My Nitrous Install
Very little info is online regarding what kit to go with so I ended up buying the 82023b kit which is a universal system made for efi cars. I've used zex for 20+ years and love their control box and tps activation and recommend giving this kit a look.First step was finding a place for the fogger nozzle. This is literally the only spot that would work
After that I needed mount the control box close enough to the fuel supply and the nozzle to work. On top the y pipe was the only spot that was within reach of both due to the location of the flexfuel control box. There is just enough room so it doesn't push against the hood liner. Fuel was tapped in the same line as the ethanol sensor and was a snap to get hooked up.
Installed a purge kit as well which is tapped in right before the controller.
Mounted the solenoid here which was a perfect distance from the controller and made it easy to run a nice straight tube to the grill.
Just needed a little tlc to get the tube into a good spot which is invisible when the hood is down.
Next it was time to wire it. There's a nice little port through the firewall behind the master cylinder which I punched everything through. Mounted the arming switch and purge button in the glove box
Lastly to mount the bottle. For this I cut a piece of plywood to the shape of the trunk, added carpet, and mounted the bottle to it so the whole thing is removable and it's not necessary to damage anything in the trunk for a sturdy install.
Make sure to use thread sealer on all connections and check everything for leakes, then it's time for fun. The engine seems to love it. No hiccups and great power. Hard to believe it's only a 75 shot. Haven't taken it to the strip yet but will do that as soon as it cools down a little. Also need to work out the jetting for e85 as I think the two together could make insane power.
Edit: I neglected to mention the tps wire hookup. Thanks to celicasaur I knew which connector to look at (white and black connector on the front of the the intake manifold under the engine cover). The wire you want to tap is the top left (closest to the firewall) wire. It's brown and the largest wire on the bundle I believe.
Also with you running the e85 are you not worried about running out of fuel? E85 does use more fuel than 93 and tapping into the fuel system to run NOS would be pushing it. I may be mistaken, I was just under that impression.
Man.....a purge line has got to be the best part about having a nitrous system. It can add another 100hp on the starting line against ricers and scare them off
You're running the stock tune, correct? What's your 60-100 with/without nitrous (in seconds)?
Running v7. Jerry said it'd be fine if we stepped up one size for the fuel jet. It seems a little rich to me though with that pill, so I may make a change depending what the next dyno tells me.
No idea on 60-100, I've sprayed less than a half bottle so far, but I'll def report in once I have had a chance to play with it.
450 awhp, 3200 lbs and a proper 6 spd equals tons of fun
I'll post some more pics soon
