C63 AMG (W204) 2008 - 2015
2008 C63 Build Concerns
Old Feb 7, 2017 | 12:32 PM
gsu007's Avatar
2008 C63 AMG
Hey MB World!
I hope you are all doing well.
Last month I took my Mercedes Benz 2008 C63 to a local shop and got the below build with products:
Ported & Polished Cylinder Heads
Weistec Engineering Head Studs
Weistec Engineering SLS Valve Buckets
Weistec Engineering Oil / Air Separator System
Weistec Engineering Spark Plugs
MBH Motorsports Long Tube Headers
ECU Tune
Lately after short drives 50-100kms I have noticed that my car's coolant has to be topped off during the next startup.
Also at idle the car has a strange intermittent shuddering, a brief engine lag which rocks up the front steering column of the car. When the hood is opened up I can hear the same intermittent shuddering and the engine briefly rocks side to side.
I am curious to know if this has impacted any other owners .
Would anyone you know a possible solution to this?
please advise.
- Gord
Old Feb 7, 2017 | 12:38 PM
Slow_c63's Avatar
Former Vendor of MBWorld
2013 Mercedes C63 AMG
Without hesitation take your car back to said shop and have them deal with the headache.
Did they warrant the work they did?
Old Feb 7, 2017 | 12:42 PM
DP8's Avatar
DP8
E90 M3, '13 C63 Sedan
Isn't coolant a potential indicator of head bolt issues? Did you check the oil dipstick? When I was researching the car prior to purchase I thought I read on the forum that they could see some dis-coloration or something odd in the dipstick reading if there was coolant leaking.
Old Feb 7, 2017 | 12:43 PM
gsu007's Avatar
2008 C63 AMG
yes, i just wanted to hear from the community if there's anyone that has prior experiences.
Old Feb 7, 2017 | 12:56 PM
gsu007's Avatar
2008 C63 AMG
thank you will keep that in mind
Old Feb 7, 2017 | 08:48 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Coolant does not typically disappear as it is a closed system, so you either have coolant under your car (undertray or on the ground) or it is inside you engine somewhere other than in the cooling system. I would suggest you may have a head gasket leak possibly causing your rough running and hesitation, but take it back and get it diagnosed.
Old Feb 7, 2017 | 08:53 PM
LondonFOB's Avatar
W204
Check the head bolts, if you got head studs the arp washer could be not sealed correctly . Ive seen that on a friends car.
Old Feb 8, 2017 | 08:03 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
+1
Step 8 in the below instructions is critical.
http://weistec.com/media/productfile...m/1/m156hs.pdf
Did they pull the heads or do them one at a time?
Old Feb 8, 2017 | 09:41 AM
chrisridebike8's Avatar
'10 C63
Originally Posted by Jasonoff
+1
He has polished and ported heads. I hope they pulled them!
Old Feb 8, 2017 | 09:46 AM
Kriston's Avatar
C63 AMG
Gordon,
after warm up does the car run normally?
Old Feb 8, 2017 | 10:04 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Missed that line. Or do they have some new technology on the market?
Old Feb 9, 2017 | 12:24 PM
gsu007's Avatar
2008 C63 AMG
Originally Posted by Kriston
Gordon,
Hey Kriston,
the car is currently back at my local shop for further testing...
waiting to see what their findings are... car runs smooth no signs of overheating, just the concern with the car at idle (shuddering of front end and interment lag) and again the occasional top off of coolant require after a few short drives...
