C63 AMG (W204) 2008 - 2015
63 Programmer and Tune Sale!!! Flash your own car without opening the ECU!!
Old May 16, 2012 | 01:38 PM
ezatnova's Avatar
2016 C63S
Wow. Thanks. Great customer service so far!
One other question for now. Your sales team just sent me the directions for the My Genius programmer. It says to first download the stock map from the car to the programmer, and then upload to the computer. But, the rest of the directions make it sound like the write-up is for people who are sending their stock file out to be edited, then returned and loaded (modified) back to the car.
Since, in this case, the programmer is being ordered with the tuned maps on it and ready to go, is there a need to perform that initial "saving" of the stock map to the computer, or does the programmer already have the stock map built in (and I assume it would be selectable as one of the maps to load, when scrolling through those that are loaded on the unit)?
Originally Posted by Jerry@Eurocharged
- How will updates/new versions/adding a map to the 4 slots work? Will they be able to be downloaded to a PC and then uploaded to the handheld via a software interface, by the customer? - The device can hold many tunes (more than needed). You use the supplied software and connect the device to your PC via a USB cable to manage the device. You can add / remove any tune you like. However, the stock software cannot be removed.
- Does the base/stock map occopy one of the 4 slots, or is that always there in the unit and the 4 slots are for tune maps? - No worries...the device can hold many maps...Some of our BMW customers have over 10 maps loaded and ready to flash.
- I assume the unit comes with V3 maps of whatever octane you specify. Jerry mentioned V4 maps in one of his posts the other day. Is that just an anticipation of a future release, or is V4 something else? - V4 is currently loaded on my black series for testing. I had a local C63 owner testing V4 at the track (MSR). During his 5th session the tranny showed an overheat message. This was hours of track abuse that caused the light to come on. I'm working on V4 now to solve that issue. Once fixed there will not be a better tune on the market! Super fast shifting, track optimized maps, etc.
- Can you guys possibly make a sticky/first-post FAQ (or place a link to one if it exists already) for Q&A around the EuroTuner V2.0 as well as the V3 maps? Sure, the Eurotuner V2 is being replaced with the programmer. The device the 63 guys will receive is stand alone and has a built in LCD interface!
- Can you elaborate a bit more on what "else" the V3 tunes do aside from power. The website product page briefly mentioned faster shifting and smoother operation, at a very high level. Would love to learn a bit more detail about all the goodies it accomplishes. - Fast shifting, smoother shifting, optimized ignition advance, fueling maps, RPM (if desired), top speed limiter, and a few key maps that are difned by us that I don't want to mention. :-)
Old May 16, 2012 | 01:45 PM
sales@eurocharged.com's Avatar
SPONSOR
C63S
1. As long as each ECU has the same Hardware Software and VIN then it will work.
2. The tunes always stay in the device!
Originally Posted by immelman
I have Couple of Questions like everyone else.
(1) If you have two ECUs for your car will (1) tuner flash both of them?
(2)Do the tunes stay in the device always are do they get "moved" back and forth to the ECU? (For instance if you have 2 ecu's can you flash the exact same file to them both?)
Old May 16, 2012 | 01:46 PM
b16's Avatar
b16
2009 C63, 2000 ML 430, 1994 Del Sol Vtec
I down for programmer + tune.
Can you supply a stock tune as well?
I would like: stock, 91v3, 100
Anyone running E85 on these things yet? :P
Old May 16, 2012 | 01:48 PM
SPONSOR
C63S
I have not tuned any E85 63's yet!
I can supply the stock tune!
PM sent.
Old May 16, 2012 | 01:49 PM
ronzride's Avatar
2012 C63
Also interested in a response to this!!
Old May 16, 2012 | 01:53 PM
SPONSOR
C63S
The programmer leaves our office blank. It requires you to mate it with the vehicle before it can be used.
Generally you would read the stock file, send it to me, I modify and send back. However, the 63 ECU cannot be read via OBDII so the device will only ID the car. Once you have this ID file, you send it to me. I match your stock software based on the ID file, attach it to an email and send it on the way to you. From that point forward, you load all tunes via the same method.
To sum it up, the device will arrive blank. We will send all files via email for you to load / manage.
One other question for now. Your sales team just sent me the directions for the programmer. It says to first download the stock map from the car to the programmer, and then upload to the computer. But, the rest of the directions make it sound like the write-up is for people who are sending their stock file out to be edited, then returned and loaded (modified) back to the car.
  #32
SPONSOR
C63S
replied
Old May 16, 2012 | 01:55 PM
  #33
ezatnova's Avatar
2016 C63S
Related to this, what happens when it comes time to sell the unit? Is there a way to "unmarry" the unit from the car/vin/ECU, so it can be used by someone else?
Old May 16, 2012 | 01:57 PM
  #34
ezatnova's Avatar
2016 C63S
Very interesting. Thanks for the informative reply.
Old May 16, 2012 | 01:58 PM
  #35
nkc's Avatar
nkc
2012 C63 Coupe P31 CF Trim - Eurocharged V7, 2012 RangeRover Autobiography, 2017 GLS 63 Amg
Sent you an email
Old May 16, 2012 | 02:04 PM
  #36
Kaiba's Avatar
AMG
Hi Jerry ,
Goods news ! Congrats for the good work.
Might be a dumb question but , are you going to provide a special tune for the C63 BS ? I guess the tune would not be the same as a "standard" C63 Coupe ?! If yes , I'll be a buyer for sure ( I'm running EU 98 by the way )
Old May 16, 2012 | 02:07 PM
  #37
SPONSOR
C63S
You can "unmarry" and resell the unit.
There will be an unlock fee of $200 required to be paid in order to use it on another car.
Old May 16, 2012 | 02:13 PM
  #38
SPONSOR
C63S
Originally Posted by Kaiba
Hi Jerry ,
Yes, we are woking on a special tune for the C63 BS. As of now, we have only managed 10WHP. Will keep you posted on the results in a new thread.
*edit: I said CLK63 BS.. oops.
Old May 16, 2012 | 02:26 PM
  #39
derspi's Avatar
2009 C63
Can we place our order through Eurocharge Canada & still be eligible for the group buy discount?
Old May 16, 2012 | 02:40 PM
  #40
b16's Avatar
b16
Sweet, mine has been ordered.
In a few weeks I'll do some dyno comparisons from stock to v3 tuned with the programmer on a Mustang Dyno.
Old May 16, 2012 | 02:44 PM
  #41
flooby's Avatar
2012 C63 Sedan
Sweet! count me down for a programer and tune!!!
Old May 16, 2012 | 02:45 PM
  #42
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
hey guys we are getting swamped with pms/etc You can also email us to sales@eurocharged.com We have the entire crew answering emails today!
Old May 16, 2012 | 02:47 PM
  #43
bhamg's Avatar
C63 AMG
Amazing. Congrats Jerry, I think for the moment you may have killed this segment of the tune business. Why would anyone go elsewhere?
Old May 16, 2012 | 02:48 PM
  #44
loungn14's Avatar
SPONSOR
sure!
awesome!
http://www.eurocharged.com/index.php...mart&Itemid=99
get it while they last!
Old May 16, 2012 | 02:49 PM
  #45
loungn14's Avatar
SPONSOR
our thoughts too!
That's also why we keep our prices low and are the only ones to offer FREE retunes for future mods!
Old May 16, 2012 | 02:55 PM
  #46
sales@eurocharged.ca's Avatar
Former Vendor of MBWorld
c63
Just to let you know this offer is avaliable to our CDN customers as well,
To place you order in Canada please email sales@eurocharged.ca
Old May 16, 2012 | 02:56 PM
  #47
bhamg's Avatar
C63 AMG
Originally Posted by loungn14
our thoughts too!
For sure, it's definitely a great business model. Congrats again!
Old May 16, 2012 | 02:58 PM
  #48
2010c63amg's Avatar
2010 C63 amg
Would we be able to use this programmer if we use a different tunners tunes? Meaning would we be able to use it to switch back and forth between their tunes as well? Or would this programmer only work with using Eurocharged tunes?
Old May 16, 2012 | 03:12 PM
  #49
masonh66's Avatar
2007 E63
[QUOTE]Would we be able to use this programmer if we use a different tunners tunes? Meaning would we be able to use it to switch back and forth between their tunes as well? Or would this programmer only work with using Eurocharged tunes?[QUOTE]
+1
Old May 16, 2012 | 03:15 PM
  #50
loungn14's Avatar
SPONSOR
between their tune and stock? You can do that, but you would need to ship the ecu over to us in houston to backup and create the file for you to write to the device.
