WTH..... "limp Mode"!!!!!
Gotta 2011 c63. ECU and pulley done. Between 2nd and 3rd 80% throttle car goes into limp mode. (scary crap. had no place to pull over on the highway to restart the car).The tune i just had it done and they tried to retune it twice already and couldnt find a problem. Took it to the dealer and the computer read pedal sensor was bad. Anyone had similar problem??? was it the sensor or the tune???
Other members have reported this problem and replacing the pedal sensor has been the reported fix for a few of them. The tune has been suspected in others. Try a search as there have been several threads reported on this issue. There is a table in the tune that compares the rate of air volume change reported by the MAFs to an expected range. If it goes outside of the range the tune will put the engine performance into limp mode. This is partially to prevent run away acceleration in the case of a defective pedal sensor. It may be possible for a tune to exceed this range and if the table has not been properly modified then limp mode is a possibility. It may also be a torque limit in the tune that is being exceeded.
Gotta 2011 c63. ECU and pulley done. Between 2nd and 3rd 80% throttle car goes into limp mode. (scary crap. had no place to pull over on the highway to restart the car).The tune i just had it done and they tried to retune it twice already and couldnt find a problem. Took it to the dealer and the computer read pedal sensor was bad. Anyone had similar problem??? was it the sensor or the tune???Trending Topics
sebc63:
Again, we will do anything possible to assist.
As I explained to you, we have a clk63BS shop car that has suffered from this for 6 months and has been at the dealer now for 6+ weeks. 2 pedals, countless harnesses, new TB, etc. They eventually found that the ECU harness had some loose connectors INTERNAL somewhere, and they are replacing the can bus harness complete as best I can tell. Same situation, the car ran great stock, once modded the issue presented itself and the issue stayed even when the car was back to stock. Very frustrating.
There are a number of threads on this site and others with this issue, I wish Mercedes would do a better job of documenting and linking these problem cars so there was a database to pull from to repair them! As we talked yesterday, please let me know when and how we can assist!
Brad
sebc63:
Brad
So far we have had issues with Powerchip/EvoSport, OE Tuning, but no issues with Kleeman, Renntech or MHP from what I read...
No doubt!
Brad
Brad
We are not the original owner, not sure we can. The dealer claims to have found the issue though, so we will know this week.
I'm glad the dealer may have found the fix. That's ultimately the best result.
Im not saying its only the Powerchip tune that causes this. Ive also heard the same issue regarding the Eurocharged tune as well.
Might even be an accelerator issue, who knows.
https://mbworld.org/forums/c63-amg-w...d-highway.html
https://mbworld.org/forums/4032894-post13.html
https://mbworld.org/forums/c63-amg-w...what-hell.html
Gotta 2011 c63. ECU and pulley done. Between 2nd and 3rd 80% throttle car goes into limp mode. (scary crap. had no place to pull over on the highway to restart the car).The tune i just had it done and they tried to retune it twice already and couldnt find a problem. Took it to the dealer and the computer read pedal sensor was bad. Anyone had similar problem??? was it the sensor or the tune???The car goes into limp mode once hit about 4k rpm.
Went into diagnostic and it was due to more than 3% variance between the 2 openings of the throttle body.
As the C63 has 2 openings in the throttle body, it is control by 1 pedal. So its either the throttle body can't sync the opening properly or the pedal is sending unequal signals to the throttle body...at least this was what i was told.
