C63 AMG (W204) 2008 - 2015
HELP! 2012 C63 with massive oil leak
Old Dec 9, 2020 | 05:25 PM
00GTS's Avatar
2012 C63 (P30)
Just purchased a 2012 C63 (P31) today with 110,000 km on it. No problems with safety inspection. Car appears to be in great condition.
Got it home and went out to put some fresh gas in it and when I returned home and parked it, there is oil pissing everywhere at the front right wheel. Oil in the wheel well and inside the rim. Puddle on the ground and all down my driveway.
Looking from above there is nothing to be seen. Too dark now to get under the car.
Ideas? Is there an oil cooler line in there? I'm very mechanically inclined but this is my first Benz and I'm not familiar with the car yet.
Any suggestions would be great.
HELP!
Old Dec 9, 2020 | 06:05 PM
BalanBro's Avatar
2012 C63 P31 Sedan
Yup, that's where the oil cooler is, behind the bumper in front of the passenger side wheel.
Old Dec 9, 2020 | 06:32 PM
00GTS's Avatar
2012 C63 (P30)
Common issue?
Is it typically the hose or the cooler that fails? Tough to access? Drop belly pan and all will reveal itself?
Old Dec 9, 2020 | 07:25 PM
Cammer88's Avatar
E63s
Dealer or Private?
Old Dec 9, 2020 | 07:26 PM
00GTS's Avatar
2012 C63 (P30)
Private.....of course.
Old Dec 9, 2020 | 09:01 PM
Xavier Smith II's Avatar
2010 C63 AMG, 2015 GL450, 2018 GLS 550, 2021 GLS 450
Originally Posted by 00GTS
Common issue?
there’s a Bolt just under the front cover, where the under shield meets the bumper on the passenger side that’s a plug for I believe cooler itself, if you car has been exposed to road salt, it can corrode and fail.
Old Dec 10, 2020 | 09:50 AM
00GTS's Avatar
2012 C63 (P30)
It looks like the cooler has failed. Is this common?
Leaking upper right side by the looks of it.
Old Dec 10, 2020 | 10:04 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Nope, I think you're the first.
EDIT: I believe that top corner is an inlet/outlet. Could be a bad o-ring or the hose connection is not seated properly.
Old Dec 10, 2020 | 10:20 AM
00GTS's Avatar
2012 C63 (P30)
Wonderful.....
Old Dec 10, 2020 | 10:42 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Probably a simple fix.
Old Dec 10, 2020 | 03:25 PM
00GTS's Avatar
2012 C63 (P30)
It's out. What a ***** of a job. New one on order.
Old Dec 10, 2020 | 03:43 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
You found an internal leak in the cooler? Did something strike it? Yours looks new compared to mine lol. This is also after I spent 20min with a dental pick to clean out the fins.
Old Dec 10, 2020 | 03:46 PM
00GTS's Avatar
2012 C63 (P30)
I couldn't see any visible damage.
It has to be an internal failure of the cooler. Nowhere else for the oil to magically appear! Inlet and outlet hoses were dry. Not a speck of oil on them or the flanges.
Old Dec 10, 2020 | 04:11 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Was your fender liner damaged, i.e., could it have been punctured by a pebble thrown up by the front wheel?
Old Dec 10, 2020 | 04:13 PM
00GTS's Avatar
2012 C63 (P30)
Nothing looks damaged. Really weird. I've had the car one whole day!
Old Dec 10, 2020 | 04:28 PM
Diabolis's Avatar
I threw out a perfectly good oil cooler - that same one, that was used for a total of maybe 5,000 km - about three months ago. It got replaced with a bigger one when I had the 44O oil cooling package installed a number of years back, and I had kept the original parts in the locker downstairs until we cleaned it out in the summer. I figured no one ever is going to need it... I would have gladly given it to you for free.
Old Dec 10, 2020 | 04:49 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Dammit, I would have taken it off your hands because mine is probably only 70% effective right now.
Old Dec 10, 2020 | 05:31 PM
00GTS's Avatar
2012 C63 (P30)
Noooooo!
Old Dec 10, 2020 | 06:43 PM
Diabolis's Avatar
Sorry. This was the cooler prior to removal...
