C63 AMG (W204) 2008 - 2015
Steering Column Adjustment Failure
Old Feb 19, 2019 | 07:14 PM
Big Jimbo's Avatar
2012 C63 with P30, LSD, and EES Supercharger, 1959 Plymouth with Viper V10 and Tremec 6sp
My steering column now just makes a single click like a solenoid when I hit the up or down switch but doesn't move. The in and out function still works. I found an old thread about a broken cable for the in and out, but I suppose the same thing might have happened to my up and down.
I am hoping against hope that someone may have a suggestion before I am faced with the ugly prospect of removing the column like it says in the shop manual. I wish I liked the position it is now stuck in, so I could just ignore it, but it is too high.
Any suggestions would be greatly appreciated! My car is a 2012 coupe.
Jim
Old Feb 20, 2019 | 03:59 AM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
I remember seeing a post directing to a video for a DIY. Can't remember if it entailed column removal, though.
Old Feb 20, 2019 | 09:15 AM
Junaidh's Avatar
C63
I had this issue, but I was able to fix mine by following this thread and doing this
If you hear a click or thump and it doesn't move, it's probably jammed up. You need to free it, extend it all the way out and hit it downward with your hand, very firmly (don't be afraid of it), while pressing the lever to adjust it down. It should free up.
https://mbworld.org/forums/c-class-w...up-down-2.html
Old Feb 23, 2019 | 10:07 AM
pjfernan's Avatar
2012 c63 coupe
Fix the up / down movement
I just unplugged and plug back the wiring connector from the left module located under the drivers seat and fixed the steering up / down movement.
As soon as I plugged it back and pressed the lever I can hear the motor and with a couple of hard poundings to the steering wheel it started to work again.
It stop working a long time ago and was in the up position.
The service department at the local dealer told me that the motor has to be replaced.
If you have the same problem, give it a try because it work for me.
Old Feb 23, 2019 | 10:50 AM
Big Jimbo's Avatar
Thanks! I tried the pounding and it didn't work, this weekend I will have more time and will try unplugging the module. I really appreciate the advice and will let you know what happens!
Old Apr 26, 2019 | 09:07 PM
Big Jimbo's Avatar
I finally got my Column to adjust up and down! I have been beating on it regularly with no success but tried my MBII scanner and found the steering column option and it also had some type of recalibration option. I tried this while beating on it and a miracle happened, the column started to move down and now works fine! I was almost ready to bring it to the dealer for a check-up but glad I tried this first. I had no idea the scanner would cover the steering column too.
I finally got the column to adjust up and down! I have been beating on it with no luck so I attached my MBII scanner and actually found the steering column to scan!
Old Apr 26, 2019 | 10:56 PM
Murret's Avatar
2012 Mercedes C63 AMG
Mine stopped working and I put my head under the steering wheel and used some pliers to turn the threaded part and it freed it up and I just sprayed some lube on it. Happened a couple of times now because It doesnt get adjusted often.
Old Apr 27, 2019 | 04:29 AM
Subarix's Avatar
C63 AMG 2013 Sedan Pack Performance
My exprience as I had a similar issue : try to move it up or down and nothing happened except a click noise. Don’t smile and this is not a joke but I decided to force on the command by insisting (like 10 sec) and it unlocked itself. I hope you will be as lucky as me.
Old Apr 27, 2019 | 06:16 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
I wouldn't count on that working too many more times
Old Apr 27, 2019 | 10:40 AM
Big Jimbo's Avatar
I turned off the movement when you exit the car and don't adjust it much so hopefully it will be ok. What is the long term fix, replacing the motor?
Old Apr 27, 2019 | 01:02 PM
Mort's Avatar
There is a nut on the flex shaft from the motor to the column adjuster on the steering column end. The flex shaft turning must tighten the nut up until the motor no longer has enough power to turn the flex shaft. Back the nut off a turn or two and you should be back in business. That is what worked for me and I posted a thread about it quite a while ago. If the nut is too tight, I think you may risk breaking the flex shaft as has happened in some instances. Then you will need to replace the flex shaft with a new one.
Old Apr 27, 2019 | 01:36 PM
Big Jimbo's Avatar
Thanks! I searched all the old column problem articles but missed yours. I will have to check that out.
Old Apr 29, 2019 | 10:46 AM
toosteeley's Avatar
Present: 2019 C43 Estate
^This. Happen to mine a few months ago and loosing the nut off worked like a charm.
Old Apr 29, 2019 | 04:31 PM
Big Jimbo's Avatar
What do you have to take apart on the Column to get at the flex shat nut?
Old Apr 29, 2019 | 05:14 PM
gmaschine's Avatar
W463
I was having the same issue and then I realized it was "preset" in the steering/seat memory. I just cleared it and now it works fine. This might work for you but I cannot guarantee it.
Old Apr 29, 2019 | 10:44 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
If you need to remove the column to remove the motor, follow instructions for W204 ESL repair.
Overall it's not a difficult process.
Remove bottom panel and you can check the plugs and actually see the motors.
Old Apr 30, 2019 | 09:46 AM
toosteeley's Avatar
Nothing. You just need to be a bit flexible to get your head down under the steering wheel so you can see the nut. There's a few threads about it.
