Special offer for upgrading your front rotor to Black Series (390x36mm)
The kit comes complete:
2 ea. Front RB light weight 2pc rotors
2 ea. Light weight aluminum alloy adapters (Not heavy steel adaptors)
4 ea. M12 12.9 grade alloy steel caliper mounting bolts
1 set Low dust, no squeak RB street performance brake pads
Everything you need at one low affordable price (no other hardware to buy) for an easy 100% bolt on installation.
http://www.racingbrake.com/ProductDe...oductCode=2457
First 5 orders get ex-stock shipment, order is shipped on first come first serve basis. After first 5 orders the leadtime will be 10-14 weeks.
This is the package we offer for spirited (mountain, canyon) driving and definitely for track applications.
http://www.racingbrake.com/Brake-Rot.../mb-irk-02.htm
Product presentation:
https://mbworld.org/forums/c63-amg-w...rakes-c63.html
Track use testimonial:
https://mbworld.org/forums/c63-amg-w...their-car.html
For street driving just upgrading the front should be fine, try this front upgrade (stage 1) first, you can always upgrade the rear (stage 2) later if needed. This stage 1 front only is more budget friendly, while some members prefer to upgrade the whole system at the same time.
In either case you can rest be assured our brake kits are designed and built by a professional brake company, and we certify the compatibility, performance improvement and value of the kit - Not the same as some member tried to sell you an adaptor with only a screen name and some pictures.
Also note that C63 drum brake (for emergency / parking) is smaller than BS, so a stock BS rear larger rotor will not fit C63, however we make the rear two piece rotor hat to fit C63 drum brake, to assume 100% compatibility for an easy DIY installation.
We are proud to provide this exclusive rear rotor design for C63 owner's upgrade which is not available anywhere or dealers. We also guarantee after this upgrade, your brake will perform way better than Black Series.
