C63 AMG (W204) 2008 - 2015
RaceDeck vs Epoxy vs POLYASPARTIC Floors
Old May 2, 2019 | 09:43 PM
Dogtag114's Avatar
2009 c63
Anyone have a strong opinion?
i like the cost and look of RaceDeck but not sure if it sounds like walking on plastic.
Old May 3, 2019 | 12:14 AM
thesaintusa's Avatar
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Have had all three.
Racedeck (or whatever is equivalent), sounded 'cheap'. Worked well, durable, drained nicely. Could use a jack etc. Was always worried about jack stands cutting into the plastic, so used pieces of plywood under the jackstands. Not ideal for rolling around on a roller under a car..
Had a finished concrete floor at my last place and loved it. Looked finished but definitely not 'fancy'. Was NOT slippery when wet. No issues using a roller/creeper. No issues with jack stands.
Currently have epoxy floor. Gets scratched if a 'pebble' gets under a wheel on the floor jack. Looks GREAT. Is incredibly slippery even though the finish has material to make it less slippery.
I would go with a finished concrete floor next time.
Old May 3, 2019 | 06:49 AM
ygmn's Avatar
2015 E400 Sedan
Originally Posted by thesaintusa
... a finished concrete floor ....
you mean regular ol' garage floor? smooth concrete?
I have finished concrete attached garage and well it absorbs oils and other liquids and just looks crappy.
It will mold, seems to create dust - ad is well CONCRETE GREY color... so boring.
now the detached garage - (Too big for race deck or I should say my wallet is too small for racedeck) was painted with epoxy or something by previous owner.
I like it much better..... it is slippery when wet but not too bad if you wear right shoes or work boots.
Oils do not soak into surface and easy wipe up...
For soem reason easier to find that drop nut or washer due to color is my guess.
Anything with wheels rolls easiers.
Cleans up easier too as dust blows off with leaf blower and out the door
Yes it scratches but that is OK with me as does not happen often
I only wish they would have used the proffessional coatings that have the flake and more slip preventatives added....
Good luck with choice but if you have the $$$$$$$$ look at proffessional stuff - where they come ni and diamond grind fllor and then coat...
I would do that if I had the $$$$$
Old May 3, 2019 | 08:01 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Use a hardner/densifier then have it polished. Same thing they do at HomeDepot/Lowes etc.
This is what they use here in Canada https://www.wrmeadows.com/en-ca/liqu...-ultra-canada/
Old May 3, 2019 | 04:08 PM
Ludedude's Avatar
2014 C63 Coupe
I have Racedeck in my garage. It's OK. I love the colors and options for designing your own floor however it hasn't done well with a jack. I have at least two tiles that are damaged from jacking up my previous car (much lighter than the C63). The good news is tiles are cheap individually and easily replaced one a time.
On the plus side, it's easy to sweep clean, looks great, stuff doesn't get lost on it like it does with epoxy floors. For some reason, everyone I know with an epoxy painted/coated floor says the same thing about losing nuts and stuff that go flying. That must just be a side effect of the common colors and texture flakes they use in it.
I'm thinking about what I'd do if I guy a new place and I'm not convinced I'd go with Racedeck again even though you can't beat the look.
Old May 3, 2019 | 04:34 PM
Dogtag114's Avatar
2009 c63
Am I the only one that religiously uses an upside down white frisbee for loose parts???
Thanks for the input... of course my project costs are exploding and now we are considering new doors too ... ugh
Old May 3, 2019 | 05:05 PM
Ludedude's Avatar
2014 C63 Coupe
I've got plenty of magnetic parts trays...the parts though...they fall out the bottom of the car and poof
Old May 5, 2019 | 09:20 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Ran across this from last month
https://www.caranddriver.com/feature...poxy-flooring/
Old May 5, 2019 | 10:20 AM
Dogtag114's Avatar
2009 c63
I got a sample of RaceDeck yesterday... one piece sounded really click-clackity but I assume it’s better when locked into others.
Now my hi-lift door and car lift project has added a floor and new garage doors to appease the wife... ugh.
All for a new car I bought on a near whim...
Old May 7, 2019 | 06:19 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Throw up pics when your done
Old Sep 12, 2019 | 12:33 AM
Dogtag114's Avatar
2009 c63
Epoxy base and polyspartic finish... just painted cinder block (what a pain), next the lift and painting the walls.
Old Sep 12, 2019 | 09:03 AM
Vladds's Avatar
2010 C63 2019 GLA45
I've got the epoxy. I went for the additional transparent sand and no clearcoat.
The clearcoat would have worked better with sealing the concrete and I should have bought double the recommended per square foot quantity of paint, as a review suggested.
Also the drying of the paint is tremendously fast, just as all review say. You gota move quick with the painting operation.
I researched repainting and found some indication that I can paint over, I plan to do this right the second time.
It does cover cracks in the concrete quite nicely.
I see that now there are outdoor kits as well and I would consider painting the driveway in maybe a gray color. I was thinking about what this would do in the winter, especially with the clearcoat, but I tend to think that the ice would adhere less and that I can salt the driveway without fear of cracking the concrete. But it could be a lot more slippery in light rain, or sleet.
Not sure what to do with this...
Old Sep 12, 2019 | 10:28 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
What products did you use?
Old Sep 12, 2019 | 12:17 PM
Dogtag114's Avatar
2009 c63
More like who... Tailored Living... the products are from Sika
Old Sep 12, 2019 | 12:49 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Ah, you watched them work with a cold beer in hand. Even better!
Old Sep 12, 2019 | 01:44 PM
Dogtag114's Avatar
2009 c63
Seriously, you could never do the level of work as a DIY... they grind the floor, lay down a thicker coating, etc.
Old Oct 20, 2019 | 09:34 AM
Dogtag114's Avatar
2009 c63
Added some paint and a lift...
Old Oct 20, 2019 | 04:18 PM
Ludedude's Avatar
2014 C63 Coupe
If only my garage was tall enough
Old Mar 31, 2023 | 08:01 PM
Ludedude's Avatar
2014 C63 Coupe
Originally Posted by pmhip
Hi there I'm looking for some advice from people who've finished their garage floors. Currently, I've narrowed down the field to Epoxy covering and/or Racedeck. The Epoxy job will be done by professionals and has a 10yr warranty, the bid costs a bit more than Racedeck. My question regarding Racedeck is doing it pop when you walk on it if the concrete floor isn't perfectly flat...or over concrete expansion joints...? The pictures of Racedeck look OK - although some pics have that cheap reflective plastic sheen revealing all the tiles. I know they now make a larger tile that might work better to reduce tile patterns. Another question for the Racedeck owners - If you spill something on the tiles does the liquid seep between the tiles...?
No popping but my garage floor isn't warped lol. No noise over expansion joints either...the tiles are 12" across, way more than enough to bridge any expansion joint I've ever seen. Yes, liquid will seep down to the floor beneath. Water more so than oil, and if I see oil spill I clean it up. I've never pulled the tiles up in the 8 years I've had them down, so no clue what's really under there.
They are tiles, they don't fit seamlessly together so that the seams are invisible. They have matte vs gloss finish tiles and seams might show up more with the glossy finish but I don't think it makes a difference really. I have both finishes on my floor and you can see the seams no matter which it is.
