a pair of cheap wheels that will fit on the rears?
or perhaps know of wheels from another car that would fit the c63 rears... so it would be easier to shop for some used wheels...
or what specs should i be concerned about so they fit on the rear but wide enough for some DRs
now the question is, what size drag radials would work?
any suggestions on tire size if i were to go with something like the MT ET street radials?
would 265/40/18 work?
The Nitto's are much wider than the M/T's.
I found some CCW 17s. http://www.ccwheel.com/wheelprofiles...php?id=Classic
They are 500 each, for the rear. The good thing about a 17 is obviously its lighter, but the tires are like 200 a side cheaper. You can also get a longer sidewall, so more flex in the sidewall, which is good for the drags...
Ill be getting some of these in the spring for 1/4mile and drift practices.. 275/40/17 was almost identical in diameter to 275/30/19, btw.
what size and offsets?
of these choices... which would fit or not fit on the rears...
my plan is to keep my stock fronts and switch out the rears with one of these size options for the strip... and be able to fit some MT ET streets on them...
17x7.5 et45
17x7.5 et50
17x8 et50
18x8 et45
18x8.5 et42
18x8 et50
19x8 et50
19x9 et50
19x9.5 et45
i just need some assistance in finding out if any of the sizes i've listed in post #16 would fit on the car
i also want to save from buying a full set of wheels until i'm ready to buy a set i really like... and a possible wide body option for the rears... i don't want to buy a set now... and find that i can go wider later on... but who knows... i'm happy with my current set up and was just looking to try out some drag radials on the strip
Hughes just wrote a big story about the car, now he's sold it?? Whats the deal? Hopefully another.
