C63 AMG (W204) 2008 - 2015
What did you do to your C63 today?
Old Jul 6, 2025 | 11:46 PM
  #426
Phil_T's Avatar
C63 AMG Saloon
Originally Posted by svtjocson
how much did it cost to do this? Is just the outside treated?
I've been told to cerakote my new headers inside and out but you mentioned ceramic heat treating is better?
I am from the UK not USA. Just the outside is treated as doing the inside can cause problems.
As above cerakote does nothing for heat protection and is just for visual appearance.
Old Jul 7, 2025 | 04:21 AM
  #427
DRBC43AMG's Avatar
Originally Posted by Phil_T
Yes which is why I did it, properly done using zirconia not like the cerakote which basically doing nothing for heat.
BTW did you get it done at Zircotec? I think they are the best around. Not cheap but top quality work
Old Jul 7, 2025 | 05:30 AM
  #428
Phil_T's Avatar
C63 AMG Saloon
Nope found a local company in the UK that does it properly (they do things for MOD, Nuclear, Raceteams and Hypercar companies), read the Zircotec reviews as they are not good with coating flaking off as they rushed it or didn’t prepare it properly. In the USA the best company to use is Swaintech.
Local company I used in the UK and Swaintech in the USA were the same price around $850-900 both with no bad reviews but Zircrotec with loads of bad reviews wanted $1700.
Old Jul 7, 2025 | 03:35 PM
  #429
DRBC43AMG's Avatar
Oh, so it looks like Zircotec's quality has gone down the drain. Pity because they were one of the best around
Old Jul 8, 2025 | 02:42 AM
  #430
Phil_T's Avatar
C63 AMG Saloon
It seems it’s always hit and miss with them now for many years. The work done to mine is just as good as their best work, the coating has been applied flawless even if it looks different in the pictures it is just the way the coating absorbs the light and makes it look different on camera.
Old Oct 3, 2025 | 07:51 PM
  #431
sickSVT's Avatar
Top Answer: 1
3.0L Whipple E63 AMG
Got my ATI Super Damper crank pulley to replace my UPD underdrive pulley. Should increase my boost by about 2-3psi.
ATI Damper next to OEM crank pulley.
Old Oct 4, 2025 | 02:41 PM
  #432
svtjocson's Avatar
2010 C63
Reason for switch from UPD to ATI? Which do you recommended for n/a?
Old Oct 4, 2025 | 02:45 PM
  #433
sickSVT's Avatar
Top Answer: 1
UPD is about 20% underdrive and works best for NA. If you're boosted ATI is better.
Old Oct 4, 2025 | 03:06 PM
  #434
svtjocson's Avatar
2010 C63
Okay that's what I figured but wanted to verify since you have both. I'm excited to put this UPD pulley on, I've heard good things on n/a
Old Oct 5, 2025 | 09:32 AM
  #435
Joshinator99's Avatar
ML 63 AMG
I run the ATI on my Whipple supercharged Camaro as well. It’s a stout damper and works well.
Old Oct 7, 2025 | 09:32 AM
  #436
SICAMG's Avatar
2005 e55 AMG
Didn't really "do" anything to the car but brought my son to his first race ever to get his feet wet in his 2012 P31 Coupe and he is hooked !! It was a roll race event and he started at 124mph and ended the day at 133mph so we where VERY happy for a stock car with headers on it. Need to get temperatures down a little ,it was really hot, and it started the run at 220* . Hopefully a tuner can get the fan running faster for the staging lanes for us when he is ready for a tune. Timing was at 22* and AFR 11.6-11.8 across the run so for sure room for improvement.
Old Oct 7, 2025 | 10:48 AM
  #437
DRBC43AMG's Avatar
Get an oil cooler upgrade. It really improves things and does the work as it should, simple to install and the engine will be happy
C63 AMG Oil Cooler solution! Reasonable 44O option! - MBWorld.org Forums
Old Oct 7, 2025 | 11:03 AM
  #438
SICAMG's Avatar
2005 e55 AMG
Was looking into that cooler but the biggest issue is getting to the staging lanes, almost 1/2 mile away I would guess, and then sitting in the staging lanes for at least 15 minutes so there is no air flow to speak of and things get hot quickly BEFORE the run even starts. I'm thinking higher fan speed would help greatly as it does in my E55.
Old Nov 12, 2025 | 10:01 PM
  #439
sickSVT's Avatar
Top Answer: 1
Installed my ATI Damper pulley, just needs an oil change and should be ready to rip for boost weather.
Old Nov 13, 2025 | 06:25 AM
  #440
Phil_T's Avatar
C63 AMG Saloon
Finally installed MBH headers
Old Nov 14, 2025 | 08:58 PM
  #441
ShazV6's Avatar
17' C43 Coupe
Sounds great, what is the rest of the exhaust setup like?
Old Nov 15, 2025 | 05:29 AM
  #442
Phil_T's Avatar
C63 AMG Saloon
MBH Catless headers, new mid pipes with secondary decat, stock resonator, stock mufflers. This is the best way to keep the Amg tone otherwise you lose it. (You can add cats in though if you wish and it will be the same tone)
Old Nov 15, 2025 | 07:51 AM
  #443
LSAMG's Avatar
2013 C63 AMG Sedan
MBH Gang
Old Nov 25, 2025 | 06:18 PM
  #444
Gene Gorman's Avatar
05 SL55, 10 C63, 12 SLK3, 20 S560, 08Bentley GT Speed, 16 Aston Martin Vanquish
Took the c63 out from the back of the garage and took my wife out for brunch. Every time I drive it I’m amazed at what a great car it is. The way it drives, sounds, and the way it goes. It now has 2751 miles on it. It is like a new 15 year old Mercedes. Definitely a keeper. Hope everyone has a great thanksgiving.
Old Nov 25, 2025 | 08:52 PM
  #445
SICAMG's Avatar
2005 e55 AMG
Wow 2,700 miles !!
By my calculations your next oil change will be in 45 years !! LOL Leave a note for the grand kids !!!
Old Nov 25, 2025 | 09:57 PM
  #446
Funny one of our grandsons owns our old C32 Mercedes.
Old Nov 26, 2025 | 07:40 PM
  #447
SICAMG's Avatar
2005 e55 AMG
Ooops my bad. In 60 years it should have 10,800 miles at the current 2750 miles per 15 years !! LOL
It may need tires LOL
Old Nov 30, 2025 | 04:27 PM
  #448
Meeyatch1's Avatar
'94 NSX,'99 NSX Z,'12 C63 Black Series (Prior: '07 E63, '08 CLK63 Black Series,'14 E63-S & 16 C63-S)
Crossed over 80,000 miles on the Black Series last week during a long county drive. Looking forward to seeing how fast I get to 100,000 miles.
80,000 miles on the C63 Black Series.
Old Dec 1, 2025 | 04:52 AM
  #449
DRBC43AMG's Avatar
Changed my wheels to 18" and winter tires 225/40 front and rear as recommended by the factory. Even if I don't drive much in the winter months, not unless the roads are dry and salt free
Old Dec 29, 2025 | 12:59 AM
  #450
sickSVT's Avatar
Top Answer: 1
Took it out for a spin.
