Phil1305 C63 Progress/Mod Thread
The only argument for keeping the SAP system is that it protects the factory cats. It serves little purpose with aftermarket cats and zero purpose for anyone with a cat delete.
Another buddy of mine came over to help drop the blower on top of the engine. Its loose for now ill bolt it down today after work.
Also, from what I'm hearing the mct should hold the power for a while as long as i stick to rolls and dont dig it too much. Right now I'm just finishing the tedious stuff up.
Also, got my purge valve relocated right behind the ABS unit to clear some room for my intake.
i put the blower pulley on and the belt to button that up, along with the radiator fan and upper rad support. I also started on the trunk ice tank but I have to make spacers at work to mount the tank to my liking. Once the tank is mounted and hoses ran then ill get the bumper back on.
Intake I plan to have made similar to this one.
I put the radiator fan and associated parts back in. I also mounted the power steering reservoir and adapted the hoses.
I ordered all the 3/4 hose i need to run for the trunk ice tank. Drilled holes in the spare tire well and ran them through the grommets. Also, used stainless clamps and modified the plastic nuts for the plastic under tray, and used the studs already on the body and the plastic nuts to mount them. It only mocked up for right now as I need to buy some silicone heat sleeve and some anti abrasion sleeve as well. I will say it is tight to run the hoses when you get to the engine bay and front bumper area.
More eye candy for now!!
Put my candy blue valve covers on with all the ARP 12 point hardware. While doing this pulled my plugs and closed the gap down to .028 since thats what weistec recommends. I already have SLS plugs with only 10-12k on them.
Made a bracket at work and mounted my catch can setup where I wanted it. I think it'll work out and look awesome once everything is finished. At the bottom I drilled and tapped for 1/4 npt and put a ball valve in, so i don't need to unscrew the can to drain it. Ill just add some 3/8 push pushlok hose and run it out the bottom of the car so I can drain it below into a pan.
I also finished plumbing the ice tank completely and have it tightened down with the drain plumbing done.
Started plumbing the catch can but didn't like how i routed it the first way. So I had to order more hose to make them longer and another 90° fitting.
Last few things to do yet is to install and wire injectors and figure out how i want to do the vacuum line fir the booster. Then get my intake made at my buddies shop.
Also Did a first fire video after finishing the wiring. This is a legit first fire with no test starts before hand. Just primed the fuel system a few times.
Lastly, I am pretty disgruntled with weistec on this kit. You pay alot of money and get some cheap **** in with it. My injector pigtails are used cut offs from another car, and its plain as day that they are. I even took pics to show. They're dirty from normal service and one had blue paint/chalk pen on it.
And the wiring for the heat exchanger pump is of cheap Chinese and mine was damaged. one female pin in the relay receptacle was pushed in and bent. I ordered new 30 amp relay/receptacle off Amazon, 5 of them for 25 bucks and is exactly identical to what i received from weistec. So they could've not cheaped out to save a few bucks. I mean a 6-9k kit maybe but 13k+ is just ridiculous. Here's some pics of these issues.
