C63 AMG (W204) 2008 - 2015
Steering wheel
Old Aug 15, 2014 | 05:29 AM
ClivePratt's Avatar
2013 c63 amg coupe, 1994 porsche 928GTS, 1988 e430
Steering wheel
Does anyone know if a 2013 steering wheel will fit the earlier model c63 2009
Old Aug 15, 2014 | 09:05 AM
charliekay's Avatar
C63 AMG
Yes it will work but if you only replace the steering wheel then the buttons won't light up. You need to replace the steering column - part number A212 900 7702. Once you replace the steering column everything will work 100%.
Old Aug 15, 2014 | 09:21 AM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
It will as mentioned above. You need the E class steering column cover to get the button lit
Old Aug 15, 2014 | 05:49 PM
ClivePratt's Avatar
Thanks for the replies, so does everything else work except the lights in the buttons, if I don't change the column, and is it the complete column or just the top cover with the electrical connections that need replacing
Old Aug 15, 2014 | 05:50 PM
abcut973's Avatar
Just the plastic top cover. It is plug and play.
Old Aug 15, 2014 | 09:50 PM
ClivePratt's Avatar
ok, so just to get this straight, when I search that part number it is the switch assy and clock spring a2129007702 is that what I need or is it just the clock spring that has all the connections, the round center section
Old Aug 15, 2014 | 10:24 PM
abcut973's Avatar
This is what i bought. That part number listed above didn't work for me:
Old Aug 15, 2014 | 10:42 PM
ClivePratt's Avatar
Thanks gain abcut973 and others that replied, I too was having trouble with that part number, I am in Australia so maybe they are different part numbers, pictures are great, I was not sure if it was one assy. i came up with 20790033009051,
Old Aug 15, 2014 | 10:59 PM
ClivePratt's Avatar
one more question, there are two different switch assy,s listed one with memory and one without, I believe this is for seat memory, how does this affect the steering wheel?
Old Sep 5, 2014 | 10:26 PM
ClivePratt's Avatar
Hi Guys, so I got my new 2013 performance pack wheel and air bag for my 2009 c63, bolted on fine, air bag fine,,,,,, none of buttons on the steering wheel work, no horn either, thought it might be a dud so I put it on my 2013 c63 and everything works,,,, so I guess I have to get the steering column switch assy, anybody else had this problem, I know a few said it is plug and play, not in my case
Old Sep 5, 2014 | 11:21 PM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
If you do the facelifted steering wheel you must buy the new airbag. Instead of buying the plastic airbag- you should opt for the nappa leather airbag from the R231 SL (same shape). And while you're at it, get the aluminum trim that says "AMG" on the bottom instead of "Airbag" that the C and E assemblies have.
These are the part numbers:
Airbag: 231 860 19 02
AMG Silver trim: 099 464 23 13
Old Sep 5, 2014 | 11:40 PM
ClivePratt's Avatar
thanks for that, but that does not answer my question, I already have the air bag,
read previous post
Old Sep 5, 2014 | 11:45 PM
abcut973's Avatar
Did you change your top cover as well with the E class one?
That is what will make the buttons lit.
Old Sep 6, 2014 | 01:12 AM
ClivePratt's Avatar
thanks abcut973, I have not changed the top yet, my main problem is that, none of the buttons work, what year model cover did you get for yours,
Old Sep 6, 2014 | 05:45 AM
Anatoli's Avatar
E500 estate
Column numbers:
- without cruise control, without Memory: A212 900 7703
- without c c, with Memory: A212 900 8103
- with c c, without Memory: A212 900 7502
- with c c, with Memory: A212 900 7702
All parts for sedan, not estate!
Estate has different parts cause of the back wiper.
Steering wheel:
There are two different kinds of steerig wheels.
One (Code 802) is working without the column, only no button lights.
The other need the column, otherwise the steering wheel will not work.
No button, no paddles, no lights, nothing!
So check your steering wheel and the right column number
Old Sep 6, 2014 | 01:29 PM
black lavender's Avatar
R8, C63, C300
Just reading the replies, it seems like a costly venture.
I'd rather put that money into a carbon fiber wheel.
Old Sep 6, 2014 | 01:49 PM
snowmuch's Avatar
C63 AMG
Subbed for future reference
Old Sep 6, 2014 | 06:43 PM
ClivePratt's Avatar
Thanks anatoli, that was the info i was looking for, I guess I have the other steering wheel, part no is a17246047039g90, its a performance pack wheel.
it works fine on my 2013, the 2009 has mem and cc, so it looks like a2129007502,,,can you tell me what holds it to column please,
thanks to all the others that comented
Old Oct 8, 2014 | 02:17 PM
torjan's Avatar
E200 CDI - w212 - 2010
Recently I bought a new steering wheel for my E class W212.
I found a good deal for W264 steering wheel, it is the same for the 2014 facelift E class.
Part Number:
Steering wheel: A246 460 1503 9E38
Airbag:A246 860 2602 9E38
I didn't try to change the steering wheel for now, as I saw many people has a problem with light.
Now my question if I buy the steering wheel Column, do I need to just exchange them, or I need to recode with A star
Old Nov 7, 2014 | 06:52 PM
ClivePratt's Avatar
hi again, so I finally got the steering column switch assy, a2129007702. it looks the same as the old one, when installed I still have the same problem, nothing on the steering wheel works, I can see where you plug the wheel to the column that there are 2 pins missing, so this is not the right part number, my next option is to swap the column switches from my 2013 to 2005 and see if that works, very frustrating as I now have a switch assy bought at great expense which is useless to me
Old Nov 7, 2014 | 06:56 PM
ClivePratt's Avatar
I meant swap the switches from my 2013 to my 2009, typo
Old Nov 7, 2014 | 07:50 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
get this! :drool:
Old Nov 7, 2014 | 08:03 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Wow, sounds like a lot of problems just to upgrade the steering wheel.
Old Nov 8, 2014 | 07:49 AM
AMG893's Avatar
2010 C63 Estate
Clive, where in Syd are you?
Old Nov 8, 2014 | 04:36 PM
ClivePratt's Avatar
sent you a pm AMG893
