C63 AMG (W204) 2008 - 2015
Brake cooling ducts and modified front bumper
Old Feb 10, 2017 | 05:13 PM
  #101
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
If you're still listening Doug, have a question about tires. I had a thought when looking at your comments for Rob on his thread about modding his BS with HRE P101's.
When I widened my rear fenders, I was able to move up to a 295/30-19 PSC2 on my Vorsteiner VSC101 19x10" ET52 rears. No problem.
At the same time, I went up one size in front to a 255/35-19 PSC2 on the 19x8.5" ET45 fronts. They run wide, and I'm starting to wonder if that might be too much tire. I had mistakenly thought I was working with a 9" wide wheel duh. I think I'm barely outside what's considered 'acceptable' with just over 10" section width on the 8.5" rim.
What do you think? Keep in mind the abuse I intend to create for them on track. Thanks.
Here's what Michelin (Tire Rack) says:
Old Feb 14, 2017 | 02:05 AM
  #102
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Hi Jim,
Sorry for the late reply... just got back from four days of sliding and drifting in various AMGs on ice (w/ custom studded racing tires of course) at Gimli. Few teaser pics below.
For track duty, a PSC2 255/35 is probably too wide on an 8.5" rim, especially on a heavy car like the 63. You'll be rolling over the outer sidewall while the inner one would be folding under the rim. Aside from handling issues, at worst you could pop the outer bead or get a blowout on the inner sidewall where the carcass will fold under. If you were using "greasier" tires, for street driving and on a lighter car you'd be fine, but IMHO you're looking for trouble with this setup. Rule of thumb for track use is that you always go with the widest approved rim size for a particular tire - so for those PSC2s, you'd ideally want 10" wide rims.
Old Feb 14, 2017 | 10:26 AM
  #103
debtinstruments's Avatar
'13 C63
i'll pay you 10x whatever saphgrey is offering on your DRL surrounds lol SHOTS FIRED
Old Feb 14, 2017 | 11:45 AM
  #104
BLKROKT's Avatar
Originally Posted by Diabolis
Hi Jim,
Sigh..... that's what I thought and was afraid of, but was reaching for someone to hopefully say that it wasn't an issue in their experience. Thanks for your valuable input. The 295 is probably a little wide as well. Time to look at dedicated track wheels.... does anyone know what the lead time is on HRE? I think I have to give Wobble a call about the rims he had Forgeline custom make too....
Gimli looks like a BLAST! What cars did you get to drive?
Old Feb 14, 2017 | 01:11 PM
  #105
604 C63's Avatar
2012 E550 Cabrio
We tried to book Gimli, but couldn't get all 4 of us to agree on dates, plus two guys were whining they want to go to Sweden, which was sold out anyways.
Based on the amount of "Cant believe we didnt do it" whining, we will be going next year for sure lol.
Old Feb 14, 2017 | 02:05 PM
  #106
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Ran 255 r-comps on a 9.5" for years on the S2000. Granted, not nearly as heavy but pulled 1.9G in the corners.
Old Feb 14, 2017 | 02:30 PM
  #107
BLKROKT's Avatar
8.5" is a different story
Old Feb 14, 2017 | 03:01 PM
  #108
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Yeah, just mentioned in case 10" is pushing it up front.
Old Feb 14, 2017 | 03:28 PM
  #109
BLKROKT's Avatar
Thanks. I know I can fit a 9" for sure. Probably 10" will take more fender massaging. 9.5" sounds custom? If I can get out to Ohio in the next month, I'll drop my car off with Forgeline to have custom widths and offsets made to get the biggest rim I can in there.
Now I'm nervous about my 295's on the 10" rear too.
Ugh, this sounds like it's going to be expensive.
Old Feb 15, 2017 | 02:52 PM
  #110
SuperFastYo's Avatar
C63 AMG - LSD
just from the video thumbnail of AutoTech Racing's C63 it looks like they removed the foglights for ducts. Ever since I saw this its been something I would like to do (if I had the skills)
Old Feb 15, 2017 | 03:15 PM
  #111
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
Looks more like they mounted a pair of 95mm cannons up there - a great way to persuade competitors to give room to let you pass!
Old Feb 15, 2017 | 03:33 PM
  #112
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
^^^^ AGREE!! Looks killer....!
Old Feb 16, 2017 | 12:22 PM
  #113
Diabolis's Avatar
In terms of tire/rim widths... if the tire fits without rubbing, usually the rim itself shouldn't be a problem assuming that you get the correct offset. And, between a 245 and a 255 where the 255 is mounted on a rim that is too narrow, the 245 will have the same contact patch size (the outer edges of the 255 will essentialy float) AND be considerably more stable and thus faster.
Re Gimli - we had 6 CLS63Ss, 6 C63Ss and 6 CLA45s. The Cs and CLAs were a blast. The CLSs were great for stupidly massive drifts at 140 km/h at an 80 degree drift angle on a huge (~700 m) circle, but they have the momentum of a medium-sized planet. Trying to get them to change direction on one of the tighter tracks is... well, frustrating. Unless you get the speed and drift angle just right everywhere, there's no correcting and you end up in the snow bank. Great learning tools though - they force you to be smooth instead of aggressive (which you could do to an extent in the other two). And, Gimli beats Sweden hands-down for a number of reasons - so much so that next year they're changing the format and track in Sweden to what the Canadian AMG DA was doing at Gimli. Plus, I hear that now Porsche and Lamborghini are coming to Gimli next year as well for thier winter programs.
Old Apr 1, 2017 | 01:05 PM
  #114
BLKROKT's Avatar
Been traveling for work like mad lately, and a lot of new toys have come in. Instead of creating new threads, I'm just going to pile all my stupid projects in here and turn this into my "Track and Stuff Build" thread. Here are some of the related links for reference (some still to be filled in):
Weistec TCU and Trans Pan: https://mbworld.org/forums/c63-amg-w...ml#post6777815
44O Cooling Kit:
Brake Cooling and Front Bumper Mod: (this thread)
RacingBrake BBK: https://mbworld.org/forums/c63-amg-w...their-car.html
Track Tires and Rear Fender Widening: https://mbworld.org/forums/c63-amg-w...ack-tires.html
UltraRacing Underbody Braces:
KW Clubsports and Full KMAC Bushing Kit: (starting below)
DIY Swaybar End Links: https://mbworld.org/forums/c63-amg-w...ncy-power.html
Spoon Rigid Collars: https://mbworld.org/forums/c63-amg-w...ollar-c63.html
Alcantara Dash and Red Seatbelts: https://mbworld.org/forums/c63-amg-w...Alcantara+dash
DIY Morimoto HIDs: [TBD]
Weistec Billet Idler Pulleys: [TBD]
So, here's what needs to go on before Apr 23.
KW Clubsports (thanks to Golan at AutoTalent)
KMAC Full Bushing Set - front and rear adjustable camber bushings and rear suspension set (Kevin was great about getting these out to me asap)
Spoon Rigid Collars and Sparco Tow Straps
The right sized end link bolts and QA1 high misalignment spacers came in. Thanks for the solid 7" rod JD, just got it today.
You can really see the difference versus the non-adjustable units that came with the KWs for the front swaybar. The only questionable thing now, is that on its shortest setting, the DIY 7" end link is the exact length of the unit KW sent for the front. This means that I should probably have used 1" shorter rod in front at least. I won't know until I try to fit, but I'm thinking that 6" front and 7" back is about right for the Joes aluminum rod length. I didn't take into account how much beefier the QA1 rod ends were, and that makes a difference in total bolt-to-bolt length and adjustment. Just something to keep in mind. I might order an extra pair of 6" rods just in case I run into issues on the install.
That's it for now. Going to try to finish taking apart the dash this afternoon for the other other project. They are stacking up.
Old Apr 1, 2017 | 01:25 PM
  #115
604 C63's Avatar
2012 E550 Cabrio
Damn. Almost 9 years in and you still got the fire in the belly. I'm impressed.
Having an 11yo boy and a 14yo girl has just about ground me to a halt on this kind of thing. Now its a big deal that I am going to change my rims and emblems, and cant even be bothered to re-install my illuminated sills lol.
Old Apr 1, 2017 | 01:33 PM
  #116
BLKROKT's Avatar
I was inactive until I bought my C63 in May 2014. So I'm not that old-school really. Just started doing my homework ahead of time.
Old Apr 1, 2017 | 01:34 PM
  #117
ZephyrAMG's Avatar
Nice projects head up for you. Gonna be some nice additions and adjustments. Keep it going strong. Can't wait for performance and stability reports from you...
Old Apr 1, 2017 | 01:50 PM
  #118
604 C63's Avatar
2012 E550 Cabrio
OH. So you joined the forum in 2008, and didnt buy your C63 for 6 years?!?!
The food is only so-so, but the irony is delicious! LOL.
Old Apr 1, 2017 | 02:07 PM
  #119
BLKROKT's Avatar
I didn't say anything - especially not ask stupid questions - until AFTER I bought the car. I just lurked and read.
Old Apr 1, 2017 | 04:21 PM
  #120
Mag1c Carp3t's Avatar
2009 C63 AMG
These custom endlinks you're piecing together can they be made to extend the endlinks past oem length?
Old Apr 1, 2017 | 05:04 PM
  #121
BLKROKT's Avatar
Yes, that's what they are made to do. See the end link thread for details. The only issue is that the way they're setup now, there may only be adjustability longer not shorter. May need a pair of 6" Joes rod to be safe, not sure yet.
Old Apr 2, 2017 | 05:25 PM
  #122
C63 AMG - LSD
absolutely gorgeous hardware Blk
Old Feb 26, 2018 | 11:57 AM
  #123
BLKROKT's Avatar
Reminder of how this turned out after being cleaned up by my body shop.
Old Feb 26, 2018 | 03:56 PM
  #124
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
That looks pretty damn cool. All business. Lots of cooling behind the grills.
Old Mar 7, 2018 | 03:42 PM
  #125
OCDUEUCE's Avatar
C63 AMG P31
Looks like a riced out AMG. God damn that's horrible. Your car though so whatever.
