Concerns for undrilled lubrication holes in NEW OEM Camshafts
After seeing this I’ll have an even harder time believing that car manufacturers don’t build their product to eventually fail on purpose.
I would bet my money on that the bit which drilled the holes was damaged and partially broken off and didn't drill the hole deep enough.
If they don't do a flow check and that info isn't traced with the 2D barcode then good luck finding the bookends.
That is just going to be blown off by the manufacturer. Worst case they have to implement a poke yoke in their production step.
At best they will recall the cars if the can find the bookends.
Most likely the camshaft he used are made as a service part by the manufacturer. Which is a non standard set up for them and stuff like that happens all the time.
In that case the original camshafts shouldn't be effected if my theory is right.
Either way, that's a serious problem lol.
Definitely missed something or didn't follow something in the PFMEA. Just the potential effect of that failure should trigger a prevention and detection step.
I truly hope it is small error in just a smaller batch of bad camshafts, likely caused by incorrect drill depth setting.
But a lot of the machining at MB is probably automated, so who KNOWS how many newer camshafts are faulty.
Sven's theory of a possible broken drill bit is also very plausible.
Older camshafts do not appear to be affected.
There are reports of faulty New camshafts appearing in Germany, Australia, & Singapore (comments in Part 2 of this video above).
Then there is the possible issue of planned obsolescence. . .
The mind reels.
And I just had all camshafts replaced with New a few months ago
The mind reels.
I'll take a look at the normal cap reinstallation procedure, to see if the cap-by-cap can make sense.
Meanwhile, i wonder if there is always the same cam that displays this problem.
The CAD-CAM (excuse the '70's engineering term) of the factory machining rig would always drill for every cam at the same circular angle.
Whatever angle Tassos's video shows (By example the lubrication hole is 30 degrees past the 4th intake lobes), our cams will have as well.
We can take a look at Tassos's video and see the clocking of the holes vs the lobes and assess which way they're facing (the lubrication holes under the cover of the caps) by looking at the lobes of the cams, as the cams sit installed in our cars, with the valve covers removed.
