C63 AMG (W204) 2008 - 2015
broken center vent controls
Old May 31, 2015 | 07:46 PM
rentzington's Avatar
2010 C63 P30
so i have noticed that one of my center vents below the nav screen was stuck in the up position (pointing towards roof) and when I tried to adjust it there was 0 tension it just kept going back into pointing towards the ceiling.
the little slider feels kind of loose and a small little piece was loose and fell behind the vent and I got it out with some tweezers.
Anyone deal with this or know if its an easy fix or does the entire vent have to be replaced (which seems to be both vents as a whole unit)
Old May 31, 2015 | 08:35 PM
mthis's Avatar
Anything W/4Wheels
I had mine snap to.
https://www.parts.com/index.cfm?fuse...3-%20Liter-GAS
what years your car. this is for 08-11
Old May 31, 2015 | 08:39 PM
2010 C63 P30
Originally Posted by mthis
I had mine snap to.
2010
i found the same diagram on OE parts and it seems like youve got to replace the entire center portion not just one vent, is that right?
Old May 31, 2015 | 11:42 PM
roadtalontsi's Avatar
10 C six trizzle
are you kidding me? gdi man you've got bad luck with this car. I'll see what my cost is on this and you can compare to online price. I can pop it in, in about 5 minutes. They do come as a whole assembly. Usually it happens on older higher mileage cars, not usually the c's mostly the cls's. Atleast you finally have your car back just in time for the weather to clear up.
Old Jun 1, 2015 | 06:44 AM
JimmyR's Avatar
E63S
I had a similar problem with my wife's VW Golf but i reckon the design is similar.
It was a simple fix. I managed to pull out just the vent assembly by gently levering it at the edges and pulling the whole vent assembly from the front.
The little piece you have already fished out will be designed to clip into the control knob from behind the central horizontal louvre. There will be 2 little prongs or similar that angle backwards to clip onto the vertical louvre that controls sideways airflow.
Use one of those plastic trim removal tools to pry it from the edges, and from memory I hooked something behind the centre bit to help pull it forwards.
Hope this makes sense.
Old Jun 1, 2015 | 06:53 AM
2010 C63 P30
i noticed it as i was leaving the dealership hah!
odd thing is before i bought it the used car place replaced a vent too.
now i just have to get it re-tuned, cant get the mygenius unit to reset it's stuck in write mode so now we have to wait for this italian holiday to end.
Old Jun 1, 2015 | 06:56 AM
2010 C63 P30
yeah that sounds like the piece that fell out, i'll try and get a picture of it.
i'm betting it can be popped back without replacing the entire thing.
Old Jun 1, 2015 | 08:34 AM
2010 C63 P30
and more into the neverending circle of problems a CEL PO410
Old Jul 21, 2018 | 03:23 PM
Crya's Avatar
2009 C63 P30
My center passenger side vent adjuster just cracked as well, and now same symptom. Coincidentally happened as I was exploring to add a backup camera. So, I'm going to order a new 20483041549116 for $80 when I do my backup wiring. Can anyone post up the WIS for removing the switchgear from the vent unit to swap over?
