For you tire gurus...
When I replace them I will go 235/265
The 245 affect turn in and straightline stability imo
The fronts are also 0.4" taller,(same goes for the oem set up) the 235 will make them the same
I was looking at the Michelin PSS, 245/35/19 are 25.8", and 265/35/19 are 26.3", so there won't be any ESP/handling issues right? Interesting that the new C63 goes with this combination? Albeit the new C63 I image has a different suspension setup...so you wouldn't recommend this setup? Also, I'm using OEM wheels.
235/35/19
255/30/19
Correct?
Can you get a 265/30/19 rear?
That way the height difference ratio stays the same
Oem fronts are bigger
Your set up makes the rears bigger
Honestly should not matter either way
Make sure you get XL's
The load ratings should be > oem so you can lower pressure a bit
Anyway, no those are just fine for size, and yes you can put them on your stock wheels and be fine. You won't have any ESP or handling issues.
The load ratings are 93 (vs 91 oem) and are XL, air down a couple psi
The ratio F/R are the same as oem
The ratio is probably more important than overall diameter
But the diameters are within 2% anyways
Good to go
