C63 AMG (W204) 2008 - 2015
Using space saver rim and tyre at the drags
Old Aug 3, 2014 | 11:26 PM
RNS-11Z's Avatar
09 C63
Who had actually done this?
Did you notice any difficulties at high speed?
Did you use the factory tyre or replace it with a normal high speed tyre?
H
Old Aug 3, 2014 | 11:35 PM
C63-AMG's Avatar
2009 C63 2016 AMG GT S
I was actually looking this up as well. I would replace the factor tire with something rated for more speed. I use to do this with my Mustang that was running in the 10's @136MPH
Old Aug 3, 2014 | 11:50 PM
Merc63's Avatar
C63 AMG
The idea behind a skinny is less weight. Pretty sure that spare is quite heavy.
I realize you will save some rolling resistance, but I think weight is the big thing.
You will 100% want to run a tire rated for speed with that, the factory donut is not rated for high speeds.
Do yourself and fellow racers a favor, get a proper tire for it or stay off the track, last thing someone needs is a guy plowing into their door at 100mph.
Old Aug 3, 2014 | 11:51 PM
Bardman's Avatar
C63 AMG 507 Edition
Semi related and a little bit funny:
Old Aug 4, 2014 | 02:00 AM
charliekay's Avatar
C63 AMG
The space saver spare w/ rubber is 31lbs, which is 20lbs less than the stock 18s w/ rubber (50lbs).
Good weight saving there but you will need proper front rubber.
Also, might be an idea to remove the stickers and plastidip the wheels to look like proper front runners as ANDRA rules have banned the use of space savers for drag racing.
I have wanted to do this for a while but I am still unsure of how good an idea it is.
Old Aug 4, 2014 | 05:39 AM
betrezra's Avatar
C63 507 AMG DA Car #19
Bad idea. There is more et/mph to be gained from rear traction,launch technique,and driver imho.
Old Aug 4, 2014 | 11:15 AM
Merc63's Avatar
C63 AMG
**** 20lbs less, that is pretty damn good, I thought it was heavy.
I'd give that a whirl with a proper tire.
Old Aug 4, 2014 | 01:43 PM
EkS's Avatar
EkS
C63
It's been done!
Old Aug 4, 2014 | 06:07 PM
CarHopper's Avatar
E63S | X5
Just get CCW skinnies and tires rated for that speed.
Are you going to get down the track? Yes.
Are the gains of saving 20lbs worth the risk of losing a front tire at 120mph on a track? No thanks.
