Wife's C63 Issue
Her car used to pop and crackle on slow downshifts from 3rd to 2nd gear in M mode at approx 40km/h.
I've noticed that's disappeared now. And just gurgles.
Had the car checked for air leaks (exhaust) just in case it's losing back pressure but they only found a tiny hole and it was rectified. It's still not crackling and popping like it used to.
Even in C and S mode it used to crackle, pop etc when it automatically downshifted through the gears especially at low speed from 3rd to 2nd.
Now it used to pop and crackle for a good 6+ months and has just stopped over the past few days.
Could it be the fuel?
I know it sounds stupid, but any insight would be good, as i'm worried it may be leading to something more serious.
1. Turn the ignition key to the "on" position which is just before you crank the engine to start.
2. Press the accelerator to the floor and hold for 5 seconds.
3. Then turn the key to the off position but do not remove the key, then release the accelerator.
4. Wait at least 5 minutes, the ECU is then reset.
The ECU rest procedure only erases the adaptive transmission and throttle settings. It does not erase any of the fuel, timing or other programming.
- Put your car in D3.
- Using heavy throttle, run past 5k through the three gears.
- Brake with a heavy foot.
- Repeat, perhaps four or five times.
- After that, test your adaptations by hard braking as if you were bedding pads, say from 70-10 mph.
- You should feel two quick downshifts accompanied by backfires and burbling.
All i want is to be able to restore the crackling and popping that's seemed to have vanished.
You engage S mode.
After driving and the car is in 3rd gear (S3) flatten the throttle.... Go through S3, S4, S5 and change at redline or above 5k.
Brake, then repeat about 4-5x.
Then test it by braking hard from a high speed to low speed and it should drop down two gears?
Do i need to do anything with the key, reset etc?
Or do i just simply go for a drive and do this?
You engage S mode.
I drive in M mode most of the time and so does my wife. I tried it a few times.
Is the car meant to gear down on its own in M mode when you're braking?
