C63 AMG (W204) 2008 - 2015
2012 Steering Wheel - Buttons and Paddles Not Working
Old Dec 18, 2013 | 12:37 PM
olszowa12's Avatar
'08 C63 Estate
I installed my new 2012 steering wheel yesterday and the buttons and paddles don't work.
I don't get any error on the dash.
Now, I remember that Adrian had a problem when installing his C63 steering wheel in his new CLS63 - the problems where the same.
https://mbworld.org/forums/c63-amg-w...ing-wheel.html
I have a feeling that the steering wheel I bought is a CLS steering wheel and not a c63 one.
Does anyone know how I can check this? I took the whole steering wheel apart and i can't find the damn part number.
Thx in advance
Old Dec 18, 2013 | 12:41 PM
zibby43's Avatar
'20 GLC300 SUV
I also think it could be the CLS wheel.
I have never seen a stitched airbag cover on a '12+ C63.
Old Dec 18, 2013 | 12:58 PM
olszowa12's Avatar
'08 C63 Estate
The OEM leather stitched airbag was bought separately in Germany.
Old Dec 18, 2013 | 01:06 PM
Faris63's Avatar
'13 CLS63 PP
I believe they're all the same steering wheel but it need to be programmed by STAR
I like the leather stitched airbag. Is it a whole airbag or just airbag cover replacement ?
Old Dec 18, 2013 | 01:09 PM
olszowa12's Avatar
'08 C63 Estate
I don't want to reprogram the car for the steering wheel to work because I know it should work plug&play.
I'll send you a PM about the leather airbag. I have too extra ones for sale
Old Dec 18, 2013 | 01:35 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Hey what have you done with your OEM wheel?
By the way did you change your steering column?
Old Dec 18, 2013 | 01:46 PM
olszowa12's Avatar
'08 C63 Estate
My carbon steering wheel is sitting the garage as backup for now.
I haven't changed the column because it is only needed to get the buttons lit.
I don't need that so I just wanted to refresh the interior with a new steering wheel but with buttons and paddles that work...
Old Dec 18, 2013 | 01:51 PM
abcut973's Avatar
Let me know if you sell your original CF wheel. I might be interested
Old Dec 18, 2013 | 01:53 PM
Kaiba's Avatar
AMG
Indeed you need to change the column for the buttons to lit up but it is strange that even the paddles don't work !!
You sure you reconnected everything correctly ? As far as I remember you have one wire for the buttons and another wire for the paddles.
Old Dec 18, 2013 | 02:07 PM
olszowa12's Avatar
'08 C63 Estate
Abcut, I will let you know when I'll decide to sell it
All of the plugs are connected properly. Everyting should work, so my only solution is to find out whether the steering wheel came from a C63 or a CLS63.
But I don't know where to find the part number
Old Dec 18, 2013 | 02:45 PM
abcut973's Avatar
No problem Matt.
I remember a member had the issue with the paddlles and it turned out to be the connection ends that were swapped on the wheel. Did you check that already?
https://mbworld.org/forums/5383443-post16.html
Old Dec 18, 2013 | 03:22 PM
olszowa12's Avatar
'08 C63 Estate
No this is not the case.
The paddles came with the steering wheel so they are from a 2012 as well.
Old Aug 5, 2017 | 02:40 PM
AMG3.2's Avatar
C63 AMG, P30
I'm going to bump this -- I just installed a new wheel myself, and I can't figure out why the paddles and buttons aren't working.
Anyone have some insight? I can't think of a reason it shouldn't work without a different steering column.
Old Aug 5, 2017 | 07:01 PM
FCPEuro's Avatar
Former Vendor of MBWorld
Mercedes
The steering column shouldn't influence anything however the steering column module at the front of the column could. What vehicle did the wheel come from?
Old Aug 6, 2017 | 03:02 AM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
Just a thought. Don't all major parts start with an Axxx as in A204? The PN on the wheel should tell you where it came from.
Old Aug 6, 2017 | 11:31 AM
AMG3.2's Avatar
C63 AMG, P30
That's what I thought too. I'm not sure what exact car it came from. Either another W204 or a CLS most likely.
Well for some reason, some parts on these wheels even when equipped with on a w204, still say A172 on them...
Long story short, ended up swapping the chip and all works. Great DIY found here:
https://mbworld.org/forums/c-class-w...heel-swap.html
Old Aug 6, 2017 | 11:58 AM
A172 suggest to me it came off a second generation SLK.
Old Aug 6, 2017 | 05:19 PM
AMG3.2's Avatar
C63 AMG, P30
It very well could have, but I just checked my WIS, and they actually have a section that lists "AMG Wheel Retrofit". That wheel and airbag begins with an A172 Take a look:
Old Aug 6, 2017 | 06:29 PM
As always the devil is in the details. It says model 204.2 which I am guessing is FL with option codes 238, 476, 442 and 803 (2013). From this I conclude that all factors have to be present. Just a guess but we know all cars are not created equal when it comes to MB.
