C63 AMG (W204) 2008 - 2015
Multiple Misfires and car undriveable
Old Jan 7, 2016 | 06:53 PM
Wobble64's Avatar
C63 507 with BS Body; 2008 SLK 55
Had an interesting day today, C63-wise. When trying to leave the house in the morning, the car started and immediately ran terribly. It was shaking, stuttering, was at the verge of stalling and the CEL came on. I turned the car around after 500 feet and limped back to my garage. Took my SLK and drove to work and had Roadside Assistance come and tow the car to the dealership.
Before I left, I read out fault codes and it was a sea of red. 'Multiple misfires', 'misfire cylinder 1', 'misfire cylinder 2', 'misfire cylinder 3', 'misfire cylinder 4' and a couple more. I texted that to my mechanic at the dealership and he then went to work. He found that the driver side cylinder bank exhaust camshaft had lost its homing position and was way off position in the camshaft adjustment. He has no idea why. He retaught the camshaft and all is well again. Just drove the car home and can confirm it is all as before. While he was at it he also checked the plugs and they are good.
This is not very confidence inspiring. They said it is a freak occurrence, which happens. May never come back. Well, I guess I will find out. Maybe a position sensor is about to crap out.
Nothing I can do than keep an eye on it. Long story short: Some hassle, no charge (warranty) and a free carwash.
Old Jan 7, 2016 | 07:08 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Glad that issue got taken care of. But what a misfortune!
Hopefully you'll be good for the long run.
Old Jan 7, 2016 | 07:10 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
How does something like that happen? Weird!
Old Jan 7, 2016 | 08:19 PM
rentzington's Avatar
2010 C63 P30
I've had a freak issue on mine too, and when these cars have an issue its always something bad enough to be undriveable it seems, which I guess is somewhat good since you won't cause more damage
But all I can say is thank god for warranties!
Old Jan 9, 2016 | 06:34 AM
C63amg Tokyo's Avatar
2012 C63 AMG BS, 2010 C63 AMG (sold), 2006 M3 (sold)
Glad to hear it was resolved. I know the feeling though, like not knowing what caused it or if it will happen again. All you can do is keep an eye and ear open, hopefully it doesn't happen again and was just a total freak occurrence.
I had something similar happen to my old m3 and it did stall out. I was afraid to drive it but when the dealer took a look, he said there was camshaft position error and it never happened again to my car for two years and then I sold it.
Old Jan 9, 2016 | 10:53 AM
hansamg's Avatar
C63AMG Coupe
Had same problem and codes on cold start with a 2012. Returned to house , towed it in. All mine required was reboot (restart not a reflash). Has not recurred. If it does I will try just a reboot at home. Like you I was on my way to work, and just jumped into another car and left it sit. Hopefully it is only a cold-start issue and will not occur once we are far from home base.
Old Jan 9, 2016 | 01:31 PM
Wobble64's Avatar
Guys, good to hear this has happened to others and should not happen again.
Yes, it happened when cold. Car runs great again - have maybe 150 miles more on it.
How would I do a reboot? Do you mean disconnect the battery? Was your issue also with camshaft position or something else?
Old Jan 10, 2016 | 02:03 PM
hansamg's Avatar
C63AMG Coupe
Sorry, by reboot I meant only to turn the car off , let it sit a bit and restart. In my situation it sat several hours, while I sped off to work in another car.
Old Jan 10, 2016 | 05:08 PM
Thrilla's Avatar
Veteran: Army
2014 C63 AMG 507 sedan
Warranty
I'm amazed that your dealer covered the issue under warranty with your headers, tune, and BS conversion. Thumbs up to your dealer.
Old Jan 10, 2016 | 05:17 PM
Wobble64's Avatar
Did not even come up. How would a camshaft loosing position error at cold start have anything to do with exhaust, suspension, body, etc? Or even a tune?
They are reasonable and like the car.
Old Jan 11, 2016 | 09:08 AM
cmacclel's Avatar
2014 C63 Polar White
I think you should just be happy you have a great dealer. Some dealers won't touch a car that has any mods. I do agree with your statement but some dealers are just *****'s.
Old Jan 11, 2016 | 02:34 PM
gogoquadzilla's Avatar
2012 C63 AMG P31
I had the same thing happen to me last Tuesday, except I also had fault code 1200, exhaust cam position implausible based on crank position or something like that. Dealer said it's bad gas and they're draining and cleaning it out tomorrow. I'm not sure how bad gas only causes misfires on one bank. Seems more like a sensor or solenoid failure to me, but we'll see.
Old Jan 11, 2016 | 06:44 PM
Wobble64's Avatar
You are right, bad gas us often blamed, whether really right or not. In your case it is probably an excuse or a lets tick this off just in case kind of thing. Hope they will not charge you for it.
In my case they asked me where I had filled up last and it was my customary Shell. They also analyzed the gas and confirmed
