C63 AMG (W204) 2008 - 2015
C63 AMG ECU removal
Old Sep 12, 2011 | 11:12 AM
Wack's Avatar
C43 AMG CAB & VIPER
C63 AMG ECU removal guide
So I have just pulled my ECU from my 2011 C63 AMG to ship it out for a tune
Before I did this, I snooped around and found info but nothing in the form of a useable HOW TO with picture's so here's mine.
This took me about 2 minutes and no tools.
(small edit, as suggested by Xtyper, you should apparently disconnect your battery before disconnecting the your ECU)
First pop the hood (duh) then look here:
That's the ECU housing.
Now there are only 3 clips holding it in place that are here:
Pop the clips (the middle one pulls up). then pull the entire plastic cover straight up towards the sky.
Then, you see the ECU:
Then you need to pull out the 2 connectors. On the outside of eahc of these connectors is a big sideways T shaped PULL TAB. Just pull it out gently about 1-2 inches) and this will safely unlock AND pull out the connector:
Once this is done, all you need to do is pull out the ECU. It is not held in place by screws but rather slipped into 4 rubber mounts (1 on each corner):
So basically, you just pull the ECU straight out (gently) and VOILÀ !
You have your ECU in your hands.
PS: The Engine bay in the C63 tends to get unusually HOT when driven. The ECU may be hot or some surfaces in the area may be hot, to be careful what you touch or where you put the removed cover because you might very well burn your self or MELT THE ECU COVER if you set it down on the engine or area (no I did not melt mine... lol)
Attached Thumbnails C63 AMG ECU removal-img_1573.jpg   C63 AMG ECU removal-img_1574.jpg   C63 AMG ECU removal-img_1576.jpg   C63 AMG ECU removal-img_1577.jpg   C63 AMG ECU removal-img_1578.jpg
Old Sep 12, 2011 | 11:17 AM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
I love you.
I have been looking for something like this and no dice since you posted.
Did I mention I love you?
Old Sep 12, 2011 | 11:28 AM
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
Did you find anything living in there? lol
When I removed mine for tuning, I found some small creature built a nest, and was living in there.
Old Sep 12, 2011 | 11:58 AM
xtyper's Avatar
2013 E63 AMG
Once this is done, all you need to do is pull out the ECU. It is not held in place by screws but rather slipped into rubber mounts:
PS: The Engine bay in the C63 tends to get unusually HOT when driven. The ECU may be hot or some surfaces in the area may be hot, to be careful what you tough or where you put the removed cover cause you might very well butn your self or MELT THE ECU COVER (no I did not melt mine... lol)
Very nice writeup!
However, I strongly encourage you and others to always disconnect your battery before removing the ECU. A few of the tuners have emphasized this to me, pointing to the rolling code that could cause problems if not done.
Old Sep 12, 2011 | 12:02 PM
BAD430BENZ's Avatar
360 Modena TT
very well said
it probably took you longer to type this out and add the pictures than it did to do the actual ecu removal .
it is just that easy
this thread should be super helpful to people that are getting ready for a tune .
Old Sep 12, 2011 | 12:08 PM
Wack's Avatar
C43 AMG CAB & VIPER
Originally Posted by xtyper
Very nice writeup!
Just added a note into the guide, thanks for the suggestion.
Ironically, I did not think to disconnect my battery... So we'll see how it turns out... My ECU is in the box and waiting for UPS pick up to go out for a tune...
So I called Eurocharged to make sure (that's where my ECU is heading) and they said that it's really not a problem, they do it all the time without disconnecting
the battery and have apparently never had any issues. Never the less, I have edited the guide to mention this to air on the side of caution and so that I'm not
responsible for misinforming anyone.
Old Sep 12, 2011 | 01:34 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
great writeup!
With your permission I would love to post this DIY to our site to help others with their ecu removal!
Old Sep 12, 2011 | 01:42 PM
Mort's Avatar
Also figure out how to open the trunk with the Valet key before you disconnect the battery and shut the trunk, or else you will not be able to open the trunk. The key goes into a key slot on the left (driver's) side of the top ledge above the plate. You could also reconnect the battery after you remove the ECU.
Old Sep 12, 2011 | 01:59 PM
Wack's Avatar
C43 AMG CAB & VIPER
Originally Posted by loungn14
great writeup!
Thank you, you have my permission.
Old Sep 12, 2011 | 03:29 PM
j bro's Avatar
2009 C63 ///Amg
perfect
Old Sep 12, 2011 | 03:37 PM
amg4rl's Avatar
'16 Lexus GS F '18 M5
Just wondering, does disconnecting the battery mess with any of the other electronics...ie: radio, nav, seats, dash info? Anything need to be reprogramed after this?
Old Sep 12, 2011 | 03:49 PM
Wack's Avatar
C43 AMG CAB & VIPER
I'm not 100% but I seriously doubt it. Old radios would lose their channel presets but with today's on board computers etc, everything is typically stored in non volatile memory... however I may be wrong.
Old Sep 12, 2011 | 04:52 PM
stangxs's Avatar
c63, 11 e350 (DD)
I've been told removing the battery is just a per-caution, so you don't mistakenly try turning the car on while the ECU is removed.
Old Sep 12, 2011 | 05:08 PM
02Drunkenup's Avatar
335i
just out of curiosity, what would happen should you try to fire the engine with the ECU gone?
Old Sep 12, 2011 | 05:19 PM
BK63amg's Avatar
'16 GTS Solar
I could have used this last month when I sent my ECU to Jerry at Eurocharged! Great write-up!
Old Sep 13, 2011 | 12:54 AM
C63newdude's Avatar
C63 AMG
You are awesome!!. Not that is difficult to remove the ECU but it takes some enthusiasm to take the time and actually share the review with pictures. Thanks!!
Old Sep 13, 2011 | 11:42 AM
Sincity's Avatar
I have been told by Cory @ Kleemann; as a precaution if you do not disconnect the battery is to make sure you DO NO INSERT THE KEY in the ignition!!!
Old Sep 19, 2011 | 12:10 PM
Wack's Avatar
C43 AMG CAB & VIPER
So I got my ECU back a couple of days later (super fast) and put it back in and encountered no problems (after an ECU removal without disconnecting the battery.
I had not disconnected my battery, removed the ECU, locked the car. Returned a few days later, unlocked the car, poped the hood, put the ECU back in and the engine started fine and has given no codes or problems of any king (except significantly diminishing the life expectancy of my tires...)
