C63 AMG (W204) 2008 - 2015
Coolant tempurature sensor location 2009 c63?
Old Feb 21, 2019 | 04:28 PM
djr48312's Avatar
2009 c63
I got a code for engine coolant temp sensor. Im not finding information on this and im not seeing it . Can someone describe the location, provide diagrams and a procedure for changing?
Old Mar 15, 2019 | 03:52 PM
djr48312's Avatar
2009 c63
No one has the location of the coolant temp sensor on the 2009 c63?
Old Mar 16, 2019 | 12:48 AM
NotABaller's Avatar
2012 C63, 2014 E550
Why does our coolant temp only go down to low of 40c ?
Old Mar 16, 2019 | 06:23 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
Temp sensor
Thermostat
Old Mar 16, 2019 | 02:08 PM
Mort's Avatar
Coolant temperature sensor 2010 C63 - Alldatadiy
Old Sep 17, 2020 | 12:51 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Anyone know if there's more than one coolant temp sensor? One for the dash "AMG screen" and another that OBDII can pick up?
Of if anyone has seen the dash report an incorrect value?
Old Sep 17, 2020 | 05:52 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I think possibly there's the sensor Mort posted and another in the thermostat housing?
Old Sep 17, 2020 | 06:45 PM
deadlyvt's Avatar
2010 C63 AMG
There is definitely some kind of electric plug on the thermostat housing and can’t think of anything else it would be...could try unplugging it and seeing if the temperature reading on the amg screen or obd is lost
Old Sep 17, 2020 | 09:05 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
https://mbworld.org/forums/c63-amg-w...ml#post8159596
Old Sep 20, 2020 | 04:12 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Anyone ever data log coolant temps? Curious the range and differential on what's displayed to the dash from the thermostat.
From what I understand after digging into this the last couple days. The thermostat temp sensor is what's displayed on the dash and controls fan operation. The CTS (from this thread) is what ignition timing, fueling etc is based on and is the accurate coolant temp flowing through the engine.
Old Sep 22, 2020 | 09:15 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Nobody has logged their CTS numbers? 100% confirmed there's 2 sensors noted above.
What if I post some cooling mod ****?
