C63 AMG (W204) 2008 - 2015
Wanting a little more growl! Exhaust recommendations? Resonator Delete/X-pipe/Cat Del
Old May 10, 2019 | 02:10 PM
jliusifer's Avatar
2010 E550 4MATIC
I am looking for a little more growl in my C63. I have a Eurocharged tune but everything else is stock. As much as I would like to install headers, it's currently out of my budget. I'm not looking for much more performance but mostly just looking for noise.
I am considering the following....Resonator Delete, Cat Delete, or X-pipe.
I'm not looking to make my car extremely loud and obnoxious. What do you guys recommend?
Old May 10, 2019 | 02:20 PM
NotABaller's Avatar
2012 C63, 2014 E550
Secondary cat delete
Old May 10, 2019 | 03:26 PM
DadCar's Avatar
2012 C63
just did cat delete, can confirm car is about 10% louder at low RPM and 50% louder at WOT
Old May 10, 2019 | 04:23 PM
dmd-amg-c63's Avatar
2012 Mercedes C63 AMG
My opinion. Remove secondary cats and replace with mikes power pipe, remove resonator and replace with straight pipes. Don’t touch the rest
This is by far the best sounding c63 that gives you the best of both worlds. Nothing too loud under 2500 rpm, sounds awesome at anything above, and will add HP. Keeps that amg growl.
headers aren’t really worth it unless you are going for every last hp which it sounds like you aren’t. MBH claims 110 hp gain but 90 of that is a tune, and 10-12 of that can be gained with mikes power pipe (remove 2nd cats and resonator).
DO NOT GET AN X-PIPE, it will ruin the amg tone.
Old May 15, 2019 | 07:29 PM
J0HN_R1's Avatar
'19 4runner TRD / '12 C63 AMG
I plan on removing this entire section, and replacing with either strait-pipes or an X-pipe...
Probably gonna have them welded in permanently, but might splurge for some V-band flanges.
FWIW - the forward section (right-side) is the secondary cats, the rear (left) section is the resonator.
And Mikes Power-Pipe replaces only the resonator...
Wanting a little more growl! Exhaust recommendations? Resonator Delete/X-pipe/Cat Del-a3agql1.jpg
Old May 15, 2019 | 07:35 PM
juggernaut1's Avatar
2010 Ford G6E Turbo / 2013 C63 Coupe - AMG Performance Pack
I thought Mike's power pipe only replaced the secondary cats
Old May 15, 2019 | 08:06 PM
DadCar's Avatar
2012 C63
correct, MPP = cats
here is my recent install:
Old Jun 9, 2019 | 12:13 AM
TexasBenzBandit's Avatar
2017 AMG C63, 2001 C5 Corvette
Nice, How much was it?
Old Jun 9, 2019 | 12:15 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Does anyone make an H-pipe? I think that would help it still sound "AMG" vs an X-pipe.
Old Jun 10, 2019 | 01:02 AM
95gsrturbo's Avatar
2000 Acura NSX, 2012 C63 P31 (gone and not forgotten), 2015 C63 507
This is incorrect
Mike's pipe replaces the secondary cats which are on the RIGHT in this pic
It DOES NOT replace the resonator.
Taking out the resonator causes a drone in the car at cruising speeds.
It's best to keep that
Old Jun 10, 2019 | 06:08 AM
agp423's Avatar
2018 GLC63
Does removing second cats affect emission inspection?
Old Jun 10, 2019 | 11:42 AM
DadCar's Avatar
2012 C63
No, O2 sensors are connected to the primary cats. Some states may do a visual inspection, but I live in NY and passed just fine.
Old Jun 10, 2019 | 11:45 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
If there is a visual inspection in your state (CA etc), you will fail if the secondary cats are removed.
Old Jun 10, 2019 | 12:45 PM
Kriston's Avatar
C63 AMG
Cut out the resonator and secondary cats. Straight pipe right into the cat back. You wont be disappointed.
H Pipes tone the exhaust note down.
Old Jun 10, 2019 | 09:37 PM
DadCar's Avatar
2012 C63
NY requires visual inspection, but I passed. Probably depends on competency/care level of the technician doing the inspection.
Old Jun 12, 2019 | 11:49 PM
I have had a C5 Vette with NO Cats and it's passed for the last 12 years. The car is TUNED so it doesn't throw any codes to make it fail, but seldom are they looking under your car. If they do, go to another place. Good Luck!
Old Jun 13, 2019 | 02:58 AM
Mikegpr03's Avatar
C63
Originally Posted by 95gsrturbo
This is incorrect
My power pipes remove the secondary cats NOT the resonator. If you do a resonator delete the I will make you an H power pipe to keep the balance and flow equalized between banks.
straight power pipe ( only if you have a resonator )
H power pipe ( only with a resonator delete )
power pipes are US mandrel stainless steel
NOT cheap China steel or aluminized piping which is bent at any muffler shop using a regular bender. The mandrel bender ensures a true 2.5 inch diameter bends.
As I always say don’t go Honda Civic with cheap exhaust mods and expensive car.
Disclaimer : I don’t have anything against Honda people..lol fine folks I was one of the back in my youth.
Old Sep 5, 2019 | 11:59 PM
Travis Decker's Avatar
c63
Is the oem exhaust stainless?
If not, how do you weld the Vband to the OEM exhaust? I am guessing the Vband is stainless wince the power pipe is stainless?
Are you welding stainless to non stainless?
Old Sep 6, 2019 | 03:38 AM
95gsrturbo's Avatar
There is no welding. The V-band allows you to clamp the exhaust together without an exhaust leak.
Scroll back up to Dadcar's pic. On the left you'll see a clamp with 2 bolts that's the V-band. It's also the location you make a single cut.
What I liked about Mike's design is that it's easily reversable
Old Sep 6, 2019 | 11:29 AM
agp423's Avatar
2018 GLC63
Anyone know how much louder it gets with a secondary cat delete and no other mods?
Old Sep 6, 2019 | 12:35 PM
BalanBro's Avatar
2012 C63 P31 Sedan
That's essentially what I have. It makes WOT a good bit louder, and start-up is definitely louder/crackly. You also get a little crackling on decel, but nothing obnoxious like those ricer burble tunes. Driving around town though, you wouldn't notice a change in the car with the windows up, and it sounds just slightly louder than stock outside at lower RPMs.
Old Sep 6, 2019 | 12:58 PM
agp423's Avatar
2018 GLC63
How much can one expect to pay for a secondary cat delete, parts and labor? And is this a weld job or a clamp job?
Old Sep 6, 2019 | 01:29 PM
BalanBro's Avatar
2012 C63 P31 Sedan
PM Mike (Post#17) for the cost of the pipe. The quality of the materials is excellent, and the design reuses 3 existing exhaust clamps. You will have to cut one pipe to remove the OEM secondaries, and Mike supplies a new clamp that will connect this section, so there is no welding required. Expect a shop to charge 1-1.5 hr labor for the install. It really shouldn't take that long, but most reputable shops will probably be in that ballpark if they are working on an AMG car.
You can also do it yourself and save all the labor, as long as you have the tools and are comfortable with cutting.
Old Sep 6, 2019 | 02:47 PM
INS1GNIA's Avatar
'13 C63 AMG P31
Depends on the shop and where you live. Can be anything from $80-$500.
Old Sep 7, 2019 | 11:00 AM
agp423's Avatar
2018 GLC63
My trusted shop says the entire exhaust should be removed for this, cut, add straight pipe in place of second cats, and then have the exhaust put back. I was quoted a day's work and $800-$1000...
