C63 AMG (W204) 2008 - 2015
Wheel Spacers for Our Cars
Old Jun 26, 2013 | 05:01 PM
  #76
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Originally Posted by olszowa12
You can try out the spacers with 40mm bolts
Khmergod - yes, you definitely should. Do both the front and rear wheels on one side of the car with the 10 bolts you have, and check both for wheel clearance and interference with the parking brake mechanism on the rear. If the wheels spin freely, lower the car and drive it SLOWLY so you can see the stance and check for rubbing.
Old Jun 26, 2013 | 06:21 PM
  #77
khmergod's Avatar
2011 P31 C63 2015 CLA45
lol! I would love to, but will just wait for the other bolts to come in so I can have them done all at once at the shop. I drive 45mins just to get there :P
Old Jun 26, 2013 | 06:24 PM
  #78
olszowa12's Avatar
'08 C63 Estate
Just do it yourself !!!
Old Jun 26, 2013 | 06:28 PM
  #79
khmergod's Avatar
I might just do the rears first. Will that be ok? Or should I do all of them at the same time? It's funny how 3 weeks ago Matt sold me cf mirrors. 3 weeks later I'm just about done with all the mods I'm willing to do on the car....
Old Jun 26, 2013 | 06:46 PM
  #80
Diabolis's Avatar
+1.
Instead of paying a shop to do it for you, buy yourself a decent 1/2" torque wrench and a deep 17mm socket and you're good to go. Plus, you'll now be able to re-torque your wheels when the time comes!
Old Jun 26, 2013 | 06:59 PM
  #81
khmergod's Avatar
I know of the socket, but...don't know much about wrenches and how do I know if im putting enough force? Say 130nm or 96ft lb?
Old Jun 26, 2013 | 07:11 PM
  #82
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
the torque wrench has settings for various forces. you set it to 96 ft/lb, for example, and when that pressure is reached, the wrench "clicks". that's what that clicking sound is when people use a torque wrench.
Old Jun 26, 2013 | 07:17 PM
  #83
Diabolis's Avatar
You set it to the value you want, and when you hear the click, you stop pushing.
Old Jun 26, 2013 | 07:22 PM
  #84
Diabolis's Avatar
I am pretty sure the owner's manual has a section about putting on the spare tire if you get a flat. It's not any different. Plus, I am sure you can google it or ask someone to help you out if you've never done it before.
Old Jun 26, 2013 | 07:29 PM
  #85
khmergod's Avatar
I've changed spares before, but it was just usually for a short period and made sure the lugs were snug and got a new tire within a day at a tire shop. They do the rest of course.
Old Jun 26, 2013 | 07:40 PM
  #86
ok, i just lost all respect for you. lol, *KIDDING*!
it's really a simple process, and i'm sure there are youtube videos showing you exactly how to use a torque wrench. i totally understand why you wouldn't want to touch your car if you arent familiar with these things, but it's pretty simple. plus, you don't want to have to drive 45 minutes to the shop again when you decide to either take the spacers off or change them to a thinner size. give it a shot!
Old Jun 26, 2013 | 08:27 PM
  #87
khmergod's Avatar
Lastly, I know torque specs for oem is at 96lb. People have run up to 130lb for their oem. What should I run with spacers?
Old Jun 26, 2013 | 08:57 PM
  #88
never thought about that one, good question. i'd ask world motorsports, they may have an answer.
Old Jun 26, 2013 | 10:23 PM
  #89
Diabolis's Avatar
96 ft lb is equal to 130 Nm. If you actually tighten the wheel to 130 ft lb, you will either strip the bolts or stretch them to the point where they wont' be able to provide the required structural integrity, or alternatively warp the hub and/or strip the threads in the holes in the hub. 130 ft lb is WAY too much torque. I think you're probably just mixing up your Imperial with SAE units.
Old Jun 26, 2013 | 10:31 PM
  #90
khmergod's Avatar
I'll stick to 100lbs for spacers to be safe
Old Jun 26, 2013 | 11:06 PM
  #91
Diabolis's Avatar
Khmergod:
Why the hell would you think that over-tightening your wheels bolts would be safer than properly tightening them to what they should be tightened at???
Old Jun 26, 2013 | 11:37 PM
  #92
khmergod's Avatar
Originally Posted by Diabolis
Khmergod:
Didn't think the 4 extra lbs would be that detrimental
Old Jun 27, 2013 | 12:15 AM
  #93
Diabolis's Avatar
It's not about the amount, but rather the concept of over-tightening. If you know what the application calls for (96 ft lb) and you have a way of accurately measuring it (torque wrench), why would you *knowingly* stretch and weaken the metal regardless of how insignificant the amount is? Do you want your bolts to break and your wheels to fall off?
Yes, the extra 4 ft lb amounts to less than 5% of the proper value so it is very unlikely that it would damage anything, but again, why do something that you know is wrong if you can just as easily do it right? Contrary to what you may think, over-tightening a fastener is certainly NOT safer than tightening it to the proper value. Torque wrenches exist for this very reason.
Old Jun 27, 2013 | 01:34 AM
  #94
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Do it yourself bro, I'm not a DIY type of guy (cuz I don't have much time) but switching tires is pretty simple & important to learn in case of emergency.
All u need is a floor jack (don't recommend using the OEM jack), torque wrench & the right socket depending on what lugs u r using. And yes, 100lbs will not harm ur vehicle, I also put 100lbs with my spacers for peace of mind.. But don't put 135lbs, u r asking for troubles. Lol
Old Jun 27, 2013 | 11:27 AM
  #95
khmergod's Avatar
Have any recommendation on a good jack, and jack stands? OEM is wobbly and funky lol. I do not like using it.
Old Jun 27, 2013 | 02:25 PM
  #96
noodleman's Avatar
2014 E63S Wagon
i bought a two ton jack from costco for around $100 and it does the job well!
Old Jun 27, 2013 | 04:35 PM
  #97
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Harbor freight (if you have one in your area) have some pretty good deal as well on floor jack and jack stands. I bought mine from them.
Old Jun 27, 2013 | 06:25 PM
  #98
bhamg's Avatar
C63 AMG
Get something like these...what is your life/health worth?
http://www.uniquetruck.com/p-6376-3-...FUGk4Aod0gIAXA
Old Jul 12, 2013 | 10:01 AM
  #99
khmergod's Avatar
I've got my 15mm F and 10mm R spacers. 10 40mm bolts and 10 43mm bolts. Lug wrench and torque wrench. Do I need anything else?
Old Jul 12, 2013 | 10:05 AM
  #100
Diabolis's Avatar
A jack to raise the car, and a beverage of your choice to consume AFTER you've put them on yourself!
