C63 AMG (W204) 2008 - 2015
Liqui Moly recommended against running Molygen
Old May 5, 2024 | 07:42 AM
  #51
GreasedFolgore's Avatar
2025 Maserati Grecale Folgore and 2024 Jaguar F-PACE SVR
Molybdenum is great stuff. There's even some in my daily multivitamin supplement. But same way it sticks to metal parts preventing cold-startup wear it also sticks to little metal particles floating around in your oil which makes them sink to the bottom of the pan and clogs up your oil filter faster. That's why you don't see it in extended service interval oils. Personally I only add it when I'm down about half a quart instead of using it every oil change. The straight stuff is Liqui Moly part # 2009 or LM2009 at NAPA.
Old May 7, 2024 | 04:48 PM
  #52
kafklatsch's Avatar
All Cars Lost To Hurricane Isaac (W124 E420 revived - added 88 Allante 14 S550, 17 S63
Oh, im Sorry ... my goal is to share experience
Everyone is welcome to thier own decisions of course... I ruined an engine in my youth due to lack of proper maintenance, so for 25+ years i have paid attention. My decision is to use the oils I have listed.
My contribution here is simply pointing out my results across many automobiles and several AMG's.
To open up an engine and see clear oilly surfaces throughout..to never see glitter, ...to scope cylinders between plug changes and see pristine walls is something I decided to share... the results are from using the oils I mentioned.
as is always...your mileage may vary
hope my goal doesn't offend, and beg you not to text angry because these happen to work for me
QUOTE=Audi Junkie;8965957]No, it is not approved nor will it be since it's extra additives create extra deposits, which are strictly limited by Mercedes.
https://www.infineuminsight.com/medi...-pages-002.pdf
https://pim.liqui-moly.de/pdf/en_GB/liqui/35/P001759
What are your goals running this oil? Have you done any lab work to ascertain problematic wear rates, or...?[/QUOTE]
Old Jul 29, 2024 | 05:03 PM
  #53
nitroracer's Avatar
Audi
Originally Posted by roadkillrob
2 things:
1. How much where you paid for this post?
2. Since I created this thread long ago, Molygen 5W40 has been certified as MB 229.5 and is fine to run in the M156.
Thanks for this. I see it's not listed on their website but other forums agree.
Old Jul 31, 2024 | 08:52 AM
  #54
LARSLEMANS's Avatar
2008 C63 AMG
Dont do 10W40. The highest recommended is 5W40 because of the oil line thickness
