Advice Lowering and Spacers
10mm on rear is fine with 255 but if you want 265-275 for better traction then you'll need to stay with a thinner spacer.
Unfortunately 10mm is the thinnest hub style spacer and also the safest way to run spacers.
With the rear stock ET54 you can run a 4mm spacer and still have hub to safely rest the wheel on.
12mm for front is fine with 235 tire but a 245 would be better with 10mm.
Here is a good site to begin your search: https://otisincla.com/
If you are not sure what bolts you need give Phil a call and he will be happy to help you out.
