C63 AMG (W204) 2008 - 2015
C63 AFE Filters / Charcoal Delete
Old Feb 27, 2013 | 12:19 PM
  #51
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
I have no charcoal with K@N...no issues ever...
It may be luck of the draw...
Old Feb 27, 2013 | 09:51 PM
  #52
_timothy's Avatar
c63
i did the weistec filters and row airboxes. no issues whatsoever.
Old Feb 28, 2013 | 10:02 PM
  #53
kenster96's Avatar
2012 C63
followed that DIY 100% and AFE filters with charcoal delete. No CEL 2012 c63 with 2011 afe pro dry s. I just got them so I started it up only once and drove it for about 10 minutes. Will repost if things change.
Old Feb 28, 2013 | 10:16 PM
  #54
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
How about 2011 AFE dry filters on a 2009 sedan? Will this work?
Anyone has tried this already?
Old Feb 28, 2013 | 10:32 PM
  #55
kenster96's Avatar
2012 C63
I was looking up this before I bought mine, and I saw that someone put a 2011 afe filter on a 2010, not saying it will work but I feel like it should work.
Old Feb 28, 2013 | 10:47 PM
  #56
abcut973's Avatar
What can be the difference between the 2009/2010/2011/2012 filters? Size wise they should be the same right?
Old Feb 28, 2013 | 11:13 PM
  #57
mitviet's Avatar
Daytime: Slow and easy with 2006 SL500 & 2003 S430 . Night time: Hard and Fast with my wife
Guys, apologize in advance for jumping into this thread but just wonder if you guys know the R230 SL500 have any type of charcoal filter? I would assume NO since it would make no sense to filter the cabin air on a convertible.
Old Mar 1, 2013 | 12:07 AM
  #58
Higgs Boson's Avatar
2020 AMG GTR
it takes several starts and run cycles for the car to test itself.
the charcoal filter has nothing to do with the cabin air filter.
Old Mar 1, 2013 | 07:32 AM
  #59
XcA's Avatar
XcA
2013 C63
2013 standard saloon C63 here. Replaced filter with BMC oil filters (http://www.bmcairfilters.com/car-fil...0_d675_11.aspx) and there where no Charcoal filters at all....!?
Running for 200 km's so far with no issues or CEL.
Old Mar 30, 2013 | 04:16 PM
  #60
EGray@Germain's Avatar
2020 AMG C63s
Hey guys did the charcoal delete on my O8 E63 AMG and a set of K&N's had no issues of CEL, but after a few days I got a CEL light. I had not issues with the drivabuilty and performance, with the K&N's and charcoal delete it feels like it picked up in power and throttal responce. I have the car dynoed before it put down 405whp 411wtq and with the filter delete and K&n's in it made 421whp 422wtq on a dyno jet.
I have heard guys do secondary cat delete and xpipe and eurocharged tune so thats the next step.
P.S. CEL light went off after 85 miles driven on the car
Thanks,
Eric
Old Mar 30, 2013 | 08:17 PM
  #61
ZephyrAMG's Avatar
^^^^so maybe gotta just drive the car for a while until everything just adjusts...interesting observation...
Old Mar 30, 2013 | 09:22 PM
  #62
RuckinAMG's Avatar
C63
Just got done putting in Afe drys with the charcoals removed. Keeping my gingers cross. Previously had K&Ns and the dreaded cel came on.
Old Mar 30, 2013 | 10:41 PM
  #63
Mikegpr03's Avatar
C63
Boils down to this.
If your gonna mod your car you will run risks ( big or small )
The only way you won't have that issue is to leave it stock.
Old Mar 30, 2013 | 11:41 PM
  #64
c63addix's Avatar
2011 C63 Calcite White
Just took my car in for check up after having a CEL for over 2 months after I got my K&N air filters.
They say its because of air leaking intake manifold gasket. I guess the K&N filters are no problem
Old Mar 31, 2013 | 03:10 AM
  #65
c63addix's Avatar
Also could someone explain what effects will that air leak intake manifold gasket cause? I noticed after the service, my cars gotten louder and smoother. Maybe because of new oil as well it's gotten noticeably louder after few hours of driving after the service
Old Mar 31, 2013 | 06:14 AM
  #66
Mikegpr03's Avatar
C63
I had the manifold gasket leak when I got my car. They swap out the gasket and update the minifold bolts too.
Old Mar 31, 2013 | 08:15 AM
  #67
2020 AMG GTR
post back after they fix it. the first time I installed my filters I let the shop check it and they also replaced the gaskets. I put the filters in again and the cel came on again. I think the codes that are caused by both are the same.
Old Apr 17, 2013 | 04:24 PM
  #68
animal_63518's Avatar
2008 E63, 1997 BMW 318ti
having same problem on e63 with shifts and bucking, k&n's with charcoal delete
Originally Posted by Higgs Boson
I had some KNs and I tried installing them three times. Each time I would put them in, about 4 starts later I would get a CEL, it would shift wrong and buck as I rolled into the throttle. Each time that happened I would reinstall the stock filters and the symptoms would go away and then the CEL would turn off as well. The trans shifts off of torque request logic which is ultimately derived off the MAF signal, so if it doesn't like the airflow vs maf hz then you are screwed.
I threw the KNs away.
It seems like some of these cars have a wider tolerance for fuel trims than others. Not sure if it is a variation in operating systems in the ECUs or what, but there are some that can run filters with no issue. Just the luck of the draw I guess.
Old Apr 19, 2013 | 03:40 PM
  #69
so afe dry filters are around $80 each???
Old Apr 19, 2013 | 03:54 PM
  #70
mthis's Avatar
Anything W/4Wheels
Check it out guys
My filter collection plus 2 other sets I thru out k&n and stock set.
C63 AFE Filters / Charcoal Delete-b8433813-a63b-4e62-8537-2937c0788b00-1265-00000186b46e390b.jpg
Old Apr 19, 2013 | 04:16 PM
  #71
johnnyblaze's Avatar
CLS63S
I ran K&N's and they didnt throw any check engine lights for me, but, after my mods I ran into a hesitation problem on the dyno and while driving under gradual acceleration. After talking with Serge at Benzworks again we decided to throw back in the stock filters. The car is actually running stronger than ever without any bucking.... Should I jump right back into some aFe's?
Old Apr 19, 2013 | 10:37 PM
  #72
mthis's Avatar
Anything W/4Wheels
If you do. Get the pro 5r. They are oiled but they are better more air flow.
Old Apr 21, 2013 | 10:33 AM
  #73
Rippin'AV's Avatar
2008 ML63 AMG
So I removed my charcoal filters about a week ago and then a CEL came on. I took it to the dealer and they told my the same story about the intake manifold leaking. They cleared the code and will need to order parts, etc. In the meantime my aFe dry S arrived and I installed them...and the CEL pops up again. Not sure if it's actually the manifold or related to the charcoal/aFe swap. They never told me the actual codes. Drives just fine.
Old Apr 22, 2013 | 04:07 PM
  #74
Rippin'AV's Avatar
2008 ML63 AMG
So after driving it all weekend with the CEL on this morning it didn't come on. Have driven it a couple of different times throughout the day and stays off. I'm guessing it has something to do with the charcoal/aFe filter mods and not the intake manifold leak like the dealer was saying. I'll keep an eye on it but for now I'm CEL free!
Old Apr 22, 2013 | 06:16 PM
  #75
SROC276's Avatar
2010 C63 P31 AMG
I've seen it happen before...just need to make sure filter and box is seated flush...any offset could throw it. Car adaption too to more air could mean your car may have "learned" recently. I would disconnect batter and do a hard reboot. This helped with my transmission shifting issue when I have a tune applied.
