C63 AMG (W204) 2008 - 2015
How to do Oil Change on your C63 at Home!
Old Feb 28, 2014 | 08:32 AM
  #76
AMG893's Avatar
2010 C63 Estate
FYI- Just did my oil change on my 2/2010 built, and used 10 Quarts (9.46L) of oil. Drove around the block (Engine temp 85 Cel/ 185 Far) checked dipstick, and oil level just around the top (Give or take)
Only did the sump drain, not oil cooler.
Though i titled the car, by jacking from DRIVERS side (RHD car), so the drain plug was at the lowest point, and let it drain for a GOOD 30 mins, before putting drain plug back in.
I have ALWAYS used ESP 5W-40 Mobil in ALL my M156's over the years.
Oil that came out of the car was in excellent shape. No mixture of any contaminates. Oil filter also appeared to be in good shape. (Car has 50k/31miles on it) Was very happy with it.
Though, after the oil change, i did notice the engine was quieter & smoother revving.
Old Aug 26, 2014 | 02:34 PM
  #77
Conv_GSDriver's Avatar
'18 Audi A4
I'm glad this topic has been talked about again recently, I had the same questions. I called my local dealer and they informed me that they use the 5w-40 Mobil 1 for their changes. I was trying to purchase a few quartz to maintain here to do the occasional topoff, but the one carried at the walmarto here is the 5w-40 for diesels. I passed on that not being sure but after reading this, it answered my questions.
Old Aug 26, 2014 | 02:44 PM
  #78
ld63's Avatar
2014 C63 507 Sedan
I used these instructions to change my oil a few thousand miles ago with mobile 1 0w-40 (bought the 5 qt jugs from walmart - great price). My dealership said this is what they use.
I did not drain the oil cooler, but did some 'jackstand gymnastics' to help drain from all angles. Also this was an unscheduled oil change.. I'm planning to let them do the official service changes.
Runs like a champ.
Old Aug 26, 2014 | 04:40 PM
  #79
'18 Audi A4
Yeah Walmart has those right now Dow $22.26 for the 5QT container, great price! They however, do not have the correct 5w-40 in stock.
Old Aug 27, 2014 | 01:10 AM
  #80
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Here we go again... the Mobil 1 5W40 Formula M is NOT a better oil for your M156 engine than the Mobil 1 0W40. See what I just wrote at https://mbworld.org/forums/c63-amg-w...rning-off.html (read the whoel thread - some of the relevant stuff as it it pertaIns to the oil composition is near the end) and in other posts elsewhere on this board. BITOG also has some good information ont the subject if you care to sift through the various posts.
If you live in North America, the 229.51-spec 5W40 Formula M that they (the dealers themselves) are now all putting in IS NOT EVEN APPROVED for your car according to MB Germany! At least it wasnt't in July, which is the latest BEVO revision. Try telling that to your SA at the dealer.
Use the 0W40 knowing that you've got better engine protection than you would with the 5W40 Formula M and enjoy your C63!
Old Aug 27, 2014 | 06:58 AM
  #81
tfthach13's Avatar
'09 C63
I thought MB officially dropped Mobil1 as their official oil??
You guys should really stick with the 0w40 viscosity. Ferrari came out with an article a while back for why they use a 0w30 (or 0w20, I forget) on the basis that flow is better for your engine to reduce heat. But then again, Ferrari engines have higher compression rates so a low viscosity oil wouldn't be a problem.
Old Aug 27, 2014 | 06:38 PM
  #82
-Marlin-'s Avatar
2011 C63 AW
I think we will all be ok using Mobil 1 0w40 or 5w40 M or ESP 0w40 or ESP 5w40.
We are splitting the finest of hairs here and even people with OCD think this oil argument is too much.
Enough is enough....geezus.
Old Aug 28, 2014 | 04:06 PM
  #83
Sincity's Avatar
Really? Has anyone bought oil at a dealer recently?
Old Nov 12, 2014 | 05:18 PM
  #84
AMG Boost's Avatar
2010 C63 P30
Hey peeps.
I just had an A service done at the dealer yesterday. I was watching my car get worked on for a little bit and noticed they have a vacuum system to suck the oil out of the dipstick, much like the Mity Vac.
My bill came out to $450. This is for a basic A service..... I noticed on the bill they used 10 quarts of oil. This is weird because I know from changing the oil is should take 9 max. Also I checked my oil afterwards and it is just as dark as it was when I took the car in..... What the heck. I dont know if I trust my dealer and I dont think I will be taking it back there again.
Will my CPO warranty be affected if I do my own work and document it?
Old Nov 12, 2014 | 07:27 PM
  #85
Diabolis's Avatar
The drain bolt on the M156 is not right at the very bottom and doesn't allow the crankcase to completely drain, so vacuuming it out gets more oil out. And, the M156 takes 9.5 L even if you don't drain the oil cooler, so 10 quarts is right on the money to the second decimal place.
I can't comment on the color of the oil, but I can assure you that a MB delership would not be in business if they were trying to stiff MB's customers by putting in dirty oil. You saw them vacuum the old oil out. What do you think it was they put back in? The same oil? The cost of the oil itself is insignificant compared to what they make on the labour. Hell, if they could, they would be happy to change your oil every single day and take your money that way. If instead you had said that the delaership had discovered a few more issues and told you they needed to replace a number of other items (that may still be serviceable for some time) and you had to pay out of pocket for them, I would believe you - but I think you're really over-reaching on this one.
I hate to break it to you, but $450 is par for the course. It's Mercedes-Benz, not Bubba's Lanmower and Auto Repair. Besides, AFAIK a CPO warranty in the US is only valid for 12 months after the original 4 year warranty expires, so on a 2010 you don't have much to worry about in that regard. If the price of the service is what has you worried, I would suggest that you try to privatley offload the car now and minimize your losses. You bought an expensive used car - or as I like to think of it, someone else's discarded goods before they became their problem - that will soon require more and more $$$ to maintain, so presumably you are aware of the ongoing maintenance costs. It's not a Toyota Camry - it is a beaten C63 that is going to require a lot of money to keep on the road. Just a word of warning.
Old Nov 12, 2014 | 08:42 PM
  #86
AMG Boost's Avatar
2010 C63 P30
Hmm that all makes sense. Ya I was wondering why the oil was so dark... Maybe left over oil in the oil cooler tinges the fresh stuff.
I have CPO till 2016 so its all good as far an maintenance goes, I will have to pay for one more B service before my warranty is done. And its not that I cant afford the car, was just surprised its was 450 for a oil change Haha. Il most likely be picking up a 2012+ GTR after my CPO warranty is gone.
Old Nov 12, 2014 | 09:04 PM
  #87
Diabolis's Avatar
Probably leftover stuff from the oil cooler. They don't drain the oil cooler when they change the oil, so even the quart that's left over could make the fresh oil look like it's already been used for a year.
And, just for the record, I did not mean to imply that you can't afford a new car nor offend you in any way. I was merely taking about the mistakes that *I* have made in the past with buying used, expensive cars when I couldn't really afford them.
Old Nov 12, 2014 | 11:10 PM
  #88
AMG Boost's Avatar
2010 C63 P30
No offense taken! You had a very thought out and informative post and I appreciate the info.
I love my C63 it is an amazing car. I am considering keeping it outside of the warranty range however the GTR is one of my dream cars. Once my C63 warranty is done in 2016 it seems like a good time to upgrade
Old Nov 13, 2014 | 01:19 PM
  #89
'18 Audi A4
So does anyone use the 0W-40 still? I'm moving to Virginia next month and being In a "colder" state than in Southern California, should I use 0w-40 or continue to use the 5w-40 in VA?
Btw Walmart has great prices on the Mobil 1 five QT jugs at $22.44 per so if you are looking todo it yourself, great savings. They typically do not carry the correct 5w-40 but their 0w-40 is the correct spec.
Old May 13, 2015 | 04:12 PM
  #90
prashd's Avatar
2011 Red C63
Did my first oil change following the instructions on this page. Spent quiet a lot of time looking for the Oil cooler drain plug and finally found it. Its hiding behind some rubber under the middle oil cooler towards the passenger side.
Here below are the pics of the oil cooler drain bolt
Old Jun 19, 2015 | 12:48 AM
  #91
ShaneN.'s Avatar
2018 e63s edition 1
Originally Posted by Jons95c36amg
Also remember put in 8.5 quarts of oil to get right on full line.
is this with or without removing the oil from the oil cooler?
Old Jun 25, 2015 | 01:21 PM
  #92
mrmkeller's Avatar
2010 C63 AMG & 2004 E500 4Matic Wagon
+1
Old Oct 2, 2015 | 10:34 PM
  #93
RobV_C63's Avatar
2010 C63 AMG
Ok, so I'm a bit confused. I've seen to use the w-30 esp formula M, and I've seen to use the new 0w-40. My problem is the MB Germany says to use the 0w-40 but my I live in south Florida and the temperatures here hover around 86-93 throughout the year except for one to two months when it gets relatively cold.
Because of this hot weather in Florida, am I better off using the 5w oil over the 0w?
Old Oct 2, 2015 | 10:46 PM
  #94
ENV²'s Avatar
2001 Porsche 911 Turbo (heavily modified)
nevermind
Old Oct 2, 2015 | 10:51 PM
  #95
looney100's Avatar
None
This is a widely held misconception. A 0W40 oil is only thinner than 5W40 when cold, not at operating temperatures. For multi grade oils, consider the first number the 'weight' when cold, and the second the 'weight' when hot.
Old Oct 3, 2015 | 08:59 AM
  #96
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
You amateurs.
Best oil ever is.........
Liqui Moly 5w40 leichtlauf high tech.
It meets MB229.5 as well.
Check it out!!!!
Old Oct 4, 2015 | 01:02 AM
  #97
looney100's Avatar
None
Don't use anything that doesn't meet MB229.5 if you want to maintain your warranty - no matter how great people in the net say it is.
Old Oct 4, 2015 | 09:59 AM
  #98
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
I suggest you search for all the posts related to the subject by Diabolis. He has a clear and scientific understanding of which is best.
Old Oct 5, 2015 | 01:40 AM
  #99
Diabolis's Avatar
Do not use any xW-30 oil in your C63. Do not use any ESP oil (MB 229.51 or 229.52) in the C63 if you live in North America (or for that matter, anywhere else if you can get a 229.5 oil). Use only MB 229.5 spec approved oils. And, don't fall for misleading marketing jargon like "designed for use in cars requiring MB 229.5 spec oil" or "compatible with MB 229.5 spec" - that's NOT the same as an MB 229.5 APPROVED oil).
While I haven't seen a VOA or UOA from the new MB-branded "MB 229.5" oil, it has been confirmend that it is now made by Shell (grey bottle with a yellow label). Now, Shell no longer sells the Helix branded oils in NA, but even if they retained the superior Helix formulation (the Pennzoil and Quaker State brands are nowhere near the quality of the old Helix), IMHO it would still be inferior to the M1 0W-40 formulation as an "all-around" oil in the C63 when it comes to engine protection, both from a viscosity and additive package standpoint.
Off the record, IMHO the only other oil that comes close to the M1 0W-40 is the Shell Rotella T6 (ester-based 5W-40 with great HTHS and additive package), but that's an HDEO oil and not approved for use in the MB despite the fact that it holds up better than most oils on the 229.5 BEVO list. I run that in my 25-year-old P-cars including the track rat, but the C63 only gets M1 0W-40.
Old Oct 6, 2015 | 04:07 PM
  #100
medamullet's Avatar
2011 C63 AMG
just posting for later. I see that the pictures in the first post are missing on a couple so I will have to climb around under there to look around. I like doing all my own work on my car for the fun of learning.
