w205 amg steering wheel retrofit possible?
Yeah, if you already own a C63, I don't see it being worth the money or hassle. Of course, I don't see the attraction to change out a PFL for a FL wheel.
Once after getting all cmponentes for installation I have been annoyed.
It turns out that we have the 5-speed gearbox, we can do the installation of the steering wheel with paddles, because you can not activate.
I had previously read, that if they could install, but to review the information before making the installacion, I have seen that only can be installed in the gearbox 7-speed.
Go depecion !!
I have a 2007 (pre-facelift W204) C-Class sedan. My car is manual and does not have cruise control.
If I buy the steering column from one of the late facelift models (as the one pictured above), will I have any issues with my car as I think cruise control was standard to all facelfit models (i.e. error messages, etc.)?
Moreover, as most used steering wheels have paddles for the automatic gearbox, would that be a problem for my car and the retrofit in general? Or I need to buy one without the paddles to avoid any issues?
Thank you.
Therefore, to summarise what I read from other topics included in the forum, we need a steering column with the following part numbers to get a fully fuctional wheel :
W212 PFL / W204FL Column: A212 900 7502 / 7702 - W204 Facelift Wheel
or
W212 FL Column: A2129007923 / 3415 - W205 Wheel & W204 FL Wheel
Is that correct? Is there additional coding required (i.e. SCN) or everything is plug and play?
Will post my findings soon.
That wheel in you picture is the standard version wheel. Most go for the sport or AMG version.
Since you have the new steering column you will onlu ned a airbag and a wheel. But make sure it is a wheel with arrows on the left buttons or it will not work.. But finding one in that color will probebly be close to impossible if you dont buy it all brand new.
Do I also need to buy contact plate/control module?
And please explain me why there are two versions of steering wheel, with/wihout arrows on the left side. Are new models W205 also with these kind of steering wheels that have arrows or it is only for people who wants to upgrade w204 steering wheel with w205?
Thanks in advance.
Are the w205 control buttons fit plug and play to the w204 facelife connections ?So the facelift w204 owners need only the steering wheel, control buttons and the new w205 airbag or?
NO and I mean NO W205 have arrow version. If you buy a W205 wheel you will need all electronics repalaced by for example CLS electronics.
Just installed mine but my Airbag left front one has an error (I’m assuming the steering wheel). Has anyone had any experience getting a dealer to do an Airbag sensor reset or where to get it done? If you’re in LA that would be even more helpful!
now I have no paddles and my steering column is the old style one
My car w212 pre facelift 2009
The wheel I bought
The existing steering column I have
