C63 AMG (W204) 2008 - 2015
Coolant usage-may be the "bad news"
Old Apr 27, 2012 | 01:42 PM
  #76
AMGC60-3's Avatar
W164 ML500,SMART For two,1994 C280(5speed manual) 1999 C230k station wagon
Originally Posted by Valvestud
My model year 2010s have engine numbers 53661 on the C63 (delivered 5/11/2009) and 59086 on the ML63 (delivered 10/05/2010). So based on that it would extend up well into MY2010 and maybe beyond. If someone can give me an early delivery US VIN for MY2011 I can look it up.
Regards,
Old Apr 27, 2012 | 03:10 PM
  #77
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by AMGC60-3
Is there something I'm missing that prompts your post?
Old Apr 27, 2012 | 04:19 PM
  #78
bhamg's Avatar
C63 AMG
See ya later...
Old Apr 27, 2012 | 05:50 PM
  #79
Mort's Avatar
My car was delivered May 14 2010 and it is close to 1500 engines before the up to #1569xx 06 060658. That may take it past 2010 model year production and into 2011.
Old Apr 27, 2012 | 08:55 PM
  #80
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
Regards,
Now it goes to 2010 models too?
Old Apr 28, 2012 | 04:01 AM
  #81
carjones's Avatar
2009 C63
latest update:
Picked up the car yesterday night.
invoice shows all lifters replaced, all head bolts, gaskets, coolant, two oil changes (one to break-in the lifters), a myriad of "screws, gaskets..." with part numbers. Dealer cleaned up the car and did a nice job getting it back together. Car always ran well, feels normal.
Altogether good dealership experience, about 10 days to complete.
Old Apr 28, 2012 | 10:46 AM
  #82
Sincity's Avatar
Though I rather not have it happen to you, but congrats on getting it done under warranty. I wonder how much this would cost post-warranty?
Old Apr 28, 2012 | 02:51 PM
  #83
JeffDL's Avatar
C63
hmmm...mine is down. not nearly the same though. 09 46k miles. Car was fine then all of a sudden started running horrible like one or some of the coil packs died. At a stop it's pouring smoke out of the exhaust. smells like raw fuel? We'll see on Monday or Tuesday whenever they get to it.
Old Apr 28, 2012 | 04:24 PM
  #84
AMGC60-3's Avatar
Just waiting to see how many model years has this problem, OK?
Old Apr 30, 2012 | 01:43 AM
  #85
morganb's Avatar
C63 AMG, C36 AMG, SL500
Wow, same thing happned to me on Friday night (51K KM in an 08). So much smoke I stopped the car in an area with no stopping lane and pushed (downhill) to a safe spot. Hoping nothing serious but I think is going to be bad.
Old Apr 30, 2012 | 10:13 PM
  #86
GTibunny8v's Avatar
2005 C55
Hi All,
I have a 2010 ML63 and 2010 C63, both of which are in the range. I subscribed to STAR TekInfo and found the service bulletin:
01-05-2012 Star Bulletins LI LI01.30-P-051567_Ver.1a
LI
(0bytes)
Check engine light (CEL) on and low coolant indicator lamp lights up
M156 up to engine # 569xx 60 060658
As you can see by the byte count, it's an empty document and returns an error when selected.
Perhaps someone can get the details and actions MB will take if one experiences the problem.
Regards,
Joe
Its an LI doc which has to be view through TIPS.
Old Apr 30, 2012 | 11:47 PM
  #87
BerBer63's Avatar
2009 C63
what's TIPS, thanks for posting that service message
Old May 1, 2012 | 03:06 AM
  #88
DuaneC63's Avatar
AMG GLC63. Audi R8
I'd really like to get a copy of this document. Given I don't put alot of miles on my car my warranty will most likely expire before the problem occurs. I'd like to convince my dealer or MBZ that this is a defect they need to pro-actively fix.
Old May 1, 2012 | 07:16 PM
  #89
DuaneC63's Avatar
AMG GLC63. Audi R8
I spoke to my local MBZ dealer lead tech (not the brainless service advisor) who confirmed the service bulletin on Startech addresses the issue of failed headbolts, however he was not allowed to give me a copy of it. He indicated they have repaired a "few" 6.3 engine with the problem, one with as few as 20K miles on it. He indicated that MBZ has updated head bolts to remedy the problem "if it occurs". MBZUSA will not retro fit the engine with the updated head bolts until the problem occurs. I also spoke with a well regarded local indy (that work on lots of C63s) who indicated the problem is more common than MBZ would like to admit. Next step is to seek a written response from MBZUSA. More to follow. Let's keep this thread alive.
Old May 1, 2012 | 07:22 PM
  #90
JeffDL's Avatar
C63
mine has 2 hydro locked cylinders from stuck fuel injectors. motor is being torn down looking for bent parts.
Old May 1, 2012 | 07:30 PM
  #91
morganb's Avatar
Angry C63 engine issue
Sorry to hear that. MB called me last night, 1,3 and 8 cylinders no compression and coolant in those 3 cylinders. Sounds like a different reason to yours. Not sure yet on overall damage yet. Only had the car 6 months and its just come out of warranty.
Old May 1, 2012 | 07:34 PM
  #92
JeffDL's Avatar
C63
yikes no warranty? think I would have grabbed it back and pulled some shady insurance fraud or something. I would not want to be paying for this mess. But yes I agree mine seems very different just lots of problems for a couple simple injectors failures.
Old May 1, 2012 | 08:40 PM
  #93
Sincity's Avatar
Agreed!
Old May 1, 2012 | 08:43 PM
  #94
Sincity's Avatar
Since it just came out of warranty, I hope MB of Aus will step-up and take care of the problem.
Old May 1, 2012 | 08:49 PM
  #95
balthaser's Avatar
2009 C63 AMG
Wow, thanks for the heads-up, hopefully we, whose car are affected, could act enough to make MBZ treat this issue seriously.
Old May 1, 2012 | 09:58 PM
  #96
DuaneC63's Avatar
AMG GLC63. Audi R8
Sorry to hear of your troubles. Besides a cracked block or heads or porous cylinder walls (highly unlikely) the only way to get water in your cylinders is from a head gasket failure. Unless you over heated the engine (which you surely would have noticed) and warped a head, failed head bolts would seem to be the most likely cause. Since its both odd and even cylinders it would seem both sides have failed. Did you get a low coolant level light or a high oil level light prior to this happening. Keep us informed.
Old May 1, 2012 | 10:18 PM
  #97
morganb's Avatar
engine issue
No overheating. Got a low coolant light about 30 seconds earlier, then the CEL light came on. I stopped for about one minute (to check the manual) and then started again after reading the car may be in limp mode and I should go to an MB workshop soon. About 20 seconds after starting again lots of smoke, turned car off and called roadside assistance. I am hoping MB Aus will help but do not know yet. The information is this thread may help me in my case for them to help. I would love to get a hold of the service bullentin.
Old May 1, 2012 | 11:16 PM
  #98
bhamg's Avatar
C63 AMG
morganb - Best of luck...hope MB will help you out.
JeffDL - Your cats and O2 sensors will need to be looked at also. GL!
Old May 1, 2012 | 11:55 PM
  #99
Sincity's Avatar
Perhaps the plaintiff attorneys for that suit shouldn't start negotiating a settlement. The potential headbolt failure would seem more catastrophic than worn lifters.
Old May 2, 2012 | 12:02 AM
  #100
P1zzaman's Avatar
2007 Acura TL
Oh man, and I am thinking of buying a 2009 C63 with 25K miles. This sounds scary.
