C63 AMG (W204) 2008 - 2015
Replacing motor mounts
Old Jun 14, 2018 | 05:25 AM
Emkovich's Avatar
C63
Originally Posted by Ryan951s
Another quick thing you can do to check is park your car on level ground, open the hood, and check how level the engine is. Before changing the mount the passenger side of the engine sat noticeably lower that the driver, maybe half an inch. After replacement the passenger is just slightly higher than the drivers side. (You can also check this at the oil pan and compare it to side to side with the crossmember; it'll be obvious if one side is sitting substantially lower.)
I noticed on my C63 the passenger side of the engine sit noticeably lower that the driver side.
I have vibration in gas pedal when I do not fast drive 70-110 km. Vibration only in pedal.
Old Jun 14, 2018 | 07:35 AM
East Coast Euro's Avatar
Former Vendor of MBWorld
C63 and CLK55
Sounds like a failed engine mount
Old Jun 14, 2018 | 10:55 AM
AMG3.2's Avatar
C63 AMG, P30
I used to feel vibration in my floor when driving at 70MPH+ (~110Kph). I replaced my engine mounts as well as trans mount two days ago and the issue seems to be gone... Just know that swapping engine mounts is actually a really frustrating job. I had the 16mm offset tool, and it still took me about 2 hours just to properly loosen the drivers side bolt. Passenger was much easier, but still not a fun task. It can be done however so best of luck!
Old Jun 14, 2018 | 11:47 AM
CyanideRide's Avatar
S/C C63
Originally Posted by East Coast Euro
Good information in here . We did a write-up with a few pics to help. Our poly/billet mounts are a nice performance upgrade over stock mounts
https://mbworld.org/forums/c63-amg-w...oast-euro.html
Is there any additional vibration transferring to the vehicle/vehicle chassis with these?
Old Jun 14, 2018 | 11:54 AM
C63 and CLK55
There is minimal vibration felt at a stop of you are looking for it. Many people don't even notice they are in the car. Except for the better throttle response
Old Dec 2, 2018 | 09:56 AM
skratch77's Avatar
2005 E55
Hey guys do you know if engine and transmission mounts are covered under cpo?
Old Dec 2, 2018 | 01:26 PM
  #32
Mort's Avatar
According to the Star Certified Warranty (Canada) document I got with our 2017 GLS under Engine: hydraulic engine mounts are covered. No mention of the transmission mount being covered.
Old Dec 2, 2018 | 10:15 PM
  #33
ItalianJoe1's Avatar
2003 CL 600
We always check coverage to verify but yes, they normally are covered.
Old Dec 2, 2018 | 10:19 PM
  #34
skratch77's Avatar
2005 E55
I texted my sa at the dealership. I will have an answer tomorrow morning.
I like how mb of Burlington sets you up to directly talk to the sa on his computer through text messages.
Old May 14, 2020 | 04:55 PM
  #35
glhansenjr's Avatar
2009 SL 63 | 2009 C63
Did you swap out the trans mount too?
Old May 17, 2020 | 12:59 PM
  #36
S/C C63
I swapped out all, engine and trans mounts.
There is a strange vibration around 60-70kms/h (30-40mph roughly) that feels like you're revving too high, but the RPM is 1200. It's hard to explain it, but it is there.
I don't even notice the extra vibration anymore, it's slight but only if you're looking for it.
Old May 17, 2020 | 10:11 PM
  #37
2003 CL 600
1200? that seems low. You may be feeling some powertrain resonance because you are loading the engine at such a low RPM. There is a process for removing the tension from the powertrain mountings that may help, but it may be normal.
