
LSD
Old Aug 22, 2011 | 12:57 AM
darmawaa's Avatar
2011 E63 AMG
LSD
After installing supercharger my car tail is bobbing when accelerate even in straight line on the highway. Would LSD cure this problem? Or its only beneficial for track use (accelerate in turns)?
Old Aug 22, 2011 | 10:43 AM
chief63's Avatar
2021 Taycan Turbo, 2018 Radical SR3, 2021 Lincoln Aviator
The LSD is good for both track and straight line.
Keep in mind the tail will still slide but you will have power and control instead of not having any.
Get OS Giken or Quaife depending on your budget.
Old Aug 22, 2011 | 03:29 PM
SonnyakaPig's Avatar
MB
Do you think there is a noticable difference in offered performance between the two options you mentioned above?
Old Aug 22, 2011 | 03:36 PM
chief63's Avatar
Since I don't have hard facts (didn't try quaife), from the comparative reviews I read: the difference in lap times between no LSD VS Quaife VS Os Giken is the same between each. So there is as much difference between no lsd and quaife then quaife and os giken.
In a straight line I don't really know how much of a difference. The shop who installed the differential said most drift guys use quaife and most track guys use os giken.
If you take a 2 minute track, you'll probably shave off 2-3 seconds per lap with a quaife and about 5 seconds with os giken. Sounds about right with my experience.
Old Aug 22, 2011 | 03:41 PM
MB
Thanks.
I know you're approximating, but with what do you attribute the difference in lap times between the Quaife and OS Giken? Does it have to do with effecting corrective lock at different rates? Or is that they have a different percentage of lock capabilities?
Old Aug 22, 2011 | 04:22 PM
chief63's Avatar
The only explanation for faster lap times I have would be more effective locking on the OS Giken one and ability to lock 100% when exiting turns. This means the car will still push forward exiting out and provide more consistent acceleration out each turn.
I guess they keyword is here is consistency. When you can run consistent hot laps, you can get way ahead.
See it as Quaife allows control maintaining high speed thru a corner while the os giken allows better acceleration thru a corner. Both kind of serve different purposes.
The big advantage is that one of the weaknesses of the C63 is exiting out of corners and putting down all that power ASAP. The C63 is heavy so you really want to minimize the amount of time you spend turning at 100%.
Old Aug 22, 2011 | 04:27 PM
MB
Very good info. That makes sense.
Old Aug 23, 2011 | 09:31 PM
darmawaa's Avatar
2011 E63 AMG
Should we use regular diff oil or Limited Slip diff oil in the quaife?
Old Aug 24, 2011 | 02:21 AM
Djovovic63's Avatar
Mercedes C63 amg, Bmw X5,
I am wondering if anyone knows which company makes the OEM LSD, that is included in p30 package?
Old Aug 24, 2011 | 02:56 AM
Jae Duk's Avatar
'09 C63
Owners in the past claim that it's Quaife
Old Aug 24, 2011 | 03:11 AM
_AMG_'s Avatar
C63
LSD will definitely help you put the power to the ground better, next to a good set of tires.
