C63 AMG (W204) 2008 - 2015
FS: X Pipe's for MHP setup and maybe others..
Old Mar 30, 2012 | 11:43 PM
Merc63's Avatar
C63 AMG
If anyone is running MHP headers with 3 inch mids. I have 3 extra X pipes for sale. They are 325 each plus shipping. They are made from mild steel and painted with high temp exhaust paint.
Below is a pic of them bead blasted awaiting paint.
This would have to be installed at a good exhaust shop. Install time is 1.5.-2hrs. The mids and X pipe have to be cut and welded together. The X pipe then slides right into the resonator connectors and clamped in place. This is an addon to the MHP system so if you wanted to remove the MHP system and install your stock exhaust you could as nothing on the stock exhaust is cut or changed.
The only piece of the MHP system that is cut is the mids. As the X pipe has to be welded to them. As you can see the X pipe slides into the resonator connectors and is clamped in place.
Please PM me if you want to grab one of these.. Below is a link of some sound clips after the install.
http://s1048.photobucket.com/albums/...t=IMG_1005.mp4
http://s1048.photobucket.com/albums/...t=IMG_1002.mp4
Old Mar 30, 2012 | 11:55 PM
Merc63's Avatar
C63 AMG
This X pipe might also work for other setups too. If you can take a measurement of the spacing between the catless mids, I can tell ya if it might work or not...
Old Mar 30, 2012 | 11:59 PM
balthaser's Avatar
2009 C63 AMG
I have resonator removed, else remains stock. so will this be direct fit?
Old Mar 31, 2012 | 12:24 AM
Merc63's Avatar
C63 AMG
You have the stock exhaust system?
I am not sure, I'd have to get a measurement of the distance between the two pipes... And I am not sure if they are 3 inch diameter??
If you can get under ur car and measure exactly how close the pipes are when the run parallel together into where the resonator would be then I can tell ya if it will fit...
Old Apr 1, 2012 | 12:51 AM
Merc63's Avatar
C63 AMG
These unfortunately wont work on the stock exhaust system.. Its too small and wider... If anyone is interested, we could get something fab'd up that would fit on the stock system...
Old Apr 1, 2012 | 02:28 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
interesting color for the coating
but can't seem to figure out why you have 4 sets?
GL with the sale!
Old Apr 1, 2012 | 12:55 PM
Merc63's Avatar
C63 AMG
GL with the sale!
That isn't a color. That's what metal looks like when it's bead blasted awaiting paint.
I have 3 left, 1 is sold and waiting to hear back from the Others that showed interest in buying one... So that's why there is 4 sets mr obvious.
Old Apr 16, 2012 | 07:51 PM
Merc63's Avatar
C63 AMG
Bump, 3 of these still left.. Anyone want them, let me know please?
Old Apr 16, 2012 | 07:53 PM
Merc63's Avatar
C63 AMG
https://mbworld.org/forums/c63-amg-w...ip-follow.html
Link to my thread with videos of how it sounds with this installed.
Old Apr 16, 2012 | 10:14 PM
SSSSE YA's Avatar
2007 CLS 63 030 package 2011 C63 1997 Dodge Viper GTS
I am looking for a X pipe and resonator delete set up to replace my stock system.
Old Apr 17, 2012 | 12:31 AM
Merc63's Avatar
C63 AMG
If you are serious PM me and we can work something out.. I have my stock system here so it would be easy to fab something up for that...
Old Apr 17, 2012 | 11:57 AM
SSSSE YA's Avatar
PM sent.
