C63 AMG (W204) 2008 - 2015
Uneven tire wear
Old Oct 14, 2015 | 11:12 AM
Smrtypants36's Avatar
2013 C63 AMG Development Package Coupe
Uneven tire wear
Ever seen this before? Thinking I need an alignment?
Attached Thumbnails Uneven tire wear-photo651.jpg   Uneven tire wear-photo448.jpg
Old Oct 14, 2015 | 01:04 PM
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
Yes I've seen that a few times. No you don't need an alignment. That's expect with negative camber, which performance cars have. You can decrease the amount of negative camber (toward neutral) to get better tire wear, but it may effect handling.
Old Oct 14, 2015 | 01:30 PM
Durban's Avatar
C63, S55, 190E 16V, S600 Maybach, S550, GL550
Are you running stock wheels?
What rediesel said is true, but I would say that if you're stock that seems like a pretty aggressive wear.
Old Oct 14, 2015 | 01:31 PM
johnny--2k's Avatar
2018 GLS 550
The only way you're going to get less camber is with either the bushing kit or the new arms in the rear, it's not adjustable on these cars from the factory. I have the same problem.
How many miles are on those tires?
Old Oct 14, 2015 | 01:34 PM
Durban's Avatar
Agreed. I have a front and rear bushing kit and have noticed a much even tire wear.
Only downside to running a more zero'd out camber is slightly less turning capability but it would be unnoticeable if you're not one who pushes their car as hard as possible.
Old Oct 14, 2015 | 01:52 PM
Thanks everyone. I have only had the car for 7 weeks. Bought it used. It's a 2013 couple with development package. I think they are the original tires, so about 30k miles. The wheels are stock, but I'm not sure at this point if it was lowered. Have to check it out.
Old Oct 14, 2015 | 04:57 PM
Durban's Avatar
Well if they have 30,000 miles on them then thats pretty normal. I had to replace mine after 7500 without the bushing kit. Although my car was probably lower than yours and the rubber is a lot softer. Either way 30,000 isnt bad.
Old Oct 14, 2015 | 05:48 PM
johnny--2k's Avatar
2018 GLS 550
at 30K miles, that's probably the 3rd set, no lie. Don't plan on getting more thatn 7-10K out of a set of rears without the bushing kit and alignment. Even if you drive gentle, plan a tire budget.
Old Oct 14, 2015 | 05:52 PM
Durban's Avatar
sounds about right
Old Oct 14, 2015 | 06:42 PM
Got it. Thanks.
Old Oct 15, 2015 | 01:27 PM
Mort's Avatar
I recommend you get your alignment checked. Your rear toe looks to be off to me. That type of wear is from excessive toe-in more than negative camber. Negative camber will cause the tire to wear across the tread to the inside but will not generally tear up the inner edge of the tire. Also check your tire pressure.
Old Oct 15, 2015 | 02:01 PM
Thanks. I'm brining it to MB tomorrow.
