C63 AMG (W204) 2008 - 2015
WHEEL OFFSETS and SIZES???
Old 04-09-2015, 01:00 AM
Huchimo01's Avatar
2013 C63 AMG and 2002 Ford Explorer Sport
Hey to all,
I am now on the lookout for wheels and tires for my '13 C63, and have a few ????. First I want to go to 19" wheels. I am looking at MRR, Niche, Forgestar, and others. However I don't know what the offsets are, so was hoping someone here had that info.
I am also looking at tires as well. Looking to go from the 235/40-18 fronts to 235/35-19. Rears from 255/35-18 to 255/30-19. I saw the 2015 C63 has 245/35-19 front and 265/25-19 on the rear. Would the 265/25-19 fit on the rear of the 2013, or is it just too wide? I hate having smaller tires on such a beast, and they really aren't as meaty as I would like. I don't want them outrageous, but at least a 265 series would be nice to have.
ANy thoughts. I was reading in a couple of recent mags that the 2015 C63 had the Michelin Pilot Super Sports, and the tester thought they were really loud. I have owned Michelin Pilot Sports and they weren't loud, and my buddy who owns an M5 loves them. Of course he owns the tire shop and he is a hard core BMW and Michelin fan. This car came with Continentals installed, but I do like the Michelins. Any insight would be greatly appreciated.
So it's really down to the wheels and what the offset is, and then I can go with the tires. I am particular in that I don't want the wheels sticking past the inner lip of the wheel arch. Just looks cleaner to me.
Thanks to all and any input on wheels is also welcome. I'm not going to spend a ton of money on the wheels, meaning thousands because in all honesty-I ain't got it. I want quality with reliability. Let's start with that first.
Cheers,
Howie
Old 04-09-2015, 02:54 AM
GRP
GRP's Avatar
2010 C63
Do a search as the subject has been done to death or even better pm Roswell for the answers.
You can go 10" on the rear with a 50/52 offset and fit 275/30/19.
Michelin Pilot Super Sports would be easily the most regularly recommended tyre in the C63 forum and is my preferred option.
Old 04-09-2015, 10:18 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Yes go PSS all day any day.
Tire size will depends on wheel offset. But for sure our cars needs 35f & 30r profile tires in 19's.. Dunno where u saw 265/25/19 on a C63? Maybe 265/25/20?
Well try maximizing the tire size by choosing the right offset.
For example:
Front: 19x8.5 or 19x9 from +40 to +45 is recommended with 245/35/19 no problem
Rear: 19x9.5 or 19x10 from +48 to +55 is fine for 255/265/275 .. xxx/30/19.
Good luck in ur search.
Old 04-09-2015, 10:33 AM
Mukd's Avatar
2013 C63AMG Sedan
Roswell,
I also had similar offset question as was planning to upgrade to vff103 19" from my stock rims and I went through the forum but found all kind of offsets and tyre sizes used by various members.
Vorsteiner gives following standard offset.
Front – 19” X 8.5” standard with a 45 offset
Rear – 19” X 9.5” standard with a 46 offset
U think they would give a flush look to the fenders or I would have to add spacers ?
I am also looking to drop it with the H&R springs !
Cheers
For example:
Old 04-09-2015, 11:48 AM
Roswell's Avatar
19x8.5 +45 will fit nicely with 245/35/19, but it won't be maximum flushness. U can do +40 by adding 5mm spacers.
Keep in mind 5mm spacers don't come hubcentric, so u might have vibration. I would do 10mm hubcentric (making it +35) & run narrower tires like 225/35 or 235/35.
As for the rear, 19x9.5 +46 will be as flush as u can get. I would recommend 265/30/19 tires though if u plan on lowering. 275/30 will definetly rub. Well at least I was rubbing lol
Old 04-09-2015, 11:49 AM
avery.whss's Avatar
S550 on order
I have 20" Vorsteiner VS-160 with a +52 offset running 285/25 in the rear..I think it's 10 or 10.5 wide using Falken FK453's
Yes it's flush
Attachment 445248
Zero spacers, no lowering, just chucked them on and drove off.
tai rahmaad (10-03-2020)
Old 04-09-2015, 12:02 PM
Mukd's Avatar
2013 C63AMG Sedan
Vorsteiner is only offering me +45 front offset on pre order (annoying) I can get both 235/245 tyre option but I think 245 is not needed and it's like adding additional weight to the car and I am sure how it would affect the handling!! But as you said 235 would need spacers with a different offset (which are not offered)
Also,I am based in india and it's very hard to get 265/30/19 profile Tyres and instead we get 265/35 and 275/30/19 as u said 275 lowered would definitely rub!
What do u reckon I should do?
Thanks !!
Old 04-09-2015, 12:13 PM
Roswell's Avatar
Yes it's flush
Love ur car Avery! Any rubbing at high speed over bumps? I was rubbing on the passenger rear when I had 275 +50, ur 285 are wide. Lol
Old 04-09-2015, 12:15 PM
Roswell's Avatar
Thanks !!
265/35 is too tall of a tire. I would go 275/30 & forget about lowering.. Or look for another set of rims with +50 & up in the rear.
Rolling fenders is also an option to avoid rubbing.
Old 04-09-2015, 12:19 PM
avery.whss's Avatar
S550 on order
thanks man and no rubbing thankfully only if i go up a super steep drive way ..did yours rub constantly on the pass rear? - you're lowered too right?
I had a set of 295's on in the summer to try for about a month and didn't have to many issues there either it's just a pain finding that tire size
if i were to re-do it again i'd probably just go with a nice set of 19's and a bit thicker of tire so tread life was a bit longer
Old 04-09-2015, 12:24 PM
Mukd's Avatar
2013 C63AMG Sedan
Thanks a ton for your advice, will definitely keep it in mind .. Looking at few other wheel options as well now!
So u recommend a +35 front with 235/35 and 10mm spacers +50 up for rear with 275/30 without lowering for flushed look and no rubbing !
Cheers
Old 04-09-2015, 01:19 PM
Roswell's Avatar
Avery, my car is lowered & my wife with my son always ride in the back seat so yes I was rubbing a lot going bumps.
Funny part is now I run wider wheel (19x10 +50) with 275 PSS & no rubbing. Must be the stretch of the 275 on x10 vs x9.5!
20's looks amazing on our cars but I agree on running 25 series tires is a pain. Plus 20's tire selection are limited & expensive.
Old 04-09-2015, 01:28 PM
CarHopper's Avatar
E63S | X5
Avery,
I normally don't like 20's but I think you car looks quite nice on them. What were your thoughts on the Falken tires?
Old 04-09-2015, 01:29 PM
Roswell's Avatar
Cheers
No for the +35 & 10 mm spacers. I was referring to the Vorsteiner wheel u asked about at +45. I suggested to add 10mm (+35mm) spacers if u want them flush as 5mm (+40mm offset) doesn't come hubcentric.
Old 04-09-2015, 01:35 PM
Roswell's Avatar
Sorry if I'm confusing u guys , my English is not that good.. Lol
Well keep the offset in front from +35 (with stretched tires) to +45 , the ideal offset is +40 for nice flushness and wide tires combo.
Old 04-09-2015, 01:59 PM
Mukd's Avatar
2013 C63AMG Sedan
Got it bro, and rear offset with 275/30 ??
Old 04-09-2015, 02:21 PM
Roswell's Avatar
+48 to +55
Old 04-09-2015, 02:22 PM
avery.whss's Avatar
S550 on order
Originally Posted by PurpleHeartAMG
Avery,
thanks! and they are great i've had them for 2 sets now and they've been lasting around 8,000 KM on the rears, they hook up good though i really like them
Old 04-09-2015, 07:06 PM
SPONSOR
SupremePower's Avatar
GT3RS, 356, Raptor, M2, Sprinter 4x4
Ran 20x10 +50 285/25 on this client's car lowered on H&R Springs and had Zero rub even with passengers:
Old 04-10-2015, 04:19 AM
Huchimo01's Avatar
Sorry my goof. I pushed the wrong button. It should have read 265/35-19. Anyway, I don't want to go overboard on the wheels and tires. Just take it to 19's and install the PSS all around. I don't want any radical offsets, but I don't want the wheels sticking out past the outer lip of the wheel arch.
Some great looking wheels some of you have. I'm on the fence with a couple of wheels, and will post once it's all done. Thanks for all of the assists.
Cheers,
Howie
Old 04-10-2015, 04:24 AM
Huchimo01's Avatar
Hey GRP,
Do you have any other images of your car with the Forgestars? I am looking at those pretty closely, but would like to see a different angle. Looks sharp.
Old 04-10-2015, 04:32 AM
Huchimo01's Avatar
Thanks Roswell,
First I don't believe in using spacers so not an option for me. I am looking at 235 tires on front, and maybe 245 if they will fit. No more than 265 on the rears. I just want an offset that keeps the wheels within the wheel arch and not go past the lip. Do you know offhand what the stock offsets are on the 2013 C63 18" wheels?
Cheers
Howie
Old 04-10-2015, 07:22 AM
Roswell's Avatar
18x8 +45 & 18x9 +54
As I said, try to stay close to +40f & +50r on ur aftermarket 19's & u will be golden.
Old 04-10-2015, 09:36 PM
GRP
GRP's Avatar
2010 C63
Originally Posted by Huchimo01
Hey GRP,
The images below should give you a good idea of fitment. Forgestar CF10s 19 x 8.5 ET 40 and 19 x 10 ET 52 running PSS 245/35 and 275/30.
Old 04-10-2015, 10:07 PM
Huchimo01's Avatar
Hey GRP,
And with those sizes you don't have any rubbing issues at all? I would have thought with a 10 inch wide wheel and 275 tires there would be some rubbing. You haven't lowered the car either? They look about as good as a set can get from my point of view. I saw a really nice Red coupe with HRW's on it that just rocked. I think this might be the way to go, although I am not sure about the 10" wides on the back. I don't want to use spacers-did you use them?
Cheers,
Howie
P.S. Where did you get the wheels? What did you pay for the set?
Quick Reply: WHEEL OFFSETS and SIZES???
