C63 AMG (W204) 2008 - 2015
M156 & M159 Tuning Packages with eightysixtuned
Old 10-25-2021, 05:21 PM
  #76
TDSixty3's Avatar
2014 C63 Sedan
so basically compared to eurocharge you guys are just able to log and dial more parameters with hp tuners and thats way more benefical then what eurocharge does?
Saurabh914 (10-25-2021)
Old 10-26-2021, 01:09 AM
  #77
SPONSOR
hachiroku's Avatar
2007 Mercedes E63 AMG
last count we modify over 130 maps for each tune. supercharged vehicles more. that many maps aren't even available through dimsport.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
TDSixty3 (10-26-2021)
Old 10-26-2021, 11:13 PM
  #78
12C63's Avatar
2012 C63
Hmm…
I have some questions.
Check your inbox.
Old 10-27-2021, 01:19 PM
  #79
SPONSOR
hachiroku's Avatar
replies to all PM's sent.
__________________
-BARRY
Old 12-16-2021, 03:21 PM
  #80
C63nut's Avatar
2013 C63 AMG W204
Do you have a side by side comparison between Eurocharge and your tunes?
So far I like the EC tune I have but based on my experience with another car, some tunes are better than others and I like the idea of being able to makes changes myself. I have experience with standalone ecu's so working with HP tuners shouldn't be a problem.
Can I use HP tuners to backup my EC tune and switch back and forth between tunes?
Old 12-16-2021, 03:33 PM
  #81
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
HP tuners is definitely the most powerful tuning software for our cars.
My car was previously tuned using different software (Alientech I think).
It made good power. But then we decidedly to tune using HPtuners, as this allows you to play with the variable valve timing.
My car picked up massively in the low and mid range, with decent gains on top.
swedepat (03-29-2022)
Old 12-16-2021, 03:56 PM
  #82
SPONSOR
hachiroku's Avatar
we don't compare our tunes against other tuners as we are the only public tuner on mbworld that offers a complete custom tuning service. many of our customers have had tuners from various vendors and have had many positives things to say once switching over to us. feel free to do a search. if you have a dimsport handheld programmer from another tuner, you can switch back and forth between their tune and our tune if that is what you'd like to do.
the misconception is tuning is tuning is tuning. this shows your lack of understanding of what is tuning and what is not tuning. standalone tuning is a cake walk in comparison to Bosch Motronic tuning. the Bosch Motronic computer has over a thousand maps...so many I have not attempted to count them and they all interact with one another. nothing like a standalone where you can simply touch one thing and it affect one thing.
__________________
-BARRY
YYCStage3 (12-16-2021)
Old 12-16-2021, 05:34 PM
  #83
C63nut's Avatar
2013 C63 AMG W204
You obviously didn't understand my question if you come back with that when I'm asking you simple Yes or No questions.
I guess I'll ask HP tuners
Old 12-16-2021, 06:41 PM
  #84
Panzerbiscuit's Avatar
C63 AMG
hey mate, i tried two different companies for "canned" tunes before i went with Barry. Check my post history, i have some side by side comparisons between different companies tunes. With dyno graphs and dragy times.
Barrys tunes are arguably the best on the market. The customer service is second to none. Most companies, one they have your money they wont help you with any issues or answer any questions you may have. Barry will work with you to develop your tune into something that is optimised for your car and driving style.
I have yet to chuck my car on a dybo yet with Barry's Sport tune, which is a revision of his base tune made using my data logs. From the bum dyno, the sport tune is a masterpiece. The car is responsive in all rpm ranges in any gear, pulls hard to redline and breaks traction if you bury the throttle.
The following 5 users liked this post by Panzerbiscuit:
C63nut (12-17-2021), hachiroku (12-17-2021), sytfu_colan (12-17-2021), yfz rock (12-19-2021), YYCStage3 (12-17-2021)
Old 12-18-2021, 05:33 PM
  #85
95gsrturbo's Avatar
2000 Acura NSX, 2012 C63 P31 (gone and not forgotten), 2015 C63 507
How much will I have to worry about pressure on the motor as sensitive as these engines are?
Or are they pretty bulletproof?
Old 12-18-2021, 05:47 PM
  #86
YYCStage3's Avatar
2012 C63 AMG P31, Stage 3 Weistec
There are guys running 750whp+ on stock cast engines.
Even more on P31 cars.
They run a tight ring gap, but I would say they are very robust for most applications. Of course, depends on how much air and fuel you plan to cram down it's throat. Everything has it's limits.
hachiroku (12-19-2021)
Old 12-18-2021, 07:41 PM
  #87
C63 AMG
As others have stated, 750whp isn't unheard of out of a stock engine. The transmission will go before the engine goes pop.
A decent tuner will work with you to make ensure you make good power while maintaining reliability and drive ability.
Just make sure you're up too date on any maintenance before you start modding.
Old 02-04-2022, 04:31 PM
  #88
SPONSOR
hachiroku's Avatar
currently in the process of tuning a customers 4L Whipple. should be fun with power capabilities of 700-1300whp. pretty broad power range for this blower.
__________________
-BARRY
The following 2 users liked this post by hachiroku:
BalanBro (02-07-2022), BLKROKT (02-04-2022)
Old 03-28-2022, 09:02 PM
  #89
SPONSOR
hachiroku's Avatar
470 whp 415 ft/lbs on 3 runs
no tuning done on dyno, simply made some quick map updates to an old tune and slapped the car on the dyno
+6% to a dyno jet equates to 498.2whp and 439.9ft/lbs
91 octane
2007 e63 amg (m156)
engine 165k miles
factory engine opened to replace headbolts
original camshafts missing a bit on the lobes due to wear
original cam adjusters making lots of noise and throwing codes from time to time
original throttle body mounting plate leaking air as well
mustang dyno (6-12% lower reading than a dynojet)
hammer tune by @eightysixtuned
mod list, lth, and high flow injectors
the dip is when they turned on their Dyno fan which seems to flow crazy air compared to their previous Dyno fan.
__________________
-BARRY
Old 03-28-2022, 11:59 PM
  #90
sickSVT's Avatar
E63
Strong numbers Barry! Always finding ways to improve your work.
hachiroku (03-29-2022)
Old 03-29-2022, 02:10 AM
  #91
SPONSOR
hachiroku's Avatar
thanks Charlie!
__________________
-BARRY
p30amg08 (03-29-2022)
Old 03-29-2022, 02:27 PM
  #92
James115's Avatar
C63 Amg
does anybody know where to get the carbon fiber air intake of the picture of this tuner page?
Old 04-19-2022, 09:23 PM
  #93
SPONSOR
hachiroku's Avatar
FYI, 82mm or larger throttle bodies work with our tunes without issue. we also do offer an optional add on if folks are looking for us to remap the larger throttle bodies to be smoother at take off.
__________________
-BARRY
James115 (04-19-2022), sickSVT (04-19-2022)
Old 06-15-2022, 07:48 PM
  #94
SPONSOR
hachiroku's Avatar
Hey all,
Finally got around to gathering some videos to outline the improved shift performance. We always recommend a proper tune to help with shift performance before a customer spending more money on other transmission mods.
__________________
-BARRY
HLG600 (06-16-2022)
Old 07-02-2022, 08:05 PM
  #95
khundaqji's Avatar
C63 P31 Coupe, GLC 410 Brabus
hello i have a c63 2013
midcat delete we use 95oct located in Qatar
how much does the tune cost ?
Old 07-23-2022, 10:50 AM
  #96
OzzyOz's Avatar
w204 c63 coupe
Hey hacriroku I filled out the form on the website and sent you an email as well regarding the tune, could you please respond to that or DM me? Thank you
Old 11-21-2022, 12:39 PM
  #97
eightysixtuned's Avatar
W211 E63 AMG
Old 11-21-2022, 12:46 PM
  #98
SPONSOR
hachiroku's Avatar
We rarely offer discounts, but... since you asked nicely. Here's our BLACK FRIDAY sale!
https://eightysixtuned.com/discount/BF15
DISCOUNT CODE: BF15
for 15% off our entire site.
__________________
-BARRY
Old 11-21-2022, 12:58 PM
  #99
W211 E63 AMG
Old 11-21-2022, 01:12 PM
  #100
SPONSOR
hachiroku's Avatar
hi, our most current pricing is available on our website. https://www.eightysixtuned.com
hi, we have replied to all of our emails. if we missed you yet again, please let us know. thanks!
__________________
-BARRY
Quick Reply: M156 & M159 Tuning Packages with eightysixtuned
