"Check Coolant Level" - Take to dealer or DIY?
While I think it's silly to have to schedule an appointment and be without my car for the better part of a day for something that is going to take them only a few minutes to find & fill, I also know that documentation is crucial if I end up further down this path and need to make a warranty claim related to the head bolts.
My plan right now would be to buy coolant from my dealer, keep the receipt, monitor what the loss rate is, and actually drop it off if the message comes back up.
Thoughts?
If your car however is out of warranty, I suggest you still bring it to the dealership for assessment and get a second opinion on a reputable German Car Repair shop. This way you know for sure if their assessment are aligned that, that is really the problem (head bolt issue). Hopefully it is just a seal or a lose radiator cap gap. Good luck!
The OP simply needs a little coolant. It happens.
Put some in (himself, not the dealer) and forget it.
If he has the headbolt issue (extremely unlikely), he'll know soon enough.
Right now all he needs is some coolant. That's it.
What's next? Tire pressure down a few pounds means a cracked wheel?
A little common sense please everyone.
2. Low levels of coolant has been correlated to the headbolts going bad. Would you rather him chance it and have a headbolt snap while he's driving?
3. He's still under warranty; why the hell wouldn't you get it checked out?
4. Low tire pressure can mean there's a slow leak in the tire. What are you going to do? Fill it up with more air and hope it goes away?
To the OP, I would rather have it taken in and have peace of mind rather than always wondering if there is a problem.
Just add the coolant and move on. Being doing this for all my MBs every year for the last 10+ years...
2. - If you are constantly loosing coolant, that is a different story and does indicate a problem.
3. - Because you will be billed for any non-warranty related diagnostics/service.
4.- Get the gage and check the tire pressure. Compare to what is specified and if it is the same, might indicate issue with tire pressure sensor so take it in. If you are just loosing air, this will be a non-warranty issue so get an empty spray bottle, put a little dishwashing soap and top-up with water, inflate the tire to around 60 psi. Spray all around the tire - bubbles will indicate where the air leak is...
Igor.
I remember taking the cap off the tank whike it was warm and it was under pressure... not sure how it would pressurize with a vent tube attached?
I am sure. There is actually a valve on the venting hose and this is why you saw the pressure. Remember that there are no radiator cups on many vehicles so valve is on the hose. It is a bit more complicated than that, but there is a venting hose 100%.
Check out the FAQ sticky, spend some time reading the headbolt threads, but you may want to brace yourself for a long road ahead.
