C63 AMG (W204) 2008 - 2015
M4 dynos at 424whp and 425wtq :O
Old Jun 28, 2014 | 03:32 PM
  #176
zibby43's Avatar
'20 GLC300 SUV
Originally Posted by unagi1
You mean if the C63 doesn't go into limp mode and the wastegates on the m4 don't close all the way?
I think both cars are evenly matched and depending on the track, weather conditions, drivers it can go either way.
I agree.
The W205, on the other hand, should spank both the W204 and F80/F82.
And it will humiliate the E9X.
Old Jun 28, 2014 | 03:34 PM
  #177
Ingenieur's Avatar
C63 AMG
I did read your post -- EU spec numbers may or may not be relevant to US spec based on # of modifications to pass DOT regs (weight-based or not). For that, I tend to go with the US numbers as a starting point. Not saying #s are totally off just need to be taken with a grain of salt.
The US numbers include the 75 kg
Subtract it, it equals the type weight
DIN/EC are pretty strict, base car <3400 lbs as BMW touted in their press release
US option car <3500
Even at that close to 500 lbs
The op claimed BMW underrated the car, actual is 480 hp & 495 lb ft
500 lbs lighter
Better balance
Wider tires
LSD
DCT with launch control
Yet slower to 124 mph
Either way it's really no faster straight line than a 507 or PP C63
Old Jun 28, 2014 | 03:37 PM
  #178
Ingenieur's Avatar
C63 AMG
The M4 should beat it easily on the track
It ran 7:52 at the 'Ring
That's 10 sec faster than a 507
Same driver
Old Jun 28, 2014 | 06:57 PM
  #179
unagi1's Avatar
'14 C63 507, '11 C300, '96 Cobra, '91 Mr2
US option car <3500
500 lbs lighter
Better balance
Wider tires
LSD
US specs don't typically include passengers, do include 100% fuel, typical options seen on 30% of built cars.
What is the point of typing, and how many of us here weigh 68 or 75kg
No additional info on conversion to US spec -- best bet is to go with US specs in order to ensure apples to apples comparison IMHO
Old Jun 28, 2014 | 07:33 PM
  #180
Ingenieur's Avatar
C63 AMG
BMW NA uses the EU spec
It includes the 75kg
Been doing so since the e36
Scale weighed cars have confirmed this
Look at the data plate
Subtract max load from gross vehicle wt GVW
C63 = 4872 - 848 = 4024 lb
It is DOT requirement
We can tell the same from the M4 plate
Old Jun 28, 2014 | 07:43 PM
  #181
Ingenieur's Avatar
C63 AMG
Scale weighed by sportauto
As a result, the BMW M4 Coupe tips the scales at 1,497 kg while the M3 Sedan stands at 1,520 kg in base specification. These weight savings have been achieved through the ...
M4 3293
M3 3344
There is 2 ways to make a car faster
Add torque
Reduce weight
Hopefully the w205 C63 will be trimmed to 3800 at least
Old Jun 28, 2014 | 10:52 PM
  #182
Ezec63's Avatar
C63 Coupe
I meant a stock m4 vs a headers, tune, exhaust c63 as the poster mentioned. A stock m4 vs stock 507 should be a close race.
Don't think the m4 won't go into limp mode either like the 335is was known for. Or blow a high pressure fuel pump that plaqued n54 and n55. It will also have to worry about not heat soaking it's air to water inter cooler ;-) which the new gen m5's have known to do and lose performance the more times they hot lap.
Good thing i have black series oil and trans cooler, thermalnator gaskets to separate my manifold and head, carbon fiber intake box and scoops that are gold reflect taped on bottom to reflect heat, speed driven trans pan that holds another 1.5 quarts of oil and has cooling fins. Think i have limp mode in check :-p
Old Jun 28, 2014 | 11:16 PM
  #183
alexmtl's Avatar
2013 C63 coupe P31
http://f80.bimmerpost.com/forums/sho....php?t=1003735
More dyno and weight info. Another M4, another dyno, very similar results. The real-world weight of the M4 is 3579lb with 1/2 a tank apparently.
Old Jun 29, 2014 | 12:22 AM
  #184
unagi1's Avatar
The modded c63 will have the edge as long as it puts out power well beyond 507 territory, but truth is c63 will lose the mod race without s/c -- all the m4 guys need to do is crank up the boost and control IATs, and they win.
Sounds like everything on the M car is covered except the wastegate sticking. I had that and then HPFP failure. Then, there's the time I launched the 335i in the air and snapped the serpentine belt, then limped into the dealership as the battery died...and the time I cracked my m6 rep winter wheel in half...but I digress.
Sounds like you have limp mode in check! I'm liking how you used gold foil to reflect heat -- that always works well
Attached Thumbnails M4 dynos at 424whp and 425wtq :O-dscn5270.jpg   M4 dynos at 424whp and 425wtq :O-img_3280m.jpg
Old Jun 29, 2014 | 12:34 AM
  #185
Ezec63's Avatar
C63 Coupe
Check out my build thread ! I have MBH headers, x pipe, full exhaust, renntech 82mm throttle body, full cf intake, weistec TCU and valve body upgrade, 2 piece
Rotors(40 pounds of rotational mass) plus a bunch of other goodies. I agree it's going to be hard to keep up with the m4 staying N/A and cost significantly more but if you do supercharge the sky is the limit JRcart ran 9 flat in the 1/4 mile and trapped over 155 on some runs so there's more potential. The one thing the m4 will have is being able to go fast for relatively cheap (down pipes, exhaust, intake, tune +e85) and it'll dust 99% of c63's out there for cheap. I'm not a fanboy it def is an amazing car. Let's see what the AMG boys do with the next c63 !
My bro in law had a modded 335 n54 and it was fast for relatively cheap but also had a lot of problems hopefully the M doesn't go down the same path !
Limp mode is def in check !!! Took a boat load of $$ but hey now I can enjoy the car to the max and beat on it like I want to !
Old Jun 29, 2014 | 10:37 AM
  #186
Ingenieur's Avatar
C63 AMG
0-124 mph
There is less than a second between a 2009 non PP C 63 and a new M3
A better comparison, 4 doors each
It is impossible for a car:
That is lighter by at least 10%
More hp 451 vs 480+ according to the dyno
More torque 443 vs 490 or so
Better tranny
More tire
Better wt dist
To be this close
The PP runs the same as the M
The 507 is faster than the M
Same driver, magazine, test location and methods
Old Jun 29, 2014 | 10:48 AM
  #187
Ingenieur's Avatar
C63 AMG
Here's a dyno test from sportauto
They hire an independent testing agency rototest
It is a PP C63
Rated 487 hp or 358 kW
Exactly what is measured after losses
And they actually MEASURE losses
Mfgs do not rate the power, an independent 3rd party does using very exacting methods
The days of the late 60's and under-rating are long gone
Old Jun 29, 2014 | 11:37 AM
  #188
JumpinJim's Avatar
SL63
It is a PP C63
Nobody is listening, nobody cares what sportauto made up. They're wrong. They're off on weight by 200 lbs. They're obviously incompetent.
Old Jun 29, 2014 | 12:35 PM
  #189
slfmde's Avatar
Segway
New M is a beast.
Old Jun 29, 2014 | 12:41 PM
  #190
Ingenieur's Avatar
C63 AMG
Originally Posted by slfmde
New M is a beast.
What's that make the 507?
0-124
M4 13.7
507 13.4
An Audi S6 will run with either
Chip it and it smoke them
Old Jun 29, 2014 | 12:44 PM
  #191
Ingenieur's Avatar
C63 AMG
They weighed the car
As did the EC testing agency
As did BMW whomust be incompetent, hell, they can't even rate the hp correctly lol
It's eas who is suspect
480/490 3500 lb car running only 12.1/119
With dct and launch control augmented by an electronic lsd
0-124
507 13.4
M4 13.7
Lol
Old Jun 29, 2014 | 12:48 PM
  #192
solekeeper's Avatar
A V8
well, if someone gets a chance to run the m4 please post results.
Old Jun 29, 2014 | 12:52 PM
  #193
Ingenieur's Avatar
C63 AMG
What does the gen of GTr-35 with the same power and torque do the 1/4 in?
Say 480-490 hp and 490 lb ft
It weighs like 4000 lbs
Mid 11's 123-125 range?
Old Jun 29, 2014 | 12:59 PM
  #194
CarHopper's Avatar
E63S | X5
0-124
M4 13.7
507 13.4
I don't think the S6 is in the same category though.
Should be something like this:
M3/4 vs S4 vs C63
M5 vs S6 vs E63
Old Jun 29, 2014 | 01:09 PM
  #195
Ingenieur's Avatar
C63 AMG
M3/4 vs S4 vs C63
M5 vs S6 vs E63
Agree
Sad we don 't get the RS6 a REAL beast
How can the m4 with more power (485 vs 481) and torque (490 vs 443)
Weighing much less
Dct
Wider tires
Only be 2/10 and 2 mph faster
The PP is ~ the same as the m3 at 12.2/117 and it is much lighter
BMW fumbled this one
2009 amg c63 pp
DIMENSIONS:
Wheelbase: 108.7 in Length: 186.0 in
Width: 70.7 in Height: 56.3 in
Curb weight: 3992 lb
C/D TEST RESULTS:
Zero to 60 mph: 3.9 sec
Zero to 100 mph: 9.1 sec
Street start, 5-60 mph: 4.3 sec
Standing �¼-mile: 12.3 sec @ 117 mph
Top speed (governor limited): 174 mph
Old Jun 29, 2014 | 01:18 PM
  #196
CarHopper's Avatar
E63S | X5
While we don't get the RS6 you can still get an RS7.
I don't understand the logic with cars that aren't sold here. Any performance wagon would make so much money here... C63, RS wagon, M5 wagon, CLS wagon, etc etc etc. So many people in the states rave about wagons.
If an RS6 was sold here I would sell a kidney and a ********.
Old Jun 29, 2014 | 01:34 PM
  #197
Ingenieur's Avatar
C63 AMG
The RS7 is nice but can't really get on board with the swoopy fastback look
Imho one of the best cars that never made it here
BMW e36 euro
< 3100 lbs
321 hp wide torque band 7200 rpm
6 TB's race car like response
6 sp manual
Compound brakes
Some say 190 mph car
Amazing handling, perhaps its strongest suit
In the early 90's tto boot !!!
A real sleeper
We got a watered down version
In this country you can almost anything
I think they do it to mess with us lol
" you can't have the good stuff" lol
Old Jun 29, 2014 | 04:27 PM
  #198
JumpinJim's Avatar
SL63
0-124
507 13.4
M4 13.7
Lol
Sportauto has never even seen an M4 let alone weighed or tested one. BMW lists the weight at 3585 which is right in line with what people weighing actual real cars come back with. You know, people who actually have them as opposed to wishing they had one. Sportauto has no credibility as they've been proven they can't get something so simple correct. I'll wait for a real review from a credible source instead of a car tabloid. Odd that none of the respected car review magazines have anything out yet, but sportauto has stuff out weeks ahead of time. Yeah, that doesn't pass the smell test.
Old Jun 29, 2014 | 04:45 PM
  #199
Ingenieur's Avatar
C63 AMG
if you can't be trusted on whether sportauto tested one every thing else you say must be dismissed out of hand
really? http://www.sportauto.de/heft/sportau...4-8398591.html they ran around the 'Ring in 7:52
sportauto is THE benchmark, unlike US rags who are full of hyperbole and short on substance
who do you like, euro tuner?
0-124 mph the 507 is faster despite being much heavier, having less tire and torque and no dct...pathetic
a US magazine got 12.1/119 and 12.2/117 M4/M3 this months motor trend...if you call that respectable...basically the same as an C63
despite having more power/torque and weighing much less, lol
BMW UK
Weight
Unladen (EU) (kg)
1572 [1612]
EU/Germany:
1. Leergewicht EU ( Car with 90% fuel, 68kg driver, 7kg luggage (75kg). Latest EU definition uses only driver @ 75kg )
so 90% fuel and 75 kg load
1612 -75 = 1537 or 3381 pounds
the sportauto car had cf brakes and forged wheels (I don't think they are standard) probably a little lighter
Old Jun 29, 2014 | 05:05 PM
  #200
Ingenieur's Avatar
C63 AMG
sportauto does real tests
dyno
wind tunnel
etc.
so far superior to anything US mags do that it is not even comparable
not to mention the driving skill of the testers: Horst von Saurma runs times comparable to Porsche and Nissan factory race/test drivers
here's the test for an AMG C63 PP see for yourself
http://www.sportauto.de/supertest/me...t-5212033.html
actual wind tunnel data!
front/rear lift force, area and Cd
Fahrzeugstirnfläche: 2.190 m² Luftwiderstandsbeiwert: 0.29 Luftwiderstandsindex: 0.64 Vorderachse: 34 kg Auftrieb Hinterachse: 27 kg Auftrieb
0-200 km/h:13,7 s
M4...exactly the same 13.7
exactly
actual dyno with measured losses
