Transmission Rebuild
The implication is that this fluid is another one of those "lifetime lubricants", which since the days of the BMW E36 automatic transmission lawsuit, we know that in corporate language lifetime= 100 k miles.
However for a track car, the ultra heavy service that the transmission is put through, then reduces the service life of the lifetime lubricant from 100k to .... maybe 60k.
Btw, drag racing and doing burnouts, donuts, drifting, can also accelerate the replacement interval of the clutch pack lubricant fluid.
Furthermore, a clutch pack is in the end a clutch.
Clutches are rated for an amount of torque. Once you mod the car and increase the torque output a lot, then the clutch starts to operate close to its torque holding limit. That must reduce its fluid replacement interval.
Now since the oil is sealed inside the pack, the only way to change the oil, is to change the pack.
Maybe this is why it's cheap, it's a consumable.
I could have sworn someone mentioned using the new SmartMediaTriple filter with the red fluid is
EDIT: FCP Euro upgrade kit https://www.fcpeuro.com/products/mer...n-001989680310 shows "Not for vehicles with A89 Option Code" and the filter in the kit list is https://www.fcpeuro.com/products/mer...a89-2222772000 which is the new filter.
If a piece of equipment is sealed and immersed in some fluid, then fluid cannot travel through it.
As far as the clutch pack being not sealed and just immersed in transmission fluid, I see that as not standing to logic either:
A difference between a torque converter and a clutch is that the torque converter is not a wearable item that generates waste material as it wears.
You cannot have something wear down and contaminate the transmission fluid in the process.
This is why it seems logical that:
A there is a fluid in the clutch pack, as it's referred to as a wet clutch
B the fluid contains debris from the constantly wearing clutch discs and it should not mix and contaminate the overall transmission fluid
C the quantities for the oil change of the wet clutch cars seem (can't recall for sure so check this) lower than the torque converter cars, suggesting that the volume of fluid that is contained in the torque converter is ... not present. If there was the same volume of fluid in the clutch pack, probably the oil change volume total would be the same.
If the volumes of oil change are different, then the difference of volumes may be the oil that is sealed in the clutch pack and cannot be drained or replaced.
If it were true that the transmission fluid freely circulates through the clutch pack, I would hope there is some sort of filter somewhere, to remove the particles of clutch lining, before the fluid exits the clutch pack.
As it stands, with the 7 speeds, I was reading somewhere that the export versions of this, when compared to the German versions, lack some sort of additional filter.
I was putting this information together with information that one person posted, saying that if when doing the transmission oil change, you take additional time and you remove the contact plate and then remove the solenoids and carefully clean both before reinstalling and then completing the job, you improve the feel of the transmission a lot.
Maybe because of the lack of this additional filter, fine debris coat the contact plate and the solenoids and cause rougher shifts and reverse delay.
If anyone with a non-MCT C63 is looking to use the updated smart media filter (same one in FCP's upgrade kit), you will need the deeper pan and green-colored overflow plug.
This A89 code, to my understanding, is just tied to a different fluid used in the factory build. Different flow characteristics, hence the different filter (MB Part # 2222772000).
RE: Deeper OE pan, yeah it's barely anything. Even the Weistec pan that I have claims fluid capacity is increased by 2.5 Quarts but I'm honestly not seeing how with the fill hole so close to the bottom of the pan.
The Weistec pan is filled from the bottom just like the OE transmission pan. That side hole is one of two that are there in case anyone wants to rig up an external transmission cooler.
