MBH Headers - Gains and Issues
PART ONE: I bought a 2012 c63 amg coupe with P31, resonator delete with eurocharged V5 tune. The car ran absolutely amazing but I just wanted a few more ponies so I purchased and installed MBH headers, x-pipe, midsection, and GESI cats along with the header V7 tune from eurocharged for high altitude (colorado version).
Got the car back and the shop gave me the baseline dyno and upgraded dyno. Numbers were before 368hp / 371ftlb, and after (with new mbh stuff and header tune), 377hp / 369ftlb. Obviously something is off and have talked to Jerry about getting a custom tune but I thought I would see what people thought on here.
PART TWO: The MBH headers have completely lost that AMG signature V8 growl. It now sounds more tuned, sportier and higher-pitched. I absolutely hate it so is there a way to get the signature AMG sound back while still keeping the headers.
If I cant get the HP up and the torque up, I definitely will be going back to the original setup...
Add Eisenmann Race Exhaust system to get the signature AMG sound back with the LTH's or Akra Slip ons for a deeper more refined growl.
Answer to Part 1.
Yes those numbers are super low for the bolt ons you have. Altitude factored in, your still about 100 WHP / TQ down on most W204's with the same mods.
- FI headers
- FI 3'' midpipes
- CLS63 resonators
- OEM mufflers
It's civilized when driving normally, with a little more throatiness.. But a complete animal when you get on it. It's a little raspy for my taste, so might add an H-Pipe I have laying around right before the resonators.
- FI headers
- FI 3'' midpipes
- CLS63 resonators
- OEM mufflers
What does the X-pipe change about the sound that everyone seems to hate? Most of these exhausts are so loud the blow out every camera microphone so videos don't really let you hear them on video very well.
Thats the main issue, has anyone actually done dyno tests for a stock p31 c63 with resonator and secondary cat delete compared to headers, resonator delete, secondary cat delete and x-pipe? Every site for the headers claims 90-120hp gains with a tube but how much of that is the tune. Eurocharged gets you 90hp alone
i honestly would’ve never bought them for $3k, paid $1k for install to only gain 7 hp and LOSE torque.
I guess the next step is to see if a custom tune by jerry at eurocharged will help the issue but honestly, if it still sounds like same, going back and selling the entire setup.
Trying not to drop money on more parts, especially akrapovic, I may try the h-pipe by mikes exhaust too, thank you for that suggestion. Isn’t the OEM exhaust Eisenmann already?
Point is is I did a baseline with three runs and then 3 runs after, max gain was 7 hp, loss of 3 ft lb.
And it sounds worse!!!! Imo
So you think those cats are the cause of me losing so much power? I was told I would lose 5, maybe 8 hp at most but I hope it’s not responsible for losing out on 33 hp
but again, I went from a stock exhaust WITH the stock cats but with the resonator delete and secondary cats deleted so I would think just adding the headers would’ve gained a lot more.
I’ve been searching for some data on the actual increase from a header replacement only
as far as sound goes part of your problem is you took out the stock resonator. Put it back in. If you don’t like the sound after that you can straight pipe the x pipe portion. Start with that. As far as power, was the second dyno done on the same day same dyno? If not that’s part of your issue. Also this Colorado tune not sure what that means but I think your best bet is a dyno tune from Jerry. With your elevation and such will be your best bet. The cats will cause you to lose power but not as much as that unless they are clogged or there is a defect. I’m not familiar with the brand but even still they shouldn’t rob as much power as your saying.
The tune is from Jerry at eurocharged. And yes, the charts have the afr fairly rich at around 17 max but it’s the afr numbers are pretty similar across all dyno runs (before and after)
im not throwing any codes so I believe the O2 sensors are good, their only a few years old and no issues.
After doing fi headers,300 cell high flow cats and remus exh on base header file I made 460 whp.
On race map and 82mm TB and ms109 fuel I made 479whp on MY dyno and trapped 121.
I'll post the before and after dyno for you.
Im really starting to see that headers alone don’t add much power for the crazy $4k I spent. But I’m still going to have jerry do the custom tune and see what can be squeezed out. From there, I’ll know if I want to go back to the old setup or try an h-pipe or add the resonator back (with headers on)
im one step closer to removing them, thank you!
