C63 AMG (W204) 2008 - 2015
FS - 2014 C63 507 Brake Rotors & Pads
Old Jun 3, 2018 | 03:26 PM
toosteeley's Avatar
Present: 2019 C43 Estate
I’ve recently upgraded my rotors/pads so my stock parts are for sale. Came off my 2014 C63 507 Edition. All parts have only 15,000 km (9,500 miles) on them. 1.5 piece front rotors (noticeably lighter then the 1 piece fronts), 1 piece rear rotors and front & rear pads with tons of meat left. Great upgrade for any non p30/p31 C63 or inexpensive alternative to brand new parts.
Asking $OLD US. Willing to work out shipping depending on location.
Old Jun 3, 2018 | 03:35 PM
gtracer's Avatar
'13 C63 & AP2 S2000
Great condition!!!
Old Jun 3, 2018 | 03:54 PM
SuckaGDog's Avatar
C63 AMG Black Series
This is how a for sale ad should be! GLWS.
What did did you upgrade to?
Old Jun 3, 2018 | 03:58 PM
toosteeley's Avatar
Thanks for the comments! Upgraded to the Racing Brake 2-piece set up.
Old Jun 3, 2018 | 08:41 PM
leungsta's Avatar
C63 AMG Coupe, BMW 335xi Frozen Silver
Can anyone confirm if these are the same brakes as what’s on a C63 BS?
Old Jun 3, 2018 | 08:44 PM
toosteeley's Avatar
The BS uses 390mm rotors in the front. Otherwise the same.
Old Jun 3, 2018 | 08:47 PM
leungsta's Avatar
Where you located ?
Old Jun 4, 2018 | 09:45 AM
Mort's Avatar
Originally Posted by leungsta
Where you located ?
According to his sig he is from Toronto.
Old Jun 5, 2018 | 03:32 PM
chrisridebike8's Avatar
'10 C63
Incorrect. Only the front calipers and all pads are the same as the BS. BS has larger rotors at all 4 corners and different calipers at the rear. Great condition for this setup though. good luck with the sale!
https://mbworld.org/forums/c63-amg-w...ml#post7139662
Old Jun 5, 2018 | 03:46 PM
toosteeley's Avatar
Good to know, thanks
Old Jun 5, 2018 | 04:59 PM
MBNRG's Avatar
BS uses slightly different Front Calipers than non-BS, with different Caliper Bracket as well ;P
Old Jun 5, 2018 | 05:21 PM
'10 C63
I think I remember that the BS caliper is externally the same. I think the pistons are a little different. And correct, the bracket is different to accomodate the larger rotor. But all you need to make a BS rotor work on a standard car is the bracket and larger wheels.
Old Jun 5, 2018 | 05:28 PM
SuckaGDog's Avatar
They’re actually slightly different. The bleeder valves are located inside the calipers. No external bleeders visable through the wheel face like the regular C63s. Can’t speak on the pistons as I haven’t removed mine yet. But yes, what you mentioned is all that’s needed for 390mm to work on a non BS.
But lets not derail OP’s for sale thread lol.
Old Jun 5, 2018 | 08:35 PM
cm60k's Avatar
If "C63 BS" got only one bleeder that located inside the caliper,,
that means; "C63 BS" sharing the same calipers with "W212 E63/W218 Cls63", but with (390mm) Rotors brackets..!
-;ZAYED;-
Old Jun 7, 2018 | 09:37 AM
toosteeley's Avatar
Thanks for the interest. These are now sold.
