C63 AMG (W204) 2008 - 2015
mixed tire brands in front and rear?
Old Mar 23, 2013 | 12:23 PM
Paculdo's Avatar
06 CTT-S
recently visited the dealership and my SA pointed out that the rears needs to be replaced soon.. since getting this CPO in July 2010, i've got 6500 miles on them. SA said they don't carry the Hankooks, but they do have Continentals and Pirelli's (I'm guessing Pzero?), anyways, does it even matter if i have the Hankook's on the front and another brand of tire on the rear?
Trying to see if I can use a wider rear than the 255 that I currently have.. by the way, the car is lowered (H&R coil overs) so not sure if going wider would rub?
Old Mar 23, 2013 | 12:56 PM
drawde's Avatar
2009 C63
you should be fine mixing tires as long as they're the same.. both fronts the same, both rears the same i think.
I'm not lowered so I can't help you there but I've run 275 PSS and Conti rears on stock 18" rims with no issues (at stock height though).
Old Mar 23, 2013 | 01:27 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
U can mix tire brands no problem. Make sure they are on the correct position if they are uni-directional.
U can definitely go up to 275 w/o rubbing on ur H&R drop.
Old Mar 24, 2013 | 10:24 PM
justthebest's Avatar
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
Don't buy tires from a dealership - better service / warranty from Discount Tire in my experience.
Old Mar 24, 2013 | 10:35 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
Vulcantire.com also has great prices on tires. They're the only place where I can find Vredesteins. If you're not tracking the car, then mixed tires are fine. Any reputable wheel shop should be able to mount and balance any tires for $50/each or less.
Old Mar 24, 2013 | 10:41 PM
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
I know it's okay to mix tires as indicated, but I like my tires to match on my cars. I like my socks and shoes to match too, .... just a personal thing.
Old Mar 24, 2013 | 10:45 PM
I like matched tires too, but with certain setups, there are only certain sizes for front or rear. At least until the mfg'ers catch up.
Old Mar 25, 2013 | 08:14 AM
MRAMG1's Avatar
S600, GL450, GLC 43
I have mixed tires sine the 80's with no issues. Hell, my audi right now has Continetal DWS's up front and Pirelli's on the rear.
The ONLY thing that could happen is on washed out roads, think truck bumps from heavy braking areas, the car may seem to wonder a little more.
Hell, I have even raced on radials and biased plys before. Long story but still very effective at the autocross. Hoosiers front, BFG's rear.
