C63 AMG (W204) 2008 - 2015
Just changed Differential Fluid
Old Jul 12, 2014 | 01:00 PM
JRHolt's Avatar
2024 GLE 63 S AMG SUV
Hey Everyone,
Just changed the differential fluid in my 2014 C63 AMG Coupe 507. As most of you know it is due initially at 2,000 miles for LSD differentials. It has 2,500 miles on it right now so I decided to do it today.
Doing it myself it cost me about $60.00 and about an hour of my time. A lot cheaper than taking it to the dealership and I know it is done right I have trust issues with other people working on my stuff, guess I am a bit meticulous
It is very easy to do and just about anyone should be able to tackle it themselves. You need a 19mm wrench for the plugs if anyone was wondering.
The fluid was pretty dirty and had a lot of particulates in it that looked like clutch pack material and possibly some material from the initial gear break in so I am glad that I did it when it was due.
I purchased the fluid at ECS Tuning. That is usually where I purchase all of my Mercedes parts
Old Jul 12, 2014 | 01:37 PM
AMG893's Avatar
2010 C63 Estate
Pic? Tools used? ie- pump? etc?
Old Jul 12, 2014 | 02:08 PM
shades's Avatar
09 C63, 11 Cayenne S
It's a drain and fill application, no need for a pump. Always loosen top first just in case it's seized...you don't wanna open the bottom bolt to find out that you can't get the top bolt out, this is just good practice. now open bottom bolt and drain. If you want, you can re-use the bolts, which most people do, or you can purchase new ones. Put the bottom bolt back in and torque it down to spec, open top bolt and fill until it starts to drip from the top and close it up and torque to spec. I believe it 1.2 or 1.5L to fill, so buy 2 liters. 75w140 synthetic. No need for funnels as usually the bottle has the application to fill in the bottle. Easy as that my friend
Old Jul 12, 2014 | 10:44 PM
JRHolt's Avatar
Really? Maybe you should not try this yourself
Old Jul 12, 2014 | 10:46 PM
Ingenieur's Avatar
C63 AMG
Old Jul 13, 2014 | 01:50 AM
AMG893's Avatar
2010 C63 Estate
Thanks for the info.
Sound very straight forward.
As for the other comments, I asked because I have heard of others only having one bolt at the top/ side and having to pump the fluid out, and needing a pump it back in.
So, this one sounds pretty straight forward.
Old Jul 13, 2014 | 08:31 AM
Gadget's Avatar
06 E55 AMG, 13 C63 AMG
Did the fluid you use include the LSD additive?
G
Old Jul 13, 2014 | 11:46 AM
Mort's Avatar
G
The correct gear oil is complete and no additive is required.My manual calls for Fuchs Titan EG 5010 D but in NA the OEM gear oil seems to be Castrol Syntrax Limited Slip 75W-140 and what I got from the dealer with a MB parts label on it.
Old Jul 13, 2014 | 01:35 PM
Ingenieur's Avatar
C63 AMG
http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/FD7AF0C21FF00DE280257AD3003FBE1B/$File/PDS%20CCSA%20Castrol%20Syntrax%20Limited%20Slip%20 75W-140%20english.pdf
Oem for lsd on AMG and BMW M
Old Jul 13, 2014 | 02:29 PM
unagi1's Avatar
'14 C63 507, '11 C300, '96 Cobra, '91 Mr2
It's a valid question -- 2 of the trans' I've done the fluid on have the side fill method. Picking up an extra bottle or two in order to flush out the factory fill fluid is not a bad idea either.
Old Jul 18, 2014 | 09:00 PM
Gadget's Avatar
I changed the fluid in my LSD diff today.
Picked up three little bottles (.5L) from the dealer for $45.
The little bottles have a built in snout that pulls out and it is perfect for filling the diff.
Takes 1.2 quarts/liters so I had some left to throw away.
Very simple job.
G
Old Jul 18, 2014 | 09:12 PM
Ingenieur's Avatar
C63 AMG
Good post
That should answer all questions
Looks very straight forward
Old Feb 1, 2015 | 01:46 AM
HBC350's Avatar
'18 C63A Cabriolet
Very simple job.
G
Crap. I paid the dealer $200 for a drain and fill? Stupid me.
Old Feb 1, 2015 | 07:06 AM
shimbibby's Avatar
2010 C63
Does this also apply to the aftermarket LSD options? Just had a wavetrac lsd installed last week, so will I also have to do the 2k mile oil change?
Old Feb 1, 2015 | 08:17 AM
odonnks's Avatar
Ford Truck, 2014 C63 AMG 507
I was told no but I'll wait for other responses.
Old Feb 1, 2015 | 08:34 AM
rentzington's Avatar
2010 C63 P30
Great post....because it just reminded me I need to change the lsd fluid in my truck Hah
Diff fluids probably easier than an oil change even because no filter to mess with
Old Feb 1, 2015 | 12:58 PM
Thrilla's Avatar
Veteran: Army
2014 C63 AMG 507 sedan
Thanks for posting. This will come in handy in a few weeks when I do mine.
BTW, what's the torque spec for the drain and fill bolts?
Old Feb 1, 2015 | 08:13 PM
dubzAMG's Avatar
2010 C63 AMG FBO, 2014 E63 AMG S
No you don't. OEM lsd is a clutch type,as it breaks in you get clutch material mixing in with the gear oil. Wavetrac is a gear type lsd.
Old Feb 2, 2015 | 12:36 AM
bhamg's Avatar
C63 AMG
My Wavetrac fluid was changed out at 10k miles. The original Motul Competition fill appeared to have few if any metallic particulates so I would say you can safely follow Wavetrac's recommendation that the fluid need never be changed.
Old Feb 4, 2015 | 12:06 PM
JRHolt's Avatar
The torque is 50 Nm which is about 37 Ft Lbs
Old Oct 3, 2015 | 04:16 PM
RobV_C63's Avatar
2010 C63 AMG
ok, im new to the MB world so don't hurt me hahaha...how do I know if I have the LSD or not?
Old Oct 4, 2015 | 09:49 AM
Mort's Avatar
Look up the Datacard for your car. It is option code 471. Valvestud will look up the datacard for you if you post your vin in one of the threads or PM him.
Old Oct 4, 2015 | 02:09 PM
unagi1's Avatar
Step A: do a burnout
Step B: Come back and inspect tire tracks.
If you have only one dark line, you don't have LSD.
Old Oct 4, 2015 | 02:47 PM
RobV_C63's Avatar
2010 C63 AMG
Haha unagi1, that would be the definitive answer, I was just looking for a way around that. Thank you though
Old Feb 24, 2016 | 02:54 PM
jmueller's Avatar
Jag F-Type V8
Did you replace the drain and fill plugs with new ones? I have read that the service manual calls for replacing them, but the dealer often does not do this. I cannot for the life of me find the plug online.
