C63 AMG (W204) 2008 - 2015
When to replace brake pads?
Old Oct 6, 2015 | 10:18 PM
Cee6three's Avatar
2013 C63 481 stock HP with LSD
Delete thread
Plz delete thread
Old Oct 6, 2015 | 10:20 PM
Cee6three's Avatar
plz delete thread
Old Oct 7, 2015 | 11:39 AM
gogoquadzilla's Avatar
2012 C63 AMG P31
I'll tack a related question onto this:
My wear indicators are squealing bad, but there still looks to be 'enough' pad left and they're not dangerously low yet. When does the wear sensor usually get tripped compared to the indicator tab squeaking?
Old Oct 7, 2015 | 11:43 AM
avery.whss's Avatar
S550 on order
my "cheak brake pads" has been going off for like 3,000 KM (getting the pads replaced this week) but I bought replacements from racing brake for around $500 bucks..front and back
Old Oct 7, 2015 | 12:12 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Originally Posted by Cee6three
Should I wait for the brake pad sensor to go off?
Will I cause damage to my rotors if I wait for the sensor to trip?
When the sensor does go off, approx how much wear do i have left?
5,000km ago I was told I had 20% left on my fronts and 40% left on my rears....so far no sensor signs have shown up
Thanks in advance....
Just check the thickness of your pads regularly.
Are you sure the squealing is due to the indicator or just your brakes squealing for not being at temperature?
Old Oct 7, 2015 | 02:53 PM
Eric ATP's Avatar
2012 C63 P31 black/black
If your tracking your car or need aggressive pads for a reason there are pads for that available. If you want good quality low dust pads and would rather go have a nice dinner buy these. http://www.autopartswarehouse.com/sk...FYKQHwod9HgM8Q
They take about 10-20 min to change out including removing the wheels. Super simple.
Old Oct 7, 2015 | 03:35 PM
Eric ATP's Avatar
Or if you think you can't mentally be ok with $50 brake pads that do the same work you can always just buy OEM for $230 and the sensor for $10.
https://www.parts.com/index.cfm?fuse...cedes-Benz-C63 AMG-Base-V8-6.3- Liter-GAS
Old Oct 7, 2015 | 05:16 PM
2012 C63 AMG P31
Well, I guess not, but it sure sounds like the high pitched squeak of the indicator tab. I guess I can get in there and bend it back and find out. I've never had squeaky brakes before, so I honestly don't know what it sounds like compared to the indicator. I understand some say these brakes can be normally squeaky.
Old Oct 8, 2015 | 09:25 AM
jmueller's Avatar
Jag F-Type V8
My brakes squeel all day long because I rarely can get them up to temperature in traffic. When I give the brakes a visual check, it looks like there is tons of pad left. These brakes just make a lot of noise.
Old Oct 8, 2015 | 06:29 PM
RacingBrake's Avatar
Former Vendor of MBWorld
CLS550
Racingbrake's ET500 is the most welcome performance street compound for C63/E63 and other MB models:
Front:
http://www.racingbrake.com/RB-ET500-.../pd1291-35.htm
Rear:
http://www.racingbrake.com/Brake-Pad.../pd1373-35.htm
Please refer to this review and learn how ET500 keep this SL550 owner so happy.
Racing Brake makes me happy:
https://mbworld.org/forums/sl-class-...ml#post5939978
ET500 will deliver an excellent braking power and modulation, very low dust and no squeak braking that you are looking for or your money back.
Both our front and rear pads equipped with wear sensor locator, just swap the sensors from the used pads - Very easy to install.
Front Pad:
Rear Pad:
Old Oct 11, 2015 | 03:42 PM
shamrode's Avatar
c63 AMG
The sensor needs to be replaced every time the pads are?
Old Oct 11, 2015 | 08:31 PM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
Theoretically you can pry the sensor out of the old pad and reuse it. Practically - many times they crumble when you try to get them out and need to be discarded/replaced.
A new sensor is about 15$ at the dealership and about 11 $ mailorder.
