C63 AMG (W204) 2008 - 2015
Eurocharge V6 wishlist
Old Aug 4, 2015 | 10:51 PM
  #76
roadtalontsi's Avatar
10 C six trizzle
420whp is more than respectable with just a tune from a 6.2L N/A engine going through an automatic transmission. Some people dont realize that dyno's can be manipulated to read whatever their heart desires. People really think that with a tune only they are knocking on 500whp door. Just ask them what the E.T. and trap speed are on that magical dyno.
Old Aug 4, 2015 | 11:46 PM
  #77
Eric ATP's Avatar
2012 C63 P31 black/black
100% agree. Be realistic.
Show me the slip.
In any case it is a great car is a great car.
Old Aug 5, 2015 | 12:30 AM
  #78
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Yeah, agree with the above. What I'm more curious about is the before/after same day, same dyno, same conditions. That's not about making the dyno read whatever you want it to. If one is the 'before' line, and one is the 'after', it looks like you lost torque and gained insignificant power. That's what doesn't look right.
Old Aug 5, 2015 | 08:47 AM
  #79
Eric ATP's Avatar
Those are back to back runs after the tune. I was not even going to put in on the dyno but was at the shop checking on a buddies progress. Every dyno I've ever pulled on we do 2-6 pulls to get consistent numbers. It was way too hot/humid and Baro was low to get top numbers on a NA car. I was just there and curious so we strapped the car down and did a couple pulls.
No where did I say those where before and after as they would not be on the same chart. I wIll do some stock to tuned runs but I'm going to wait till this Fall for more favorable weather conditions. The dyno in Marrietta also has been there a long time and the numbers are pretty consistent.
Multiple runs the lines will NEVER line up.
Old Sep 20, 2015 | 04:41 PM
  #80
ENV²'s Avatar
2001 Porsche 911 Turbo (heavily modified)
nothin yet on v6 release? I am wondering if mine is running lean. Need to know how to tell
Old Sep 20, 2015 | 04:57 PM
  #81
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
You can insert an OBD dongle and monitor air to fuel ratios via your cellphone.
Old Sep 20, 2015 | 05:07 PM
  #82
ENV²'s Avatar
Really? Any links to which are some good ones?
Old Sep 20, 2015 | 05:30 PM
  #83
Wobble64's Avatar
I using this one:
Amazon.com: ScanTool 427201 OBDLink LX Bluetooth: OBD Adapter/Diagnostic Scanner for Android & Windows: Automotive Amazon.com: ScanTool 427201 OBDLink LX Bluetooth: OBD Adapter/Diagnostic Scanner for Android & Windows: Automotive
Use a Bluetooth version for Android and Windows phones, and a WiFi Version for iOS.
You should not see AFRs higher than around 12.8 under full load. If you do see 13s or 14s, you are too lean. Note: Those kinds of values are Ok at minimum throttle.
Old Sep 20, 2015 | 07:19 PM
  #84
ENV²'s Avatar
I using this one:
Ordered thanks. If I am running to lean, what do you suggest? Should I reach out to EC and ask them to work on custom changing the tune?
Old Sep 21, 2015 | 06:32 AM
  #85
Wobble64's Avatar
I thought I had posted a response yesterday, but don't see it here, so here I post again:
I doubt the EC tune is the issue. They have many cars out there running successfully and the AFRs are regulated also with the O2 sensors you have. If indeed you are running too lean, then there is something wrong with the car most likely (for example a leak in the air intake). I would get the data with your OBD scanner first and take it from there.
Btw, if the basic app that comes with the dongle is too simple, you can also try Torque or DashCommand. They offer a bit more functionality. I personally have all 3 but end up using Torque the most.
Old Sep 21, 2015 | 09:28 PM
  #86
ENV²'s Avatar
Excellent, thank you. I have RoW boxes I am hoping they arent causing lean conditions.
Old Sep 22, 2015 | 08:05 AM
  #87
Wobble64's Avatar
I also have ROW boxes and ran EC tunes in the past. They are no issue as the air flow sensors are measuring actual air mass. If there was a leak after those air sensors, that would let additional air in, that could be an issue.
Old Sep 22, 2015 | 08:49 PM
  #88
ENV²'s Avatar
So I got the scanner on the software that came with it reported all good marks on all tests. Torque had 2-3 areas with red but I am not sure if that just stuff it cannot read, etc I dont know what the strange values mean and there are no explanations next to them.
On the other OBD app it showed 1 misfire on 2 different cylinders on one of the cylinder reads but not on the other. These apps are hard to understand but it still showed green check marks across the board.
Also no fault codes on either program
Old Sep 22, 2015 | 10:19 PM
  #89
Wobble64's Avatar
You were concerned about your engine running too lean. In order to check that watch air to fuel ratios while driving under load. They should not be higher than 12.8 under full throttle.
Old Sep 23, 2015 | 06:46 AM
  #90
BLKROKT's Avatar
EC tunes run super fat. I'm in the high 11's and low 12's (11.9-12.4) at WOT in 3rd and 4th. Verified using a standalone dual-bank AFR gauge with dedicated wideband sensors (Innovate DLG-1). Safe as kittens.
Old Sep 23, 2015 | 07:09 AM
  #91
Wobble64's Avatar
Blkrokt, that makes sense. So if someone sees much higher AFRs then someting is not right. And likely not the tune but an airleak.
And if the AFRs are in the right range then the enginee is not running lean.
Old Sep 24, 2015 | 05:36 AM
  #92
Mazspeed's Avatar
C63 amg Custom 67 Camaro GLK 350 4matic 2017 AMG GTS
I bought my V5 tune about 3 weeks ago and asked the sales guy on the phone if and when they were going to have a V6 and he went and asked someone, he came back to the phone and old me they have no plans on doing the V6 tune. He said they had newer cars out they had to do.
Old Sep 24, 2015 | 07:35 AM
  #93
ENV²'s Avatar
Couldnt figure out fully how to read the gauge but I was running around 12-12.7 under WOT but when I let off the gar and hit brakes it would jump to 28 then level back down in the 12 area.
Old Sep 24, 2015 | 09:19 AM
  #94
BLKROKT's Avatar
Well 12-12.7 is a little vague. On one end you're fine, and on the other end you're starting to get into the not-so-fine area. What RPMs are you seeing those numbers at, what gear, etc.
It's normal for the AFR to jump like that when you get off it. On decel it runs as lean as possible. Cruising it fluctuates up and down to keep things around stoich.
Old Sep 24, 2015 | 09:45 AM
  #95
Wobble64's Avatar
That is also how my car is. The 28-30 is just the max reading possible. When you lift your foot off the gas, the car cuts fuel supply completely and coasts. So in theory the AFR becomes infinite, but can only show something like 30.
Running lean is only dangerous at full throttle.
Old Mar 8, 2016 | 12:51 PM
  #96
AMG3.2's Avatar
C63 AMG, P30
Originally Posted by g-f
Don't know if it's possible but I'd like to be able to start in 2nd in M mode.
Originally Posted by Ihopaz
Can we some how figure out how to make the transmission in M mode actually shift when you pull the paddle!
A little more power like 560hp and also increase the torque 20lb/ft
Stay in M or S mode after shutting the car off
Up-shifts can be done at any rpm
A little more throttle when downshifting like a growling rumple
Faster up shifts when in M mode
Start in 2nd Gear
Can you do 2015 Christmas gift? Please!
Would like all of the bolded features.
Old Mar 8, 2016 | 01:28 PM
  #97
IBowlC63AMG's Avatar
2012 C63 Amg / 1999 C43 Amg
I'd much rather be too rich than too lean. I don't know what the point is getting any more aggressive with the tune. I was running AFRs from 12-4-12.8 the other week at The Glen on my street tune, and at redline it was creeping higher than that. That's more than aggressive enough for me and I was on straight race gas - anything more and you're starting to compromise the engine IMO. I don't want to see 13's, it's not worth it to me for a tenth here or there.
And I do have a race gas file in case I'm feeling lucky. Yes, it would be nice to have a better interface. Also agree less gimmicks and sounds, more practicality. Maybe some of the gauges can be changed to show warnings such as knock as mentioned above.
But overall, EC is doing a damn good job for me anyway. We will see when I get her to Atco in a few weeks...
Hey if you dont mind me asking would you mind letting me know when youre headed to atco??? i am from NJ and havent met any other 63 owners though i have seen two thus far on the road since having mine!!! being you have upgrades and mods id just like to see and hear how your car runs etc etc.. if not no big deal....just would like to meet some other owners
Old Mar 8, 2016 | 03:02 PM
  #98
BLKROKT's Avatar
There are a few of us that head down on Friday nights. Will usually post here to try and get a posse going. I will be there the 18th, 19th or 20th weather-depending.
Old Mar 8, 2016 | 03:37 PM
  #99
Thanks man! keep me updated.. ill be looking out for the post!
Old Mar 8, 2016 | 08:36 PM
  #100
Exhibit13's Avatar
2010 c63 (p31) w/LSD
Any updates on when v6 is due to release?
