C63 AMG (W204) 2008 - 2015
ESP Sport- 2010 (video)
Old Mar 2, 2014 | 06:44 AM
AMG893's Avatar
2010 C63 Estate
Exclamation ESP Sport- 2010 (video)
Okay guys, compare these 2 videos.
First one is of a Feb 2010 Built C63. Note the location icons and message for ESP Sport & ESP Off.
Second one is of a Jul 2010 Built C63. Note the word "SPORT" and the location of the icon for ESP off.
Can anyone confirm, if the Feb 2010 can be software updated to the Jul 2010, so the words "SPORT" appear when in ESP Sport mode?
Thanks for your input.
Old Mar 2, 2014 | 10:08 AM
chrisridebike8's Avatar
'10 C63
Wow. I didn't know there was a difference. I hate that huge triangle. I'm curious as well.
Old Mar 2, 2014 | 10:18 AM
MagasC63's Avatar
2009 c63 AMG
This is interesting. Can anyone confirm if this is possible to update.
Old Mar 2, 2014 | 12:39 PM
AMG893's Avatar
2010 C63 Estate
The crap thing about the location of the triangle, and blinkers for that matter, is they are blocked by the steering wheel.
Obviously, this depends on your seating position. But at a comfortable seating position for me, its all blocked. Grrr.
AMG893's Avatar
2010 C63 Estate
Plus, "SPORT" looks better
Old Mar 2, 2014 | 05:33 PM
roadtalontsi's Avatar
10 C six trizzle
I dont think it can be updated to that. It's probably a different cluster. My 2010 does like the first one. I'll see if there is an update for esp and the cluster to see if it changes anything though. later this week that is.
Old Mar 2, 2014 | 11:08 PM
AMG893's Avatar
2010 C63 Estate
Excellent, please report back
Old Mar 9, 2014 | 10:26 PM
AMG893's Avatar
2010 C63 Estate
Any news?
Old Mar 16, 2014 | 11:16 PM
AMG893's Avatar
2010 C63 Estate
Any revelations?
Old Mar 18, 2014 | 12:55 AM
tfthach13's Avatar
'09 C63
I really doubt that a software update can change the location of the indicators. I'm certain the instrument clusters are different. It wouldn't make sense to have both indicators available on the cluster and not have one lit up. It would be unecessary.
Old Mar 18, 2014 | 04:56 AM
AMG893's Avatar
2010 C63 Estate
You have a good point, but it was worth asking
Old Mar 26, 2014 | 10:19 AM
AMG893's Avatar
2010 C63 Estate
Okay, i swapped the clusters over, between the two cars above in the video.
Worked perfectly. My "older" 2010 carried over the "SPORT" light from the "newer" 2010.
BUT- the odometer wasnt showing. It just showed ------- as the reading. I didint drive anywhere, and only started the engine for a minute or so. The tacho worked, and all the menu's worked etc.
If i were to get another cluster, how would i go about putting my cars KMS on the cluster? Would it auto populate after driving around the block? Or would it have to be coded?
Anyone?
Old Mar 26, 2014 | 01:07 PM
Mort's Avatar
Ii think you best touch base with a dealer. They will need to verify your current cluster and set and certify your new cluster. If you don't there may be no end to the pain caused by having a car with unverifiable mileage. Better safe than sorry.
Old Mar 26, 2014 | 06:25 PM
AMG893's Avatar
2010 C63 Estate
Hmmm..... your probably right.
I will update thread when i do it....
Thanks!
Old Mar 27, 2014 | 02:57 AM
clichere1's Avatar
W205 C63S E.1
Anyone?
I swapped my cluster too and saw different signs than I used too but everything is working normal. I used to have MPH speedo, I swapped it with KM speedo, no need to program anything, just plug and play.
regarding the odo , I got the same dashes -------- , this one needs to be programed for the new cluster, also double check the tire pressure option in the cluster, you might find that the TPMS is not found message. This is because it need to be identified to the new cluster. I think you might need to pay a visit to the stealership.
For temporary use of the odo, you can do the following:
after driving the car around, switch the car off, open the door
don't press any button, the cluster will show you that you need to take the car key, wait for almost 1.5 to 2 min, then you'll see the your current trip odo, wait a little longer, you'll see the dashes flips back to your current odo.
I tried it, it's working
check this, it might help:
https://mbworld.org/forums/c63-amg-w...ph-speedo.html
Old Mar 27, 2014 | 12:07 PM
AMG893's Avatar
2010 C63 Estate
But what Odometer does it show? The reading that was ORIGINALLY on the car, or the Odometer of the donor cluster?
Please clarify that.
TY
